[PATCH v2] port ndbm
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Thu Jun 27 06:21:27 UTC 2019
On Thu, Jun 27, 2019 at 11:24 AM Aditya Upadhyay <aadit0402 at gmail.com>
wrote:
> On Thu, Jun 27, 2019 at 11:14 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > On Thu, Jun 27, 2019 at 10:08 AM Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
> >> On Thu, Jun 27, 2019 at 2:11 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> > Hello Gedare,
> >> > as you suggested, to use the group name of patch as 'newlib'.
> >> > I did that and then removed the line "%patch setup newlib -p1"
> >> > It has generated ndbm.h in include directory.
> >> You are applying the patches to RSB just for testing purpose. It would
> >> not show your contribution.
> >> This will only help you to tests your methods what you will be going
> >> to contribute to newlib.
> >> So figuring out the solution of this old header replacement or
> >> updating headers and submitting the patches to
> >> the newlib is recommended.
> > Sure, I will complete the testsuite as soon as possible and then push
> the patch to newlib.
> First you will have to figure out the dependecies between headers,
> only then you would be able to
> send the right patches. Otherwise You have to make much changes in your
> patch.
> >> I appreciate your effort. Have you figured out how would you be going
> >> to write the test cases for ndbm and ftw methods?
> > I did tried to check for the ndbm using raw ndbm methods in
> testsuites/samples/hello/init.c:
> https://github.com/VARoDeK/rtems/blob/test_ndbm_presence/testsuites/samples/hello/init.c
> You will have to write test cases in psxtests directory by following
> this open group page:
> https://pubs.opengroup.org/onlinepubs/9699919799/functions/dbm_clearerr.html
> > It showing the error:
> /home/varodek/development/rtems/5/lib/gcc/sparc-rtems5/7.4.1/../../../../sparc-rtems5/bin/ld:
> hello/hello-init.o: in function `Init':
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:41:
> undefined reference to `dbm_open'
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:42:
> undefined reference to `dbm_store'
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:45:
> undefined reference to `dbm_fetch'
> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:49:
> undefined reference to `dbm_close'
> Can you check whether function symbol is getting generated or not?
> Like when you compile newlib, You can see that function symbol
> using this command:
> $sparc-rtems5-nm `find . -name lib_a-ndbm.o` This command will list
> the function symbol.
When I made changes in Newlib-cygwin, and compiled it in
b-sparc-rtems5-newlib.
I checked for function symbols using commnad :
$ cd
/home/varodek/development/newlib/b-sparc-rtems5-newlib/sparc-rtems5/newlib/libc/posix
$ nm -A ./*.o | grep dbm_close
output<< ./lib_a-ndbm.o:00000000 T dbm_close
> >> > Vaibhav Gupta
> >> > On Wed, Jun 26, 2019 at 8:41 PM Vaibhav Gupta <
> vaibhavgupta40 at gmail.com> wrote:
> >> >> On Wed, Jun 26, 2019 at 8:35 PM Vaibhav Gupta <
> >> >>> Hello,
> >> >>> Newlib is compiling successfully.
> >> >>> But when i applied patch to RSB. It is not generating ndbm.h
> inside rtems/5/sparc-rtem5/include this time.
> >> >>> I am following same steps again which I followed that day when
> ndbm.h was successfully generated.
> >> >>> Below are the log files generated by rsb build.
> >> >> Although, before testing, I update RSB today (git pull). I
> figured that the configuration file, used by rsb for newlib, is now changed.
> >> >> So i updated my steps accordingly. That is, I added the patch in
> that new configuration file.
> >> >> According to logs, patch is applied I guess, but it is not
> generating ndbm.h in include directory.
> >> >>> On Wed, Jun 26, 2019 at 8:32 PM Vaibhav Gupta <
> >> >>>> newlib/libc/include/ndbm.h | 84 +++++++++++++
> >> >>>> newlib/libc/search/Makefile.am | 1 +
> >> >>>> newlib/libc/search/ndbm.c | 215
> >> >>>> 3 files changed, 300 insertions(+)
> >> >>>> create mode 100644 newlib/libc/include/ndbm.h
> >> >>>> create mode 100644 newlib/libc/search/ndbm.c
> >> >>>> diff --git a/newlib/libc/include/ndbm.h
> b/newlib/libc/include/ndbm.h
> >> >>>> new file mode 100644
> >> >>>> index 000000000..3b42c60b0
> >> >>>> --- /dev/null
> >> >>>> +++ b/newlib/libc/include/ndbm.h
> >> >>>> @@ -0,0 +1,84 @@
> >> >>>> + * SPDX-License-Identifier: BSD-3-Clause
> >> >>>> + * Copyright (c) 1990, 1993
> >> >>>> + * The Regents of the University of California. All rights
> reserved.
> >> >>>> + * This code is derived from software contributed to Berkeley by
> >> >>>> + * Margo Seltzer.
> >> >>>> + * Redistribution and use in source and binary forms, with or
> without
> >> >>>> + * modification, are permitted provided that the following
> conditions
> >> >>>> + * are met:
> >> >>>> + * 1. Redistributions of source code must retain the above
> copyright
> >> >>>> + * notice, this list of conditions and the following
> disclaimer.
> >> >>>> + * 2. Redistributions in binary form must reproduce the above
> copyright
> disclaimer in the
> >> >>>> + * documentation and/or other materials provided with the
> distribution.
> >> >>>> + * 3. Neither the name of the University nor the names of its
> contributors
> >> >>>> + * may be used to endorse or promote products derived from
> this software
> >> >>>> + * without specific prior written permission.
> >> >>>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS
> IS'' AND
> >> >>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> >> >>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> >> >>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS
> BE LIABLE
> >> >>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> >> >>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> SUBSTITUTE GOODS
> >> >>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> INTERRUPTION)
> >> >>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> CONTRACT, STRICT
> >> >>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
> IN ANY WAY
> >> >>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> POSSIBILITY OF
> >> >>>> + * SUCH DAMAGE.
> >> >>>> + * @(#)ndbm.h 8.1 (Berkeley) 6/2/93
> >> >>>> + * $FreeBSD$
> >> >>>> +#ifndef _NDBM_H_
> >> >>>> +#define _NDBM_H_
> >> >>>> +#define __DBINTERFACE_PRIVATE
> >> >>>> +/* Map dbm interface onto db(3). */
> >> >>>> +#define DBM_RDONLY O_RDONLY
> >> >>>> +/* Flags to dbm_store(). */
> >> >>>> +#define DBM_INSERT 0
> >> >>>> +#define DBM_REPLACE 1
> >> >>>> + * The db(3) support for ndbm always appends this suffix to the
> >> >>>> + * file name to avoid overwriting the user's original database.
> >> >>>> +#define DBM_SUFFIX ".db"
> >> >>>> +typedef struct {
> >> >>>> + void *dptr;
> >> >>>> + int dsize; /* XXX Should be size_t according to
> 1003.1-2008. */
> >> >>>> +} datum;
> >> >>>> +struct __db;
> >> >>>> +typedef struct __db DB;
> >> >>>> +typedef DB DBM;
> >> >>>> +#define dbm_pagfno(a) DBM_PAGFNO_NOT_AVAILABLE
> >> >>>> +__BEGIN_DECLS
> >> >>>> +int dbm_clearerr(DBM *);
> >> >>>> +void dbm_close(DBM *);
> >> >>>> +int dbm_delete(DBM *, datum);
> >> >>>> +int dbm_error(DBM *);
> >> >>>> +datum dbm_fetch(DBM *, datum);
> >> >>>> +datum dbm_firstkey(DBM *);
> >> >>>> +#if __BSD_VISIBLE
> >> >>>> +long dbm_forder(DBM *, datum);
> >> >>>> +#endif
> >> >>>> +datum dbm_nextkey(DBM *);
> >> >>>> +DBM *dbm_open(const char *, int, mode_t);
> >> >>>> +int dbm_store(DBM *, datum, datum, int);
> >> >>>> +#if __BSD_VISIBLE
> >> >>>> +int dbm_dirfno(DBM *);
> >> >>>> +#endif
> >> >>>> +__END_DECLS
> >> >>>> +#endif /* !_NDBM_H_ */
> >> >>>> diff --git a/newlib/libc/search/Makefile.am
> b/newlib/libc/search/Makefile.am
> >> >>>> index 98920c3f4..a61107fb9 100644
> >> >>>> --- a/newlib/libc/search/Makefile.am
> >> >>>> +++ b/newlib/libc/search/Makefile.am
> >> >>>> @@ -9,6 +9,7 @@ GENERAL_SOURCES = \
> >> >>>> db_local.h \
> >> >>>> extern.h \
> >> >>>> hash.h \
> >> >>>> + ndbm.c \
> >> >>>> page.h \
> >> >>>> qsort.c
> >> >>>> diff --git a/newlib/libc/search/ndbm.c b/newlib/libc/search/ndbm.c
> >> >>>> index 000000000..8ac6d1f40
> >> >>>> --- /dev/null
> >> >>>> +++ b/newlib/libc/search/ndbm.c
> >> >>>> @@ -0,0 +1,215 @@
> reserved.
> >> >>>> + * Margo Seltzer.
> without
> conditions
> >> >>>> + * are met:
> copyright
> disclaimer.
> copyright
> disclaimer in the
> distribution.
> contributors
> this software
> IS'' AND
> TO, THE
> PARTICULAR PURPOSE
> BE LIABLE
> CONSEQUENTIAL
> SUBSTITUTE GOODS
> INTERRUPTION)
> CONTRACT, STRICT
> IN ANY WAY
> POSSIBILITY OF
> >> >>>> + * SUCH DAMAGE.
> >> >>>> +#if defined(LIBC_SCCS) && !defined(lint)
> >> >>>> +static char sccsid[] = "@(#)ndbm.c 8.4 (Berkeley) 7/21/94";
> >> >>>> +#endif /* LIBC_SCCS and not lint */
> >> >>>> +#include <sys/cdefs.h>
> >> >>>> +__FBSDID("$FreeBSD$");
> >> >>>> + * This package provides a dbm compatible interface to the new
> hashing
> >> >>>> + * package described in db(3).
> >> >>>> +#include <sys/param.h>
> >> >>>> +#include <stdio.h>
> >> >>>> +#include <string.h>
> >> >>>> +#include <errno.h>
> >> >>>> +#include <ndbm.h>
> >> >>>> +#include "db_local.h"
> >> >>>> +#include "hash.h"
> >> >>>> + * Returns:
> >> >>>> + * *DBM on success
> >> >>>> + * NULL on failure
> >> >>>> +extern DBM *
> >> >>>> +dbm_open(const char *file, int flags, mode_t mode)
> >> >>>> + HASHINFO info;
> >> >>>> + char path[MAXPATHLEN];
> >> >>>> + info.bsize = 4096;
> >> >>>> + info.ffactor = 40;
> >> >>>> + info.nelem = 1;
> >> >>>> + info.cachesize = 0;
> >> >>>> + info.hash = NULL;
> >> >>>> + info.lorder = 0;
> >> >>>> + if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
> >> >>>> + errno = ENAMETOOLONG;
> >> >>>> + return(NULL);
> >> >>>> + (void)strcpy(path, file);
> >> >>>> + (void)strcat(path, DBM_SUFFIX);
> >> >>>> + return ((DBM *)__hash_open(path, flags, mode, 0, &info));
> >> >>>> +extern void
> >> >>>> +dbm_close(DBM *db)
> >> >>>> + (void)(db->close)(db);
> >> >>>> + * Returns:
> >> >>>> + * DATUM on success
> >> >>>> + * NULL on failure
> >> >>>> +extern datum
> >> >>>> +dbm_fetch(DBM *db, datum key)
> >> >>>> + datum retdata;
> >> >>>> + int status;
> >> >>>> + DBT dbtkey, dbtretdata;
> >> >>>> + dbtkey.data = key.dptr;
> >> >>>> + dbtkey.size = key.dsize;
> >> >>>> + status = (db->get)(db, &dbtkey, &dbtretdata, 0);
> >> >>>> + if (status) {
> >> >>>> + dbtretdata.data = NULL;
> >> >>>> + dbtretdata.size = 0;
> >> >>>> + retdata.dptr = dbtretdata.data;
> >> >>>> + retdata.dsize = dbtretdata.size;
> >> >>>> + return (retdata);
> >> >>>> + * Returns:
> >> >>>> + * NULL on failure
> >> >>>> +extern datum
> >> >>>> +dbm_firstkey(DBM *db)
> >> >>>> + int status;
> >> >>>> + datum retkey;
> >> >>>> + DBT dbtretkey, dbtretdata;
> >> >>>> + status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
> >> >>>> + if (status)
> >> >>>> + dbtretkey.data = NULL;
> >> >>>> + retkey.dptr = dbtretkey.data;
> >> >>>> + retkey.dsize = dbtretkey.size;
> >> >>>> + return (retkey);
> >> >>>> + * Returns:
> >> >>>> + * NULL on failure
> >> >>>> +extern datum
> >> >>>> +dbm_nextkey(DBM *db)
> >> >>>> + int status;
> >> >>>> + datum retkey;
> >> >>>> + status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
> >> >>>> + if (status)
> >> >>>> + return (retkey);
> >> >>>> + * Returns:
> >> >>>> + * 0 on success
> >> >>>> + * <0 failure
> >> >>>> +extern int
> >> >>>> +dbm_delete(DBM *db, datum key)
> >> >>>> + int status;
> >> >>>> + DBT dbtkey;
> >> >>>> + status = (db->del)(db, &dbtkey, 0);
> >> >>>> + if (status)
> >> >>>> + return (-1);
> >> >>>> + else
> >> >>>> + return (0);
> >> >>>> + * Returns:
> >> >>>> + * 0 on success
> >> >>>> + * <0 failure
> >> >>>> + * 1 if DBM_INSERT and entry exists
> >> >>>> +extern int
> >> >>>> +dbm_store(DBM *db, datum key, datum data, int flags)
> >> >>>> + DBT dbtkey, dbtdata;
> >> >>>> + dbtdata.data = data.dptr;
> >> >>>> + dbtdata.size = data.dsize;
> >> >>>> + return ((db->put)(db, &dbtkey, &dbtdata,
> >> >>>> + (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
> >> >>>> +extern int
> >> >>>> +dbm_error(DBM *db)
> >> >>>> + HTAB *hp;
> >> >>>> + hp = (HTAB *)db->internal;
> >> >>>> + return (hp->error);
> >> >>>> +extern int
> >> >>>> +dbm_clearerr(DBM *db)
> >> >>>> + HTAB *hp;
> >> >>>> + hp->error = 0;
> >> >>>> + return (0);
> >> >>>> +extern int
> >> >>>> +dbm_dirfno(DBM *db)
> >> >>>> + return(((HTAB *)db->internal)->fp);
> >> >>>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190627/d21df876/attachment-0001.html>
