Attempt to get rid of -qrtems
Jonathan Brandmeyer jbrandmeyer at planetiq.com
Fri Jun 28 00:08:34 UTC 2019
Closely related, the .pc files installed for each bsp under
lib/pkgconfig also add the -qrtems argument to cflags.
On Thu, Jun 27, 2019 at 5:35 PM Chris Johns <chrisj at rtems.org> wrote:
> On 27/6/19 10:08 pm, Sebastian Huber wrote:
> > I would like to get rid of the -qrtems command for normal RTEMS applications.
> I do not think you can remove -qrtems as it will break all existing configure
> scripts. The default needs to be stubs.
> Chris
> devel mailing list
> devel at rtems.org
Jonathan Brandmeyer
Vice President of Software Engineering
PlanetiQ
