[PATCH] Record-client program to read from a file for --input=<FILE> flag
Ravindra Meena
rmeena840 at gmail.com
Fri Jun 28 11:01:44 UTC 2019
misc/record/record-main.c | 35 ++++++++++++++++++++++++-----------
1 file changed, 24 insertions(+), 11 deletions(-)
diff --git a/misc/record/record-main.c b/misc/record/record-main.c
index b4591e3..14023e2 100644
--- a/misc/record/record-main.c
+++ b/misc/record/record-main.c
@@ -39,6 +39,8 @@
#include <unistd.h>
#include <inttypes.h>
+#include<fcntl.h>
+#include<errno.h>
#include <netinet/in.h>
#include <arpa/inet.h>
@@ -52,6 +54,7 @@ static const struct option longopts[] = {
{ "host", 1, NULL, 'H' },
{ "port", 1, NULL, 'p' },
{ "items", 1, NULL, 'i' },
+ { "input", 1, NULL, 'f' },
{ NULL, 0, NULL, 0 }
@@ -111,32 +114,35 @@ RB_GENERATE_INTERNAL( active, client_item, active_node, item_cmp, static inline
static void usage( char **argv )
printf(
- "%s [--host=HOST] [--port=PORT] [--items=ITEMS]\n"
+ "%s [--host=HOST] [--port=PORT] [--items=ITEMS] [--input=INPUT]\n"
"\n"
"Mandatory arguments to long options are mandatory for short options too.\n"
- " -h, --help print this help text\n"
- " -H, --host=HOST the host IPv4 address of the record server\n"
- " -p, --port=PORT the TCP port of the record server\n"
- " -i, --items=ITEMS the maximum count of active record items\n",
+ " -h, --help print this help text\n"
+ " -H, --host=HOST the host IPv4 address of the record server\n"
+ " -p, --port=PORT the TCP port of the record server\n"
+ " -i, --items=ITEMS the maximum count of active record items\n"
+ " -input, --input=INPUT the file input\n",
argv[ 0 ]
-static int connect_client( const char *host, uint16_t port )
+static int connect_client( const char *host, uint16_t port, const char *input_file ,bool input_file_flag )
struct sockaddr_in in_addr;
int fd;
int rv;
- fd = socket( PF_INET, SOCK_STREAM, 0 );
+ fd = ( input_file_flag ) ? open( input_file, O_RDONLY ) : socket( PF_INET, SOCK_STREAM, 0 );
assert( fd >= 0 );
memset( &in_addr, 0, sizeof( in_addr ) );
in_addr.sin_family = AF_INET;
in_addr.sin_port = htons( port );
in_addr.sin_addr.s_addr = inet_addr( host );
+ if( !input_file_flag ){
rv = connect( fd, (struct sockaddr *) &in_addr, sizeof( in_addr ) );
assert( rv == 0 );
return fd;
@@ -268,6 +274,8 @@ int main( int argc, char **argv )
client_item *items;
const char *host;
uint16_t port;
+ const char *input_file;
+ bool input_file_flag = false;
int fd;
int rv;
int opt;
@@ -280,7 +288,7 @@ int main( int argc, char **argv )
n = RTEMS_RECORD_CLIENT_MAXIMUM_CPU_COUNT * 1024 * 1024;
while (
- ( opt = getopt_long( argc, argv, "hH:p:i:", &longopts[0], &longindex ) )
+ ( opt = getopt_long( argc, argv, "hH:p:i:f", &longopts[0], &longindex ) )
!= -1
switch ( opt ) {
@@ -297,6 +305,11 @@ int main( int argc, char **argv )
case 'i':
n = (size_t) strtoul( optarg, NULL, 10 );
break;
+ case 'f':
+ input_file = optarg;
+ assert( input_file != NULL );
+ input_file_flag = true;
+ break;
default:
exit( EXIT_FAILURE );
break;
@@ -320,15 +333,15 @@ int main( int argc, char **argv )
SLIST_INSERT_HEAD( &cctx.free_items, &items[ i ], free_node );
- fd = connect_client( host, port );
+ fd = connect_client( host, port , input_file, input_file_flag );
rtems_record_client_init( &ctx, handler, &cctx );
while ( true ) {
int buf[ 8192 ];
ssize_t n;
- n = recv( fd, buf, sizeof( buf ), 0 );
- if ( n >= 0 ) {
+ n = ( input_file_flag ) ? read(fd, buf, 10) : recv( fd, buf, sizeof( buf ), 0 );
+ if ( n > 0 ) {
rtems_record_client_run( &ctx, buf, (size_t) n );
} else {
break;
2.7.4
