Problem building RTEMS - readline/undefined reference to tputs
John Graham
johngavingraham at googlemail.com
Wed Jun 5 13:07:47 UTC 2019
I'm on Ubuntu 19.04, assumed that would be fine as I saw Ubuntu marked as
supported elsewhere, however in your link I see 18.04 LTS is specifically
mentioned so I may try that if I can't get this to work.
John
On Wed, 5 Jun 2019, 13:45 Sebastian Huber, <
> On 05/06/2019 14:27, John Graham wrote:
> > I'm trying to build RTEMS to see about starting development work, I
> > took the advice to build the tools as per the user manual, and
> > everything goes okay until this page:
> > https://docs.rtems.org/branches/master/user/start/tools.html
> > I've followed the instructions but when I try and actually build the
> > tools (i.e. ../source-builder/sb-set-builder --prefix=${RTEMS_PREFIX?}
> > 5/rtems-sparc) I get a linker error with lots of undefined references
> > to tputs, e.g.:
> Which host operating system do you have? Maybe it is on this list:
> https://docs.rtems.org/branches/master/user/hosts/index.html#host-computer
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190605/481046e7/attachment-0002.html>
