[PATCH v2] port ndbm
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Thu Jun 27 05:43:33 UTC 2019
On Thu, Jun 27, 2019 at 10:08 AM Aditya Upadhyay <aadit0402 at gmail.com>
wrote:
> On Thu, Jun 27, 2019 at 2:11 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Hello Gedare,
> > as you suggested, to use the group name of patch as 'newlib'.
> > I did that and then removed the line "%patch setup newlib -p1"
> > It has generated ndbm.h in include directory.
> You are applying the patches to RSB just for testing purpose. It would
> not show your contribution.
> This will only help you to tests your methods what you will be going
> to contribute to newlib.
> So figuring out the solution of this old header replacement or
> updating headers and submitting the patches to
> the newlib is recommended.
Sure, I will complete the testsuite as soon as possible and then push the
patch to newlib.
> I appreciate your effort. Have you figured out how would you be going
> to write the test cases for ndbm and ftw methods?
I did tried to check for the ndbm using raw ndbm methods in
testsuites/samples/hello/init.c:
https://github.com/VARoDeK/rtems/blob/test_ndbm_presence/testsuites/samples/hello/init.c
It showing the error:
/home/varodek/development/rtems/5/lib/gcc/sparc-rtems5/7.4.1/../../../../sparc-rtems5/bin/ld:
hello/hello-init.o: in function `Init':
/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:41:
undefined reference to `dbm_open'
/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:42:
undefined reference to `dbm_store'
/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:45:
undefined reference to `dbm_fetch'
/home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:49:
undefined reference to `dbm_close'
> > Vaibhav Gupta
> > On Wed, Jun 26, 2019 at 8:41 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> On Wed, Jun 26, 2019 at 8:35 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >>> Hello,
> >>> Newlib is compiling successfully.
> >>> But when i applied patch to RSB. It is not generating ndbm.h
> inside rtems/5/sparc-rtem5/include this time.
> >>> I am following same steps again which I followed that day when ndbm.h
> was successfully generated.
> >>> Below are the log files generated by rsb build.
> >> Although, before testing, I update RSB today (git pull). I figured
> that the configuration file, used by rsb for newlib, is now changed.
> >> So i updated my steps accordingly. That is, I added the patch in that
> new configuration file.
> >> According to logs, patch is applied I guess, but it is not generating
> >>> On Wed, Jun 26, 2019 at 8:32 PM Vaibhav Gupta <
> vaibhavgupta40 at gmail.com> wrote:
> >>>> newlib/libc/include/ndbm.h | 84 +++++++++++++
> >>>> newlib/libc/search/Makefile.am | 1 +
> >>>> newlib/libc/search/ndbm.c | 215
> >>>> 3 files changed, 300 insertions(+)
> >>>> create mode 100644 newlib/libc/include/ndbm.h
> >>>> create mode 100644 newlib/libc/search/ndbm.c
> >>>> diff --git a/newlib/libc/include/ndbm.h b/newlib/libc/include/ndbm.h
> >>>> new file mode 100644
> >>>> index 000000000..3b42c60b0
> >>>> --- /dev/null
> >>>> +++ b/newlib/libc/include/ndbm.h
> >>>> @@ -0,0 +1,84 @@
> >>>> + * SPDX-License-Identifier: BSD-3-Clause
> >>>> + * Copyright (c) 1990, 1993
> >>>> + * The Regents of the University of California. All rights
> reserved.
> >>>> + * This code is derived from software contributed to Berkeley by
> >>>> + * Margo Seltzer.
> >>>> + * Redistribution and use in source and binary forms, with or without
> >>>> + * modification, are permitted provided that the following conditions
> >>>> + * are met:
> >>>> + * 1. Redistributions of source code must retain the above copyright
> >>>> + * notice, this list of conditions and the following disclaimer.
> >>>> + * 2. Redistributions in binary form must reproduce the above
> copyright
> in the
> >>>> + * documentation and/or other materials provided with the
> distribution.
> >>>> + * 3. Neither the name of the University nor the names of its
> contributors
> >>>> + * may be used to endorse or promote products derived from this
> software
> >>>> + * without specific prior written permission.
> >>>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS
> IS'' AND
> >>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> >>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> >>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE
> LIABLE
> >>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> >>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
> GOODS
> >>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> INTERRUPTION)
> >>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> CONTRACT, STRICT
> >>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
> ANY WAY
> >>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> POSSIBILITY OF
> >>>> + * SUCH DAMAGE.
> >>>> + * @(#)ndbm.h 8.1 (Berkeley) 6/2/93
> >>>> + * $FreeBSD$
> >>>> +#ifndef _NDBM_H_
> >>>> +#define _NDBM_H_
> >>>> +#define __DBINTERFACE_PRIVATE
> >>>> +/* Map dbm interface onto db(3). */
> >>>> +#define DBM_RDONLY O_RDONLY
> >>>> +/* Flags to dbm_store(). */
> >>>> +#define DBM_INSERT 0
> >>>> +#define DBM_REPLACE 1
> >>>> + * The db(3) support for ndbm always appends this suffix to the
> >>>> + * file name to avoid overwriting the user's original database.
> >>>> +#define DBM_SUFFIX ".db"
> >>>> +typedef struct {
> >>>> + void *dptr;
> >>>> + int dsize; /* XXX Should be size_t according to
> 1003.1-2008. */
> >>>> +} datum;
> >>>> +struct __db;
> >>>> +typedef struct __db DB;
> >>>> +typedef DB DBM;
> >>>> +#define dbm_pagfno(a) DBM_PAGFNO_NOT_AVAILABLE
> >>>> +__BEGIN_DECLS
> >>>> +int dbm_clearerr(DBM *);
> >>>> +void dbm_close(DBM *);
> >>>> +int dbm_delete(DBM *, datum);
> >>>> +int dbm_error(DBM *);
> >>>> +datum dbm_fetch(DBM *, datum);
> >>>> +datum dbm_firstkey(DBM *);
> >>>> +#if __BSD_VISIBLE
> >>>> +long dbm_forder(DBM *, datum);
> >>>> +#endif
> >>>> +datum dbm_nextkey(DBM *);
> >>>> +DBM *dbm_open(const char *, int, mode_t);
> >>>> +int dbm_store(DBM *, datum, datum, int);
> >>>> +#if __BSD_VISIBLE
> >>>> +int dbm_dirfno(DBM *);
> >>>> +#endif
> >>>> +__END_DECLS
> >>>> +#endif /* !_NDBM_H_ */
> >>>> diff --git a/newlib/libc/search/Makefile.am
> b/newlib/libc/search/Makefile.am
> >>>> index 98920c3f4..a61107fb9 100644
> >>>> --- a/newlib/libc/search/Makefile.am
> >>>> +++ b/newlib/libc/search/Makefile.am
> >>>> @@ -9,6 +9,7 @@ GENERAL_SOURCES = \
> >>>> db_local.h \
> >>>> extern.h \
> >>>> hash.h \
> >>>> + ndbm.c \
> >>>> page.h \
> >>>> qsort.c
> >>>> diff --git a/newlib/libc/search/ndbm.c b/newlib/libc/search/ndbm.c
> >>>> index 000000000..8ac6d1f40
> >>>> --- /dev/null
> >>>> +++ b/newlib/libc/search/ndbm.c
> >>>> @@ -0,0 +1,215 @@
> reserved.
> >>>> + * Margo Seltzer.
> >>>> + * are met:
> copyright
> in the
> distribution.
> contributors
> software
> IS'' AND
> THE
> PARTICULAR PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> INTERRUPTION)
> CONTRACT, STRICT
> ANY WAY
> POSSIBILITY OF
> >>>> + * SUCH DAMAGE.
> >>>> +#if defined(LIBC_SCCS) && !defined(lint)
> >>>> +static char sccsid[] = "@(#)ndbm.c 8.4 (Berkeley) 7/21/94";
> >>>> +#endif /* LIBC_SCCS and not lint */
> >>>> +#include <sys/cdefs.h>
> >>>> +__FBSDID("$FreeBSD$");
> >>>> + * This package provides a dbm compatible interface to the new
> hashing
> >>>> + * package described in db(3).
> >>>> +#include <sys/param.h>
> >>>> +#include <stdio.h>
> >>>> +#include <string.h>
> >>>> +#include <errno.h>
> >>>> +#include <ndbm.h>
> >>>> +#include "db_local.h"
> >>>> +#include "hash.h"
> >>>> + * Returns:
> >>>> + * *DBM on success
> >>>> + * NULL on failure
> >>>> +extern DBM *
> >>>> +dbm_open(const char *file, int flags, mode_t mode)
> >>>> + HASHINFO info;
> >>>> + char path[MAXPATHLEN];
> >>>> + info.bsize = 4096;
> >>>> + info.ffactor = 40;
> >>>> + info.nelem = 1;
> >>>> + info.cachesize = 0;
> >>>> + info.hash = NULL;
> >>>> + info.lorder = 0;
> >>>> + if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
> >>>> + errno = ENAMETOOLONG;
> >>>> + return(NULL);
> >>>> + (void)strcpy(path, file);
> >>>> + (void)strcat(path, DBM_SUFFIX);
> >>>> + return ((DBM *)__hash_open(path, flags, mode, 0, &info));
> >>>> +extern void
> >>>> +dbm_close(DBM *db)
> >>>> + (void)(db->close)(db);
> >>>> + * Returns:
> >>>> + * DATUM on success
> >>>> + * NULL on failure
> >>>> +extern datum
> >>>> +dbm_fetch(DBM *db, datum key)
> >>>> + datum retdata;
> >>>> + int status;
> >>>> + DBT dbtkey, dbtretdata;
> >>>> + dbtkey.data = key.dptr;
> >>>> + dbtkey.size = key.dsize;
> >>>> + status = (db->get)(db, &dbtkey, &dbtretdata, 0);
> >>>> + if (status) {
> >>>> + dbtretdata.data = NULL;
> >>>> + dbtretdata.size = 0;
> >>>> + retdata.dptr = dbtretdata.data;
> >>>> + retdata.dsize = dbtretdata.size;
> >>>> + return (retdata);
> >>>> + * Returns:
> >>>> + * NULL on failure
> >>>> +extern datum
> >>>> +dbm_firstkey(DBM *db)
> >>>> + int status;
> >>>> + datum retkey;
> >>>> + DBT dbtretkey, dbtretdata;
> >>>> + status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
> >>>> + if (status)
> >>>> + dbtretkey.data = NULL;
> >>>> + retkey.dptr = dbtretkey.data;
> >>>> + retkey.dsize = dbtretkey.size;
> >>>> + return (retkey);
> >>>> + * Returns:
> >>>> + * NULL on failure
> >>>> +extern datum
> >>>> +dbm_nextkey(DBM *db)
> >>>> + int status;
> >>>> + datum retkey;
> >>>> + status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
> >>>> + if (status)
> >>>> + return (retkey);
> >>>> + * Returns:
> >>>> + * 0 on success
> >>>> + * <0 failure
> >>>> +extern int
> >>>> +dbm_delete(DBM *db, datum key)
> >>>> + int status;
> >>>> + DBT dbtkey;
> >>>> + status = (db->del)(db, &dbtkey, 0);
> >>>> + if (status)
> >>>> + return (-1);
> >>>> + else
> >>>> + return (0);
> >>>> + * Returns:
> >>>> + * 0 on success
> >>>> + * <0 failure
> >>>> + * 1 if DBM_INSERT and entry exists
> >>>> +extern int
> >>>> +dbm_store(DBM *db, datum key, datum data, int flags)
> >>>> + DBT dbtkey, dbtdata;
> >>>> + dbtdata.data = data.dptr;
> >>>> + dbtdata.size = data.dsize;
> >>>> + return ((db->put)(db, &dbtkey, &dbtdata,
> >>>> + (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
> >>>> +extern int
> >>>> +dbm_error(DBM *db)
> >>>> + HTAB *hp;
> >>>> + hp = (HTAB *)db->internal;
> >>>> + return (hp->error);
> >>>> +extern int
> >>>> +dbm_clearerr(DBM *db)
> >>>> + HTAB *hp;
> >>>> + hp->error = 0;
> >>>> + return (0);
> >>>> +extern int
> >>>> +dbm_dirfno(DBM *db)
> >>>> + return(((HTAB *)db->internal)->fp);
> >>>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190627/852aad24/attachment-0001.html>
