Coverity Scan Configuration?
Gedare Bloom
gedare at rtems.org
Thu Jun 27 21:31:04 UTC 2019
I have an interest and plan to work on this area soon. I made myself a note
to look into the options, and whether any of the rules can be used out of
the box for open source in https://devel.rtems.org/ticket/3710
Gedare
On Thu, Jun 27, 2019, 5:25 AM Joel Sherrill <joel at rtems.org> wrote:
> It would be good to have some control over Scan options but I have never
> seen anything on the Dashboard giving us any control like this. It appears
> to be set to a specific set of options outside our control.
> Also if you follow the path down for help, they send you to Stack Overflow.
> If we can figure out who to ask for help, it would be good. We also need a
> model for our memory allocator and kernel locks. They do support that in
> Scan
> --joel
> On Thu, Jun 27, 2019, 2:18 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> the RTEMS project uses Coverity Scan:
>> https://scan.coverity.com/projects/rtems?tab=overview
>> Can it be configured in the open source program variant? For example
>> Coverity supports a couple of MISRA rules:
>> https://www.synopsys.com/content/dam/synopsys/sig-assets/datasheets/coverity-misra-standards-ds-ul.pdf
>> From the reported defects for RTEMS I guess these rules are not enabled
>> currently. Would it be possible to enable a subset of these rules in our
>> current setup?
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190627/4bc1d1ce/attachment.html>
