[PATCH v1] Port ndbm
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Tue Jun 25 19:11:49 UTC 2019
Hello
I am sorry i was not able to inform on devel. I was feeling weakness, was
not well, so took rest. Couldn't work last 2 days. I will continue it now.
On Tue, Jun 25, 2019, 11:06 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Vaibhav,
> How did this turn out? I was surprised not to hear about this
> approach by now, and whether or not it worked for you.
> You should post some updates to github, even if it is not working
> code, on a branch or something, to show what you are trying out and to
> have a history of what you investigated.
> Gedare
> On Mon, Jun 24, 2019 at 1:12 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > I will test it!
> > On Sat, Jun 22, 2019 at 2:02 AM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Fri, Jun 21, 2019 at 1:42 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> > On Fri, Jun 21, 2019 at 11:38 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >> On Fri, Jun 21, 2019 at 11:03 AM Vaibhav Gupta <
> vaibhavgupta40 at gmail.com> wrote:
> >> >> > On Fri, Jun 21, 2019, 9:46 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >> >> On Fri, Jun 21, 2019 at 4:25 AM Vaibhav Gupta <
> >> >> >> > Hello Gedare,
> >> >> >> > As you suggested, I have placed nbm.c in libc/search
> directory. This directory contains hash.h, db_local.h, hash.c. And all
> these are required by ndbm.
> >> >> >> > Here newlib got successfully compiled and It was generating
> function symbols.
> >> >> >> > After that when i added the patch to RSB, and tried to compile
> a test to check if ndbm is ported successfully or not.
> >> >> >> > It gave me error:
> >> >> >> > mv -f fileio/.deps/fileio-init.Tpo fileio/.deps/fileio-init.Po
> >> >> >> > sparc-rtems5-gcc -DHAVE_CONFIG_H -I.
> -I/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples
> -I.
> -I/home/varodek/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/include
> -I/home/varodek/development/rtems/kernel/rtems/cpukit/include
> -I/home/varodek/development/rtems/kernel/rtems/cpukit/score/cpu/sparc/include
> -I/home/varodek/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/lib/libbsp/sparc/erc32/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/sparc/include
> -I/home/varodek/development/rtems/kernel/rtems/bsps/sparc/erc32/include
> -DT_FILE_NAME='"init.c"'
> -I/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/../support/include
> -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> -Wnested-externs -MT hello/hello-init.o -MD -MP -MF
> hello/.deps/hello-init.Tpo -c -o hello/hello-init.o `test -f 'hello/init.c'
> || echo
> '/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/'`hello/init.c
> >> >> >> > In file included from
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:17:0:
> /home/varodek/development/rtems/5/sparc-rtems5/include/ndbm.h:43:10: fatal
> error: db_local.h: No such file or directory
> >> >> >> > #include <db_local.h>
> >> >> >> > I found that db_local.h is not present in rtems/5
> directory.
> >> >> >> I suspect that the headers in search/ are not installed, they are
> only
> >> >> >> to be included during compilation of newlib, and probably should
> be
> >> >> >> included by #include "db_local.h" for example. I also find it
> likely
> >> >> > ndbm.h is in libc/include, db_local.h is in libc/search.
> >> >> > I will have to use #include"../search/db_local.h" which
> itself is a very bad way to do so.
> >> >> Definitely shouldn't do that.
> >> >> >> that you should not be including these non-installed headers from
> >> >> >> installed headers inside of libc/include.
> >> >> >> So, you might need to rewrite the ndbm.h so that it does not rely
> on
> >> >> >> some internal headers of newlib.... Just my two cents. Not sure
> if I'm
> >> >> >> right. :)
> >> >> > I can do one thing. db_local.h contains some data structures.
> Also it contains some function declarations, definitions of which are
> present in hash.h.
> >> >> > So i can put those declarations and data structures directly in
> ndbm.h, so won't need to call db_local.h
> >> >> It would be better if you can remove anything requiring db_local.h
> >> >> from ndbm.h so that you don't have to #include db_local.h. You could
> >> >> put those things into maybe db_local.h, or into some new file like
> >> >> search/ndbm_local.h or something. you might need some guidance from
> >> >> newlib maintainers about what is the right way to split the
> >> >> public/private sides of headers like this.
> >> > Actually ndbm.h has declarations of database functions. And all of
> them require a data-type (structure)
> >> > defined in db_local.h . So there is nothing in ndbm.h which I can
> shift to db_local.h
> >> > or ndbm_local.h . If I transfer anything, ndbm.h will lose its
> meaning.
> >> What about forward declare the structures?
> >> > Okay I will ask in newlib. Haven't got reply from them for my
> previous mail though.
> >> >> The basic idea is, how to make it so that #include <ndbm.h> doesn't
> >> >> need to include db_local.h? Instead, you can modify ndbm.c to do
> >> >> something lilke #include "db_local.h" and #include "ndbm_local.h"
> >> >> itself. This way, the ndbm.h header file does not need to "leak" the
> >> >> details of db_local.h to userland.
> >> >> Gedare
> >> >> > Will this be practical?
> >> >> >> > Thank you
> >> >> >> > Vaibhav Gupta
> >> >> >> > On Fri, Jun 21, 2019 at 1:57 AM Vaibhav Gupta <
> >> >> >> >> newlib/libc/include/ndbm.h | 84 +++++++++++++
> >> >> >> >> newlib/libc/search/Makefile.am | 1 +
> >> >> >> >> newlib/libc/search/ndbm.c | 214
> >> >> >> >> 3 files changed, 299 insertions(+)
> >> >> >> >> create mode 100644 newlib/libc/include/ndbm.h
> >> >> >> >> create mode 100644 newlib/libc/search/ndbm.c
> >> >> >> >> diff --git a/newlib/libc/include/ndbm.h
> b/newlib/libc/include/ndbm.h
> >> >> >> >> new file mode 100644
> >> >> >> >> index 000000000..f89f97dd0
> >> >> >> >> --- /dev/null
> >> >> >> >> +++ b/newlib/libc/include/ndbm.h
> >> >> >> >> @@ -0,0 +1,84 @@
> >> >> >> >> + * SPDX-License-Identifier: BSD-3-Clause
> >> >> >> >> + * Copyright (c) 1990, 1993
> >> >> >> >> + * The Regents of the University of California. All
> rights reserved.
> >> >> >> >> + * This code is derived from software contributed to Berkeley
> by
> >> >> >> >> + * Margo Seltzer.
> >> >> >> >> + * Redistribution and use in source and binary forms, with or
> without
> >> >> >> >> + * modification, are permitted provided that the following
> conditions
> >> >> >> >> + * are met:
> >> >> >> >> + * 1. Redistributions of source code must retain the above
> copyright
> >> >> >> >> + * notice, this list of conditions and the following
> disclaimer.
> >> >> >> >> + * 2. Redistributions in binary form must reproduce the above
> copyright
> disclaimer in the
> >> >> >> >> + * documentation and/or other materials provided with the
> distribution.
> >> >> >> >> + * 3. Neither the name of the University nor the names of its
> contributors
> >> >> >> >> + * may be used to endorse or promote products derived from
> this software
> >> >> >> >> + * without specific prior written permission.
> >> >> >> >> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS
> ``AS IS'' AND
> >> >> >> >> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> LIMITED TO, THE
> >> >> >> >> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> >> >> >> >> + * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR
> CONTRIBUTORS BE LIABLE
> >> >> >> >> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> OR CONSEQUENTIAL
> >> >> >> >> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> SUBSTITUTE GOODS
> >> >> >> >> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> INTERRUPTION)
> >> >> >> >> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> CONTRACT, STRICT
> >> >> >> >> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> ARISING IN ANY WAY
> >> >> >> >> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> POSSIBILITY OF
> >> >> >> >> + * SUCH DAMAGE.
> >> >> >> >> + * @(#)ndbm.h 8.1 (Berkeley) 6/2/93
> >> >> >> >> + * $FreeBSD$
> >> >> >> >> +#ifndef _NDBM_H_
> >> >> >> >> +#define _NDBM_H_
> >> >> >> >> +#define __DBINTERFACE_PRIVATE
> >> >> >> >> +#include <db_local.h>
> >> >> >> >> +/* Map dbm interface onto db(3). */
> >> >> >> >> +#define DBM_RDONLY O_RDONLY
> >> >> >> >> +/* Flags to dbm_store(). */
> >> >> >> >> +#define DBM_INSERT 0
> >> >> >> >> +#define DBM_REPLACE 1
> >> >> >> >> + * The db(3) support for ndbm always appends this suffix to
> the
> >> >> >> >> + * file name to avoid overwriting the user's original
> database.
> >> >> >> >> +#define DBM_SUFFIX ".db"
> >> >> >> >> +typedef struct {
> >> >> >> >> + void *dptr;
> >> >> >> >> + int dsize; /* XXX Should be size_t according to
> 1003.1-2008. */
> >> >> >> >> +} datum;
> >> >> >> >> +typedef DB DBM;
> >> >> >> >> +#define dbm_pagfno(a) DBM_PAGFNO_NOT_AVAILABLE
> >> >> >> >> +__BEGIN_DECLS
> >> >> >> >> +int dbm_clearerr(DBM *);
> >> >> >> >> +void dbm_close(DBM *);
> >> >> >> >> +int dbm_delete(DBM *, datum);
> >> >> >> >> +int dbm_error(DBM *);
> >> >> >> >> +datum dbm_fetch(DBM *, datum);
> >> >> >> >> +datum dbm_firstkey(DBM *);
> >> >> >> >> +#if __BSD_VISIBLE
> >> >> >> >> +long dbm_forder(DBM *, datum);
> >> >> >> >> +#endif
> >> >> >> >> +datum dbm_nextkey(DBM *);
> >> >> >> >> +DBM *dbm_open(const char *, int, mode_t);
> >> >> >> >> +int dbm_store(DBM *, datum, datum, int);
> >> >> >> >> +#if __BSD_VISIBLE
> >> >> >> >> +int dbm_dirfno(DBM *);
> >> >> >> >> +#endif
> >> >> >> >> +__END_DECLS
> >> >> >> >> +#endif /* !_NDBM_H_ */
> >> >> >> >> diff --git a/newlib/libc/search/Makefile.am
> b/newlib/libc/search/Makefile.am
> >> >> >> >> index 98920c3f4..a61107fb9 100644
> >> >> >> >> --- a/newlib/libc/search/Makefile.am
> >> >> >> >> +++ b/newlib/libc/search/Makefile.am
> >> >> >> >> @@ -9,6 +9,7 @@ GENERAL_SOURCES = \
> >> >> >> >> db_local.h \
> >> >> >> >> extern.h \
> >> >> >> >> hash.h \
> >> >> >> >> + ndbm.c \
> >> >> >> >> page.h \
> >> >> >> >> qsort.c
> >> >> >> >> diff --git a/newlib/libc/search/ndbm.c
> b/newlib/libc/search/ndbm.c
> >> >> >> >> index 000000000..bd9c71e4f
> >> >> >> >> --- /dev/null
> >> >> >> >> +++ b/newlib/libc/search/ndbm.c
> >> >> >> >> @@ -0,0 +1,214 @@
> rights reserved.
> by
> >> >> >> >> + * Margo Seltzer.
> without
> conditions
> >> >> >> >> + * are met:
> copyright
> disclaimer.
> copyright
> disclaimer in the
> distribution.
> contributors
> this software
> ``AS IS'' AND
> LIMITED TO, THE
> PARTICULAR PURPOSE
> OR CONSEQUENTIAL
> SUBSTITUTE GOODS
> INTERRUPTION)
> CONTRACT, STRICT
> ARISING IN ANY WAY
> POSSIBILITY OF
> >> >> >> >> + * SUCH DAMAGE.
> >> >> >> >> +#if defined(LIBC_SCCS) && !defined(lint)
> >> >> >> >> +static char sccsid[] = "@(#)ndbm.c 8.4 (Berkeley)
> 7/21/94";
> >> >> >> >> +#endif /* LIBC_SCCS and not lint */
> >> >> >> >> +#include <sys/cdefs.h>
> >> >> >> >> +__FBSDID("$FreeBSD$");
> >> >> >> >> + * This package provides a dbm compatible interface to the
> new hashing
> >> >> >> >> + * package described in db(3).
> >> >> >> >> +#include <sys/param.h>
> >> >> >> >> +#include <stdio.h>
> >> >> >> >> +#include <string.h>
> >> >> >> >> +#include <errno.h>
> >> >> >> >> +#include <ndbm.h>
> >> >> >> >> +#include "hash.h"
> >> >> >> >> + * Returns:
> >> >> >> >> + * *DBM on success
> >> >> >> >> + * NULL on failure
> >> >> >> >> +extern DBM *
> >> >> >> >> +dbm_open(const char *file, int flags, mode_t mode)
> >> >> >> >> + HASHINFO info;
> >> >> >> >> + char path[MAXPATHLEN];
> >> >> >> >> + info.bsize = 4096;
> >> >> >> >> + info.ffactor = 40;
> >> >> >> >> + info.nelem = 1;
> >> >> >> >> + info.cachesize = 0;
> >> >> >> >> + info.hash = NULL;
> >> >> >> >> + info.lorder = 0;
> >> >> >> >> + if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX))
> >> >> >> >> + errno = ENAMETOOLONG;
> >> >> >> >> + return(NULL);
> >> >> >> >> + (void)strcpy(path, file);
> >> >> >> >> + (void)strcat(path, DBM_SUFFIX);
> >> >> >> >> + return ((DBM *)__hash_open(path, flags, mode, 0,
> &info));
> >> >> >> >> +extern void
> >> >> >> >> +dbm_close(DBM *db)
> >> >> >> >> + (void)(db->close)(db);
> >> >> >> >> + * Returns:
> >> >> >> >> + * DATUM on success
> >> >> >> >> + * NULL on failure
> >> >> >> >> +extern datum
> >> >> >> >> +dbm_fetch(DBM *db, datum key)
> >> >> >> >> + datum retdata;
> >> >> >> >> + int status;
> >> >> >> >> + DBT dbtkey, dbtretdata;
> >> >> >> >> + dbtkey.data = key.dptr;
> >> >> >> >> + dbtkey.size = key.dsize;
> >> >> >> >> + status = (db->get)(db, &dbtkey, &dbtretdata, 0);
> >> >> >> >> + if (status) {
> >> >> >> >> + dbtretdata.data = NULL;
> >> >> >> >> + dbtretdata.size = 0;
> >> >> >> >> + retdata.dptr = dbtretdata.data;
> >> >> >> >> + retdata.dsize = dbtretdata.size;
> >> >> >> >> + return (retdata);
> >> >> >> >> + * Returns:
> >> >> >> >> + * NULL on failure
> >> >> >> >> +extern datum
> >> >> >> >> +dbm_firstkey(DBM *db)
> >> >> >> >> + int status;
> >> >> >> >> + datum retkey;
> >> >> >> >> + DBT dbtretkey, dbtretdata;
> >> >> >> >> + status = (db->seq)(db, &dbtretkey, &dbtretdata,
> R_FIRST);
> >> >> >> >> + if (status)
> >> >> >> >> + dbtretkey.data = NULL;
> >> >> >> >> + retkey.dptr = dbtretkey.data;
> >> >> >> >> + retkey.dsize = dbtretkey.size;
> >> >> >> >> + return (retkey);
> >> >> >> >> + * Returns:
> >> >> >> >> + * NULL on failure
> >> >> >> >> +extern datum
> >> >> >> >> +dbm_nextkey(DBM *db)
> >> >> >> >> + int status;
> >> >> >> >> + datum retkey;
> R_NEXT);
> >> >> >> >> + if (status)
> >> >> >> >> + return (retkey);
> >> >> >> >> + * Returns:
> >> >> >> >> + * 0 on success
> >> >> >> >> + * <0 failure
> >> >> >> >> +extern int
> >> >> >> >> +dbm_delete(DBM *db, datum key)
> >> >> >> >> + int status;
> >> >> >> >> + DBT dbtkey;
> >> >> >> >> + status = (db->del)(db, &dbtkey, 0);
> >> >> >> >> + if (status)
> >> >> >> >> + return (-1);
> >> >> >> >> + else
> >> >> >> >> + return (0);
> >> >> >> >> + * Returns:
> >> >> >> >> + * 0 on success
> >> >> >> >> + * <0 failure
> >> >> >> >> + * 1 if DBM_INSERT and entry exists
> >> >> >> >> +extern int
> >> >> >> >> +dbm_store(DBM *db, datum key, datum data, int flags)
> >> >> >> >> + DBT dbtkey, dbtdata;
> >> >> >> >> + dbtdata.data = data.dptr;
> >> >> >> >> + dbtdata.size = data.dsize;
> >> >> >> >> + return ((db->put)(db, &dbtkey, &dbtdata,
> >> >> >> >> + (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
> >> >> >> >> +extern int
> >> >> >> >> +dbm_error(DBM *db)
> >> >> >> >> + HTAB *hp;
> >> >> >> >> + hp = (HTAB *)db->internal;
> >> >> >> >> + return (hp->error);
> >> >> >> >> +extern int
> >> >> >> >> +dbm_clearerr(DBM *db)
> >> >> >> >> + HTAB *hp;
> >> >> >> >> + hp->error = 0;
> >> >> >> >> + return (0);
> >> >> >> >> +extern int
> >> >> >> >> +dbm_dirfno(DBM *db)
> >> >> >> >> + return(((HTAB *)db->internal)->fp);
> >> >> >> >> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190626/696f3105/attachment-0001.html>
