[PATCH 2/6] TDA19988 : Port to RTEMS
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Jun 30 15:43:23 UTC 2019
On Sun, Jun 30, 2019 at 9:08 PM Christian Mauderer <oss at c-mauderer.de>
wrote:
> On 30/06/2019 17:33, Vijay Kumar Banerjee wrote:
> > The following patchset has only the port commits, the commits to import
> > are pushed to Github and the links are as follows:
> > [PATCH 1/6]
> https://github.com/thelunatic/rtems-libbsd/commit/fa8900b30f5b41611ddc16e5b386a6b8b443675a
> > [PATCH 3/6]
> https://github.com/thelunatic/rtems-libbsd/commit/4f1cde1ef64e4a401cf4acd71bc5e681628fb3ed
> > [PATCH 5/6]
> https://github.com/thelunatic/rtems-libbsd/commit/efe23128b1cf39bdd75040067c95d87c05ae7f00
> Hello Vijay,
> just a side note: Are you aware of the --compose option of git
> send-email? It's thought for adding an introductory message. In RTEMS
> it's quite common to use this to add a short description of the patch
> set and add comments like the one you just added.
> Note that this depends on the community. For example the Linux mailing
> lists suggest to _not_ use introductory messages for most cases.
> Best regards
> Christian
Hi,
Yes, I'm aware, I forgot to add it with this. Thanks for the note, I'll make
sure to add these explanations/comments in the --compose next time. :-)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190630/51adf401/attachment.html>
