[PATCH] Record-client program to read from a file for --input=<FILE> flag
Fri Jun 28 18:20:33 UTC 2019
----- Am 28. Jun 2019 um 18:20 schrieb Gedare Bloom gedare at rtems.org:
> On Fri, Jun 28, 2019 at 10:15 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Fri, Jun 28, 2019 at 5:02 AM Ravindra Meena <rmeena840 at gmail.com> wrote:
>> >  misc/record/record-main.c | 35 ++++++++++++++++++++++++-----------
>> >  1 file changed, 24 insertions(+), 11 deletions(-)
>> > diff --git a/misc/record/record-main.c b/misc/record/record-main.c
>> > index b4591e3..14023e2 100644
>> > --- a/misc/record/record-main.c
>> > +++ b/misc/record/record-main.c
>> > @@ -39,6 +39,8 @@
>> >  #include <string.h>
>> >  #include <unistd.h>
>> >  #include <inttypes.h>
>> > +#include<fcntl.h>
>> > +#include<errno.h>
>> add space before <
>> when writing code, aim to be consistent with surrounding code, and
>> with coding style rules
>> >  #include <netinet/in.h>
>> >  #include <arpa/inet.h>
>> > @@ -52,6 +54,7 @@ static const struct option longopts[] = {
>> >    { "host", 1, NULL, 'H' },
>> >    { "port", 1, NULL, 'p' },
>> >    { "items", 1, NULL, 'i' },
>> > +  { "input", 1, NULL, 'f' },
>> I know you were asked to add --input, however, since 'i' is already
>> used, it might be sensible to use --file= and 'f'?
>> >    { NULL, 0, NULL, 0 }
>> > @@ -111,32 +114,35 @@ RB_GENERATE_INTERNAL( active, client_item, active_node,
>> > item_cmp, static inline
>> >  static void usage( char **argv )
>> >    printf(
>> > -    "%s [--host=HOST] [--port=PORT] [--items=ITEMS]\n"
>> > +    "%s [--host=HOST] [--port=PORT] [--items=ITEMS] [--input=INPUT]\n"
>> >      "\n"
>> >      "Mandatory arguments to long options are mandatory for short options too.\n"
>> > -    "  -h, --help                 print this help text\n"
>> > -    "  -H, --host=HOST            the host IPv4 address of the record server\n"
>> > -    "  -p, --port=PORT            the TCP port of the record server\n"
>> > -    "  -i, --items=ITEMS          the maximum count of active record items\n",
>> > +    "  -h,      --help             print this help text\n"
>> > +    "  -H,      --host=HOST        the host IPv4 address of the record
>> > server\n"
>> > +    "  -p,      --port=PORT        the TCP port of the record server\n"
>> > +    "  -i,      --items=ITEMS      the maximum count of active record items\n"
>> Why is this reformatting the existing strings?
>> > +    "  -input,  --input=INPUT      the file input\n",
>> >      argv[ 0 ]
>> > -static int connect_client( const char *host, uint16_t port )
>> > +static int connect_client( const char *host, uint16_t port, const char
>> > *input_file  ,bool input_file_flag )
>> This is > 80 characters.
>> https://devel.rtems.org/wiki/Developer/Coding/Conventions#Formatting
> I guess this is not RTEMS code, so you should refer to your mentor
> what would be the coding standard in use.
It used to be the RTEMS style.
