GSoC Project | Basic Support for Trace Compass
Wed Jun 26 11:08:30 UTC 2019
On 26/06/2019 12:55, Ravindra Kumar Meena wrote:
>     To be able to better reproduce issues, could you please:
>     1. record a raw record item stream produced by the Qemu target via
>     the nc tool in a file (not more than 100KiB)
>     2. add this file to rtems-tools
> Okay. Where do I have to add this file?
Just add it to misc/record.
>     3. modify the record-client program to read from a file if a
>     --input=<FILE> command line option is given
> Okay. Are you suggesting to add --input=<FILE> flag to the following
> command?
> ./build/misc/rtems-record -H 169.254.159.156 -p 1234 | head
The record client connects currently to the target via TCP. The
--input=<FILE> option should change this so that the record client reads
the data from the specified file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
