[PATCH 4/4] dl: Add dynamicly loaded app support.
chrisj at rtems.org chrisj at rtems.org
Sun Jun 30 01:54:16 UTC 2019
 dl.py | 118 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 118 insertions(+)
 create mode 100644 dl.py
diff --git a/dl.py b/dl.py
new file mode 100644
index 0000000..ec5b238
--- /dev/null
+++ b/dl.py
@@ -0,0 +1,118 @@
+# RTEMS Project (https://www.rtems.org/)
+# Copyright (c) 2018 Chris Johns <chrisj at rtems.org>. All rights reserved.
+#  Redistribution and use in source and binary forms, with or without
+#  modification, are permitted provided that the following conditions
+#  are met:
+#  1. Redistributions of source code must retain the above copyright
+#     notice, this list of conditions and the following disclaimer.
+#  2. Redistributions in binary form must reproduce the above copyright
+#     notice, this list of conditions and the following disclaimer in the
+#     documentation and/or other materials provided with the distribution.
+#  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+#  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+#  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+#  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+#  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+#  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+#  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+#  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+#  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+#  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+#  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+import os
+def _syms_rule(tsk):
+    A rule handler so 'no_errcheck_out' can be set. This avoids the
+    erronous duplicate output error from waf (2.0.14 and later).
+    setattr(tsk, 'no_errcheck_out', True)
+    src = tsk.inputs[0].abspath()
+    tgt = tsk.outputs[0].abspath()
+    cmd = '%s -e -C %s -c "%s" -o %s %s' % (' '.join(tsk.env.RTEMS_SYMS),
+                                            ' '.join(tsk.env.CC),
+                                            ' '.join(tsk.env.CFLAGS),
+                                            tgt,
+                                            src)
+    return tsk.exec_command(cmd)
+def syms(ctx, target, source):
+    Create a symbols object file from a base kernel image. The object
+    can be linked to the file executable providing it with a symbol
+    table.
+    The created object file is read and available in a 'use' attribute
+    of the 'cprogram' build.
+    :param ctx: Waf build context
+    :param target: The target object file to create and read
+    :param source: The kernel base image to generate the symbol table of
+    tgt = ctx.path.find_or_declare(target)
+    ctx(rule = _syms_rule,
+        target = tgt,
+        source = source,
+        color = 'CYAN')
+    ctx.read_object(tgt)
+def _strip_rule(tsk):
+    A rule handler so 'no_errcheck_out' can be set. We need this because
+    'ranlib' takes only a single argument, the archive is rewritten so it
+    will appear in 2 outputs.
+    cmd = '%s -d -o %s %s' % (' '.join(tsk.env.STRIP), tgt, src)
+def strip_debug_info(ctx, *k, **kw):
+    Strip the source object file or archive of debug information
+    creating a new archive in the build directory.
+    :param target: The stripped target archive or object file
+    :param source: The source target or acthive file to strip
+    if 'source' not in kw:
+        ctx.fatal('No source in strip')
+    if 'target' not in kw:
+        ctx.fatal('No target in strip')
+    source = kw['source']
+    target = kw['target']
+    if 'name' in kw:
+        name = kw['name']
+    else:
+        if not isinstance(source, str):
+            ctx.fatal('No name and source is not a path')
+        name = 'strip-%s' % (os.path.basename(source))
+    print(type(source), str(source), target)
+    ctx(rule = _strip_rule,
+        name = name,
+        target = target,
+        source = source,
+        color = 'CYAN')
+def _ranlib_rule(tsk):
+    tgt = tsk.inputs[0].abspath()
+    cmd = '%s -t %s' % (' '.join(tsk.env.RANLIB), tgt)
+def ranlib(ctx, lib):
+    ctx(rule = _ranlib_rule,
+        name = 'ranlib-%s' % (lib),
+        source = lib)
2.20.1 (Apple Git-117)
