Problem building RTEMS - readline/undefined reference to tputs
Joel Sherrill
joel at rtems.org
Wed Jun 5 12:38:16 UTC 2019
On Wed, Jun 5, 2019, 7:27 AM John Graham <johngavingraham at googlemail.com>
wrote:
> Hi there,
> I'm trying to build RTEMS to see about starting development work, I took
> the advice to build the tools as per the user manual, and everything goes
> okay until this page:
> https://docs.rtems.org/branches/master/user/start/tools.html
> I've followed the instructions but when I try and actually build the tools
> (i.e. ../source-builder/sb-set-builder --prefix=${RTEMS_PREFIX?}
> 5/rtems-sparc) I get a linker error with lots of undefined references to
> tputs, e.g.:
> gcc -O2 -pipe -I/home/john/src/
> git.rtems.org/rsb/rtems/build/tmp/sb-john/5/rtems-sparc/home/john/src/git.rtems.org/install/include
> -DHAVE_CONFIG_H -DDEFAULT_INLINE=0 -DFAST_UART
> -I../../../gdb-8.2.1/sim/sis/../.. `echo -Dsparc-rtems5 | sed s/-rtems.//`
> -I. -I../../../gdb-8.2.1/sim/sis -I../common
> -I../../../gdb-8.2.1/sim/sis/../common -I../../include
> -I../../../gdb-8.2.1/sim/sis/../../include -I../../bfd
> -I../../../gdb-8.2.1/sim/sis/../../bfd -I../../opcodes
> -I../../../gdb-8.2.1/sim/sis/../../opcodes -g -O2 -static-libstdc++
> -static-libgcc -L/home/john/src/
> git.rtems.org/rsb/rtems/build/tmp/sb-john/5/rtems-sparc/home/john/src/git.rtems.org/install/lib
> -o run \
> run.o libsim.a ../../bfd/libbfd.a ../../opcodes/libopcodes.a
> ../../libiberty/libiberty.a -ldl -lnsl -L../../zlib -lz
> ../../readline/libreadline.a -lm
> /usr/bin/ld: ../../readline/libreadline.a(display.o): in function
> `_rl_move_cursor_relative':
> /home/john/src/
> git.rtems.org/rsb/rtems/build/sparc-rtems5-gdb-8.2.1-x86_64-linux-gnu-1/build/readline/../../gdb-8.2.1/readline/display.c:1985:
> undefined reference to `tputs'
> I'm not sure how to go about solving this in the context of the RTEMS
> build system. This thread (
> https://github.com/monero-project/monero/issues/2919) seems to suggest I
> just need to link in termcap wherever readline is, though I can't find
> where that's done.
That symbol comes from the ncurses package. So you will need to build it
also.
I think there are RSB recipes for both these. Or at least I remember
working on them. Hopefully I finished successfully.
> I'm coming back to this sort of development after a long break, so may
> have missed something obvious! I'm using a fresh Ubuntu 19.04 system,
> nothing installed except emacs and what the RTEMS user guide says.
> Thanks for any help,
> John
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190605/281ffa5d/attachment-0002.html>
