[PATCH] Write event stream in file
Tue Jun 25 08:19:39 UTC 2019
On 25/06/2019 09:48, Ravindra Kumar Meena wrote:
>      >     Do you get compiler warnings with this version?
>      > No I didn't get any compiler warning or error.
>     How did you configure the build? Did you somehow disable the warnings?
>     [242/254] Compiling misc/record/record-main.c
>     ../misc/record/record-main.c: In function ‘print_item’:
>     ../misc/record/record-main.c:152:14: warning: variable ‘seconds’ set
>     but
>     not used [-Wunused-but-set-variable]
>            uint32_t seconds;
>     ../misc/record/record-main.c: In function ‘handler’:
>     ../misc/record/record-main.c:161:14: warning: ‘ns’ may be used
>     uninitialized in this function [-Wmaybe-uninitialized]
>          ctf_item.ns=ns;
>     ../misc/record/record-main.c:149:12: note: ‘ns’ was declared here
>          uint32_t ns;
> Okay. I also got these warnings after reconfiguring again. This can be
> resolved if we remove the if block. I think there is no need for it now.
No, sorry, please fix these warnings immediately. Warnings about
uninitialized variables are very likely a hard error.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
