[PATCH 6/6] fbd : Port to RTEMS
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Jun 30 19:38:14 UTC 2019
On Mon, Jul 1, 2019 at 12:46 AM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 30/06/2019 19:57, Vijay Kumar Banerjee wrote:
> > On Sun, Jun 30, 2019 at 10:17 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > On 30/06/2019 18:29, Vijay Kumar Banerjee wrote:
> > > > @@ -366,6 +374,9 @@ driver_t fbd_driver = {
> > > > devclass_t fbd_devclass;
> > > > DRIVER_MODULE(fbd, fb, fbd_driver, fbd_devclass, 0, 0);
> > > > +#ifdef __rtems__
> > > > +DRIVER_MODULE(fbd, am335x_lcd, fbd_driver, fbd_devclass, 0,
> 0);
> > > Why is this necessary in this case? I don't see a similar
> > connection in
> > > FreeBSD.
> > > the fbd needs to be linked to the am335x_lcd which provides the
> > fb0 device
> > > and the fbd needs to attach to fb0.
> > It seems that this connection (or a similar one) hasn't been there on
> > FreeBSD. So I wonder why it should be necessary on RTEMS.
> > Note that the situation is a bit different from the one of the i2c
> bus.
> > There your driver implemented a base for a bus system. Therefore the
> > generic bus had been connected to a device specific driver. I'm not
> sure
> > that's the case here.
> > It's quite possible that you just have to link the fbd with a line
> like
> > the following in nexus-devices.h:
> > SYSINIT_MODULE_REFERENCE(fbd);
> > This is not working :
> > fb0: failed to attach fbd device
> > Best regards
> > Christian
> OK. I had a more detailed look: In FreeBSD it's the following connection:
> fbd->fb->fb_mod
> For some devices (like freescale/imx/imx51_ipuv3_fbd.c) a specialized fb
> is connected to simplebus. So one of the following should work and
> should be most likely more correct:
> Either
> SYSINIT_DRIVER_REFERENCE(fbd, fb);
> SYSINIT_DRIVER_REFERENCE(fb, fb_mod);
> SYSINIT_MODULE_REFERENCE(fb_mod);
> This worked!
> or
> SYSINIT_DRIVER_REFERENCE(fb, simplebus);
> For the second one the following line will be necessary in fbd.c
> DRIVER_MODULE(fbd, simplebus, fbd_driver, fbd_devclass, 0, 0);
> Can you try whether one of these two works? It's just odd to connect the
> frame buffer device driver to a specialized device instead of the
> general frame buffer where it is connected in FreeBSD. I would expect
> problems later with the current construction.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190701/59a44afe/attachment-0001.html>
