GSoC Project | Basic Support for Trace Compass
Tue Jun 25 18:37:09 UTC 2019
I had a look at the metadata file:
typedef enum events_e : uint64_t_be {
Why is it like this? Your structure looks like this:
typedef struct ctf_event {
  uint32_t                     event_id;
  uint64_t                     ns;
  uint32_t                     cpu;
  rtems_record_event           event;
  uint64_t                     data;
} ctf_event;
A enum is usually an int, which is int32_t on x86_64. If you don't know what big and little endian is, then look at wikipedia. Getting this sort of things done with trial and error is not time efficient.
