Attempt to get rid of -qrtems
Sebastian Huber
Thu Jun 27 12:08:18 UTC 2019
Hello,
I would like to get rid of the -qrtems command for normal RTEMS
applications. The difficulty is that the configuration process to build
GCC with all the target libraries (libatomic, libstdc++, libgomp, etc.)
relies on some link time tests which use the crt0.o, libc.a and libm.a.
The attached patch introduces a new -qrtemsstub command line option
which is enabled during the GCC target library build. In case this
option is not present, then the standard RTEMS libraries will be used,
e.g. librtemscpu.a, librtemsbsp.a, libc.a, etc. For backward
compatibility the -qrtems option is ignored.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190627/0c5d896c/attachment.bin>
