Attempt to get rid of -qrtems
Joel Sherrill
joel at rtems.org
Fri Jun 28 00:13:53 UTC 2019
I want to +1 on the default behavior being right for configure scripts with
no magic.
The .pc file contents reflect the fragments from the make .cfg file. Those
assume infrastructure to get the other arguments. So the .PC files need
more. Good spot
On Thu, Jun 27, 2019, 8:08 PM Jonathan Brandmeyer <jbrandmeyer at planetiq.com>
wrote:
> Closely related, the .pc files installed for each bsp under
> lib/pkgconfig also add the -qrtems argument to cflags.
> On Thu, Jun 27, 2019 at 5:35 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 27/6/19 10:08 pm, Sebastian Huber wrote:
> > > I would like to get rid of the -qrtems command for normal RTEMS
> applications.
> > I do not think you can remove -qrtems as it will break all existing
> configure
> > scripts. The default needs to be stubs.
> > Chris
> > devel mailing list
> > devel at rtems.org
> Jonathan Brandmeyer
> Vice President of Software Engineering
> PlanetiQ
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190627/1812bf0f/attachment-0001.html>
