Coverity Scan Configuration?
Joel Sherrill
joel at rtems.org
Fri Jun 28 02:19:49 UTC 2019
There are also some annotations that can silence warnings for suspect cases
of not having breaks in switches, etc. I recall a few places that adding
annotations would allow users to get cleaner runs.
--joel
On Thu, Jun 27, 2019, 5:31 PM Gedare Bloom <gedare at rtems.org> wrote:
> I have an interest and plan to work on this area soon. I made myself a
> note to look into the options, and whether any of the rules can be used out
> of the box for open source in https://devel.rtems.org/ticket/3710
> Gedare
> On Thu, Jun 27, 2019, 5:25 AM Joel Sherrill <joel at rtems.org> wrote:
>> It would be good to have some control over Scan options but I have never
>> seen anything on the Dashboard giving us any control like this. It appears
>> to be set to a specific set of options outside our control.
>> Also if you follow the path down for help, they send you to Stack
>> Overflow.
>> If we can figure out who to ask for help, it would be good. We also need
>> a model for our memory allocator and kernel locks. They do support that in
>> Scan
>> --joel
>> On Thu, Jun 27, 2019, 2:18 AM Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Hello,
>>> the RTEMS project uses Coverity Scan:
>>> https://scan.coverity.com/projects/rtems?tab=overview
>>> Can it be configured in the open source program variant? For example
>>> Coverity supports a couple of MISRA rules:
>>> https://www.synopsys.com/content/dam/synopsys/sig-assets/datasheets/coverity-misra-standards-ds-ul.pdf
>>> From the reported defects for RTEMS I guess these rules are not enabled
>>> currently. Would it be possible to enable a subset of these rules in our
>>> current setup?
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190627/8cdfd917/attachment.html>
