Add newlib patch to RTEMS RSB
Tue Jun 25 16:10:05 UTC 2019
On Tue, Jun 25, 2019 at 6:13 AM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Jun 21, 2019 at 9:22 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>> On Fri, Jun 21, 2019, 7:19 PM Joel Sherrill <joel at rtems.org> wrote:
>>> On Fri, Jun 21, 2019 at 3:37 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
>>>> Hello,
>>>> I figured it out.
>>>> Below is the output given by shell
>>>> config: tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
>>>> warning: rtems-gcc-7.4.0-newlib-1d35a003f.cfg:29: invalid format: '%setup patch newlib -p'
>>>> error: gcc-common-1.cfg:80: %patch already setup source: newlib -p1
>>>> Build FAILED
>>>> Build Set: Time 0:06:29.257451
>>>> Build FAILED
>>>> I realized, the name of group of my patch and the source of newlib-source was same in        rtems-gcc-7.4.0-newlib-1d35a003f.cfg. Also, I had put "%patch setup" statement before "%patch add" .
>>>> Here is the new git-diff. This got compiled successfully
>>> Great! How is the testing going?
>> I have placed ndbm.h in     newlib/libc/include    directory.
>> ndbm.h     requires    db.h (named as db_local.h in newlib), which is present in    newlib/libc/search   directory.
>> This directory also contains     hash.h     and     hash.c  which is required by    ndbm.c
>> So gedare suggested me to place    ndbm.c     in this   libc/search     directory.
>> Here, when I compiled newlib for sparc, it was successful and generates function symbols.
>> But when I added this patch to RSB, and made a sample program calling ndbm functions, just to check if it is successful port or not, its showing me compile time error.
>> Error: https://lists.rtems.org/pipermail/devel/2019-June/026271.html
> Any header files which are included by ndbm.h directly or indirectly must be available after it is installed. So putting them in libc/search isn't going to work.
> So move the .h files as needed to libc/include and try again.
I'm not sure this is the best solution, and it might face resistance
in newlib (hard to say without sending a working patch, though). My
thought was that the ndbm.h file should be stripped down to just the
publicly necessary prototypes as per
http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/ndbm.h.html
I suspect cross-checking the POSIX spec with the ndbm.h from FreeBSD
will allow to identify which pieces to keep there, which might be
moved to a private header inside search/, or which may be removed
entirely. (e.g., I don't think dmb_pagfno() is necessary?)
Gedare
