[PATCH] Port ndbm
Vaibhav Gupta vaibhavgupta40 at gmail.com
Fri Jun 7 19:35:48 UTC 2019
Okay! So first let me check what files are updated till now.
On Sat, 8 Jun, 2019, 1:00 AM Gedare Bloom, <gedare at rtems.org> wrote:
> I wouldn't send the patch, I would suggest you write an email to
> discuss about how you are porting ndbm, and that the current version
> relies on the search/hash functions, and that the interface has
> changed a bit over time so inquire whether you should update
> hash/search functions to newer versions.  This should reduce the
> number of changes you have to make to the ndbm files to get them to
> work.
> On Fri, Jun 7, 2019 at 11:24 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Sure! I will send the patch to newlib and ask them if they need updated
> set of files inside libc/search.
> > On Fri, 7 Jun, 2019, 10:29 PM Gedare Bloom, <gedare at rtems.org> wrote:
> >> On Thu, Jun 6, 2019 at 8:02 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> > Please review the code so that I can send it to newlib-devel.
> >> > On Fri, Jun 7, 2019 at 7:22 AM Vaibhav Gupta <
> vaibhavgupta40 at gmail.com> wrote:
> >> >>  newlib/libc/include/ndbm.h    |  86 ++++++++++++++
> >> >>  newlib/libc/posix/Makefile.am |   4 +-
> >> >>  newlib/libc/posix/ndbm.c      | 214
> >> >>  3 files changed, 302 insertions(+), 2 deletions(-)
> >> >>  create mode 100644 newlib/libc/include/ndbm.h
> >> >>  create mode 100644 newlib/libc/posix/ndbm.c
> >> >> diff --git a/newlib/libc/include/ndbm.h b/newlib/libc/include/ndbm.h
> >> >> new file mode 100644
> >> >> index 000000000..1fd5e5198
> >> >> --- /dev/null
> >> >> +++ b/newlib/libc/include/ndbm.h
> >> >> @@ -0,0 +1,86 @@
> >> >> + * SPDX-License-Identifier: BSD-3-Clause
> >> >> + * Copyright (c) 1990, 1993
> >> >> + *     The Regents of the University of California.  All rights
> reserved.
> >> >> + * This code is derived from software contributed to Berkeley by
> >> >> + * Margo Seltzer.
> >> >> + * Redistribution and use in source and binary forms, with or
> without
> >> >> + * modification, are permitted provided that the following
> conditions
> >> >> + * are met:
> >> >> + * 1. Redistributions of source code must retain the above copyright
> >> >> + *    notice, this list of conditions and the following disclaimer.
> >> >> + * 2. Redistributions in binary form must reproduce the above
> copyright
> in the
> >> >> + *    documentation and/or other materials provided with the
> distribution.
> >> >> + * 3. Neither the name of the University nor the names of its
> contributors
> >> >> + *    may be used to endorse or promote products derived from this
> software
> >> >> + *    without specific prior written permission.
> >> >> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS
> IS'' AND
> >> >> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> >> >> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> >> >> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS
> BE LIABLE
> >> >> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> >> >> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> SUBSTITUTE GOODS
> >> >> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> INTERRUPTION)
> >> >> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> CONTRACT, STRICT
> >> >> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
> IN ANY WAY
> >> >> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> POSSIBILITY OF
> >> >> + * SUCH DAMAGE.
> >> >> + *     @(#)ndbm.h      8.1 (Berkeley) 6/2/93
> >> >> + * $FreeBSD$
> >> >> +#ifndef _NDBM_H_
> >> >> +#define        _NDBM_H_
> >> >> +#ifndef __DBINTERFACE_PRIVATE
> >> >> +#define __DBINTERFACE_PRIVATE
> >> >> +#endif
> >> > Included the above lines in ndbm.h, since     __hash_open     was
> under conditional compilation in db_local.h . Line 211 (
> https://github.com/VARoDeK/newlib/blob/master/newlib/libc/search/db_local.h
> >> >> +#include <db_local.h>
> >> >> +/* Map dbm interface onto db(3). */
> >> >> +#define DBM_RDONLY     O_RDONLY
> >> >> +/* Flags to dbm_store(). */
> >> >> +#define DBM_INSERT      0
> >> >> +#define DBM_REPLACE     1
> >> >> + * The db(3) support for ndbm always appends this suffix to the
> >> >> + * file name to avoid overwriting the user's original database.
> >> >> +#define        DBM_SUFFIX      ".db"
> >> >> +typedef struct {
> >> >> +       void *dptr;
> >> >> +       int dsize;      /* XXX Should be size_t according to
> 1003.1-2008. */
> >> >> +} datum;
> >> >> +typedef DB DBM;
> >> >> +#define        dbm_pagfno(a)   DBM_PAGFNO_NOT_AVAILABLE
> >> >> +__BEGIN_DECLS
> >> >> +int     dbm_clearerr(DBM *);
> >> >> +void    dbm_close(DBM *);
> >> >> +int     dbm_delete(DBM *, datum);
> >> >> +int     dbm_error(DBM *);
> >> >> +datum   dbm_fetch(DBM *, datum);
> >> >> +datum   dbm_firstkey(DBM *);
> >> >> +#if __BSD_VISIBLE
> >> >> +long    dbm_forder(DBM *, datum);
> >> >> +#endif
> >> >> +datum   dbm_nextkey(DBM *);
> >> >> +DBM    *dbm_open(const char *, int, mode_t);
> >> >> +int     dbm_store(DBM *, datum, datum, int);
> >> >> +#if __BSD_VISIBLE
> >> >> +int     dbm_dirfno(DBM *);
> >> >> +#endif
> >> >> +__END_DECLS
> >> >> +#endif /* !_NDBM_H_ */
> >> >> diff --git a/newlib/libc/posix/Makefile.am
> b/newlib/libc/posix/Makefile.am
> >> >> index 6cdee1df0..01334c7fa 100644
> >> >> --- a/newlib/libc/posix/Makefile.am
> >> >> +++ b/newlib/libc/posix/Makefile.am
> >> >> @@ -2,12 +2,12 @@
> >> >>  AUTOMAKE_OPTIONS = cygnus
> >> >> -INCLUDES = $(NEWLIB_CFLAGS) $(CROSS_CFLAGS) $(TARGET_CFLAGS)
> >> >> +INCLUDES = -I$(srcdir)/../search $(NEWLIB_CFLAGS) $(CROSS_CFLAGS)
> $(TARGET_CFLAGS)
> >> >>  GENERAL_SOURCES = \
> >> >>         closedir.c collate.c collcmp.c creat.c dirfd.c \
> >> >>         fnmatch.c glob.c _isatty.c isatty.c \
> >> >> -       opendir.c readdir.c readdir_r.c \
> >> >> +       ndbm.c opendir.c readdir.c readdir_r.c \
> >> >>         regcomp.c regerror.c regexec.c regfree.c \
> >> >>         rewinddir.c sleep.c usleep.c \
> >> >>         telldir.c
> >> >> diff --git a/newlib/libc/posix/ndbm.c b/newlib/libc/posix/ndbm.c
> >> >> index 000000000..63e54df37
> >> >> --- /dev/null
> >> >> +++ b/newlib/libc/posix/ndbm.c
> >> >> @@ -0,0 +1,214 @@
> reserved.
> >> >> + * Margo Seltzer.
> without
> conditions
> >> >> + * are met:
> copyright
> in the
> distribution.
> contributors
> software
> IS'' AND
> TO, THE
> PARTICULAR PURPOSE
> BE LIABLE
> CONSEQUENTIAL
> SUBSTITUTE GOODS
> INTERRUPTION)
> CONTRACT, STRICT
> IN ANY WAY
> POSSIBILITY OF
> >> >> + * SUCH DAMAGE.
> >> >> +#if defined(LIBC_SCCS) && !defined(lint)
> >> >> +static char sccsid[] = "@(#)ndbm.c     8.4 (Berkeley) 7/21/94";
> >> >> +#endif /* LIBC_SCCS and not lint */
> >> >> +#include <sys/cdefs.h>
> >> >> +__FBSDID("$FreeBSD$");
> >> >> + * This package provides a dbm compatible interface to the new
> hashing
> >> >> + * package described in db(3).
> >> >> +#include <sys/param.h>
> >> >> +#include <stdio.h>
> >> >> +#include <string.h>
> >> >> +#include <errno.h>
> >> >> +#include <ndbm.h>
> >> >> +#include <hash.h>
> >> >> + * Returns:
> >> >> + *     *DBM on success
> >> >> + *      NULL on failure
> >> >> +extern DBM *
> >> >> +dbm_open(const char *file, int flags, mode_t mode)
> >> >> +       HASHINFO info;
> >> >> +       char path[MAXPATHLEN];
> >> >> +       info.bsize = 4096;
> >> >> +       info.ffactor = 40;
> >> >> +       info.nelem = 1;
> >> >> +       info.cachesize = 0;
> >> >> +       info.hash = NULL;
> >> >> +       info.lorder = 0;
> >> >> +       if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
> >> >> +               errno = ENAMETOOLONG;
> >> >> +               return(NULL);
> >> >> +       (void)strcpy(path, file);
> >> >> +       (void)strcat(path, DBM_SUFFIX);
> >> >> +       return ((DBM *)__hash_open(path, flags, mode, 0, &info));
> >> > In ndbm.c,
> >> > The original code was:  return ((DBM *)__hash_open(path, flags, mode,
> &info, 0));
> >> > But the declaration of this function in db_local.h is:
> __hash_open(const char *, int, int, int, const HASHINFO *);
> >> >  hence changed the original code to: return ((DBM *)__hash_open(path,
> >> Should db_local.h be updated? how about hash.h? Maybe, the entire
> >> search.h should be updated to newer FreeBSD sources?  This is probably
> >> something to discuss at newlib ML...
> >> >> +extern void
> >> >> +dbm_close(DBM *db)
> >> >> +       (void)(db->close)(db);
> >> >> + * Returns:
> >> >> + *     DATUM on success
> >> >> + *     NULL on failure
> >> >> +extern datum
> >> >> +dbm_fetch(DBM *db, datum key)
> >> >> +       datum retdata;
> >> >> +       int status;
> >> >> +       DBT dbtkey, dbtretdata;
> >> >> +       dbtkey.data = key.dptr;
> >> >> +       dbtkey.size = key.dsize;
> >> >> +       status = (db->get)(db, &dbtkey, &dbtretdata, 0);
> >> >> +       if (status) {
> >> >> +               dbtretdata.data = NULL;
> >> >> +               dbtretdata.size = 0;
> >> >> +       retdata.dptr = dbtretdata.data;
> >> >> +       retdata.dsize = dbtretdata.size;
> >> >> +       return (retdata);
> >> >> + * Returns:
> >> >> + *     NULL on failure
> >> >> +extern datum
> >> >> +dbm_firstkey(DBM *db)
> >> >> +       int status;
> >> >> +       datum retkey;
> >> >> +       DBT dbtretkey, dbtretdata;
> >> >> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
> >> >> +       if (status)
> >> >> +               dbtretkey.data = NULL;
> >> >> +       retkey.dptr = dbtretkey.data;
> >> >> +       retkey.dsize = dbtretkey.size;
> >> >> +       return (retkey);
> >> >> + * Returns:
> >> >> + *     NULL on failure
> >> >> +extern datum
> >> >> +dbm_nextkey(DBM *db)
> >> >> +       int status;
> >> >> +       datum retkey;
> >> >> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
> >> >> +       if (status)
> >> >> +       return (retkey);
> >> >> + * Returns:
> >> >> + *      0 on success
> >> >> + *     <0 failure
> >> >> +extern int
> >> >> +dbm_delete(DBM *db, datum key)
> >> >> +       int status;
> >> >> +       DBT dbtkey;
> >> >> +       status = (db->del)(db, &dbtkey, 0);
> >> >> +       if (status)
> >> >> +               return (-1);
> >> >> +       else
> >> >> +               return (0);
> >> >> + * Returns:
> >> >> + *      0 on success
> >> >> + *     <0 failure
> >> >> + *      1 if DBM_INSERT and entry exists
> >> >> +extern int
> >> >> +dbm_store(DBM *db, datum key, datum data, int flags)
> >> >> +       DBT dbtkey, dbtdata;
> >> >> +       dbtdata.data = data.dptr;
> >> >> +       dbtdata.size = data.dsize;
> >> >> +       return ((db->put)(db, &dbtkey, &dbtdata,
> >> >> +           (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
> >> >> +extern int
> >> >> +dbm_error(DBM *db)
> >> >> +       HTAB *hp;
> >> >> +       hp = (HTAB *)db->internal;
> >> >> +       return (hp->error);
> >> >> +extern int
> >> >> +dbm_clearerr(DBM *db)
> >> >> +       HTAB *hp;
> >> >> +       hp->error = 0;
> >> >> +       return (0);
> >> >> +extern int
> >> >> +dbm_dirfno(DBM *db)
> >> >> +       return(((HTAB *)db->internal)->fp);
> >> >> 2.21.0
> >> > _______________________________________________
> >> > devel mailing list
> >> > devel at rtems.org
> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190608/0c6ac982/attachment-0002.html>
