BBB Framebuffer driver : Project status
Tue Jun 25 16:02:40 UTC 2019
On Tue, Jun 25, 2019 at 5:34 AM Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> Hello,
> The First Evaluation is going on and I here I would summarize all the progress
> that the project has made in the first Phase.
> 1. The major progress is the completion of the I2C adaptation layer in the libbsd
>      along with the iicbus driver imports. The v4 of the driver [1] has been tested to be
>      working with the bbb-i2c driver patch [2]. After the RTEMS driver is updated in the
>      master, the adaptation layer will be mergeable.
> 2. I am getting EDID reading from the imported tda drivers. I have checked this using
>     the ti_i2c driver but now as we have an updated version  of the driver, I'll pull this all
>     with the adaptation layer and will continue from there.
> 3. I found a sample app from the freebsd mailing list, that draws a basic shape on the
>     screen. I have made it a standalone app with only single source and have tested it
>      to be working with the FreeBSD. The only issue with the code is that it uses mmap
>      and RTEMS doesn't use mmap so I'm rewriting the app with pread and pwrtie on
>      to write to the /dev/fb0 directly. This app work is ongoing.
We have a rudimentary mmap() support available. I would expect this
might be important to investigate for graphics applications in general
might be trying to mmap() device memory.
> Next Up:
> 1. merge the ported TDA driver and using it with the adaptation layer.
> 2. Import and port the fbd dirver to create an fb0 device.
> 3. complete the sample app and convert it into a libbsd sample app to test the device.
> Thanks,
> Vijay
> devel mailing list
> devel at rtems.org
