[PATCH v2 1/5] iicbus: Import from FreeBSD
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Mon Jun 10 12:42:41 UTC 2019
On Mon, Jun 10, 2019, 6:06 PM Christian Mauderer <list at c-mauderer.de> wrote:
> Hello Vijay,
> the patch set works fine on the Beagle (except for the i2c tool - but as
> discussed that will work after the next libbsd update). The patches look
> OK for me.
> Best regards
> Christian
Hi!
Thanks for reviewing the patches.
Currently the i2c tool can't do the read/write operation, but I checked
that `i2c -s` function can scan the bus.
Thanks,
Vijay
> On 08/06/2019 14:49, Vijay Kumar Banerjee wrote:
> >  freebsd/sys/dev/iicbus/iic.c        | 506 ++++++++++++++++++++++++++
> >  freebsd/sys/dev/iicbus/iic.h        |  72 ++++
> >  freebsd/sys/dev/iicbus/iicbus.c     | 378 ++++++++++++++++++++
> >  freebsd/sys/dev/iicbus/iicbus.h     |  83 +++++
> >  freebsd/sys/dev/iicbus/iiconf.c     | 527 ++++++++++++++++++++++++++++
> >  freebsd/sys/dev/iicbus/iiconf.h     | 162 +++++++++
> >  freebsd/sys/dev/iicbus/ofw_iicbus.c | 242 +++++++++++++
> >  7 files changed, 1970 insertions(+)
> >  create mode 100644 freebsd/sys/dev/iicbus/iic.c
> >  create mode 100644 freebsd/sys/dev/iicbus/iic.h
> >  create mode 100644 freebsd/sys/dev/iicbus/iicbus.c
> >  create mode 100644 freebsd/sys/dev/iicbus/iicbus.h
> >  create mode 100644 freebsd/sys/dev/iicbus/iiconf.c
> >  create mode 100644 freebsd/sys/dev/iicbus/iiconf.h
> >  create mode 100644 freebsd/sys/dev/iicbus/ofw_iicbus.c
> > diff --git a/freebsd/sys/dev/iicbus/iic.c b/freebsd/sys/dev/iicbus/iic.c
> > new file mode 100644
> > index 00000000..dc9c06f9
> > --- /dev/null
> > +++ b/freebsd/sys/dev/iicbus/iic.c
> > @@ -0,0 +1,506 @@
> > +#include <machine/rtems-bsd-kernel-space.h>
> > + * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
> > + * Copyright (c) 1998, 2001 Nicolas Souchu
> > + * All rights reserved.
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS''
> AND
> > + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
> LIABLE
> > + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> CONSEQUENTIAL
> > + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
> GOODS
> > + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
> > + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
> STRICT
> > + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
> ANY WAY
> > + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
> OF
> > + * SUCH DAMAGE.
> > + * $FreeBSD$
> > +#include <sys/param.h>
> > +#include <sys/bus.h>
> > +#include <sys/conf.h>
> > +#include <sys/fcntl.h>
> > +#include <sys/lock.h>
> > +#include <sys/kernel.h>
> > +#include <sys/malloc.h>
> > +#include <sys/module.h>
> > +#include <sys/sx.h>
> > +#include <sys/systm.h>
> > +#include <sys/uio.h>
> > +#include <sys/errno.h>
> > +#include <dev/iicbus/iiconf.h>
> > +#include <dev/iicbus/iicbus.h>
> > +#include <dev/iicbus/iic.h>
> > +#include <rtems/bsd/local/iicbus_if.h>
> > +struct iic_softc {
> > +     device_t sc_dev;
> > +     struct cdev *sc_devnode;
> > +struct iic_cdevpriv {
> > +     struct sx lock;
> > +     struct iic_softc *sc;
> > +     bool started;
> > +     uint8_t addr;
> > +#define      IIC_LOCK(cdp)                   sx_xlock(&(cdp)->lock)
> > +#define      IIC_UNLOCK(cdp)                 sx_xunlock(&(cdp)->lock)
> > +static MALLOC_DEFINE(M_IIC, "iic", "I2C device data");
> > +static int iic_probe(device_t);
> > +static int iic_attach(device_t);
> > +static int iic_detach(device_t);
> > +static void iic_identify(driver_t *driver, device_t parent);
> > +static void iicdtor(void *data);
> > +static int iicuio_move(struct iic_cdevpriv *priv, struct uio *uio, int
> last);
> > +static int iicuio(struct cdev *dev, struct uio *uio, int ioflag);
> > +static int iicrdwr(struct iic_cdevpriv *priv, struct iic_rdwr_data *d,
> int flags);
> > +static devclass_t iic_devclass;
> > +static device_method_t iic_methods[] = {
> > +     /* device interface */
> > +     DEVMETHOD(device_identify,      iic_identify),
> > +     DEVMETHOD(device_probe,         iic_probe),
> > +     DEVMETHOD(device_attach,        iic_attach),
> > +     DEVMETHOD(device_detach,        iic_detach),
> > +     /* iicbus interface */
> > +     DEVMETHOD(iicbus_intr,          iicbus_generic_intr),
> > +     { 0, 0 }
> > +static driver_t iic_driver = {
> > +     "iic",
> > +     iic_methods,
> > +     sizeof(struct iic_softc),
> > +static       d_open_t        iicopen;
> > +static       d_ioctl_t       iicioctl;
> > +static struct cdevsw iic_cdevsw = {
> > +     .d_version =    D_VERSION,
> > +     .d_open =       iicopen,
> > +     .d_read =       iicuio,
> > +     .d_write =      iicuio,
> > +     .d_ioctl =      iicioctl,
> > +     .d_name =       "iic",
> > +static void
> > +iic_identify(driver_t *driver, device_t parent)
> > +     if (device_find_child(parent, "iic", -1) == NULL)
> > +             BUS_ADD_CHILD(parent, 0, "iic", -1);
> > +static int
> > +iic_probe(device_t dev)
> > +     if (iicbus_get_addr(dev) > 0)
> > +             return (ENXIO);
> > +     device_set_desc(dev, "I2C generic I/O");
> > +     return (0);
> > +static int
> > +iic_attach(device_t dev)
> > +     sc = device_get_softc(dev);
> > +     sc->sc_dev = dev;
> > +     sc->sc_devnode = make_dev(&iic_cdevsw, device_get_unit(dev),
> > +                     UID_ROOT, GID_WHEEL,
> > +                     0600, "iic%d", device_get_unit(dev));
> > +     if (sc->sc_devnode == NULL) {
> > +             device_printf(dev, "failed to create character device\n");
> > +             return (ENXIO);
> > +     sc->sc_devnode->si_drv1 = sc;
> > +     return (0);
> > +static int
> > +iic_detach(device_t dev)
> > +     if (sc->sc_devnode)
> > +             destroy_dev(sc->sc_devnode);
> > +     return (0);
> > +static int
> > +iicopen(struct cdev *dev, int flags, int fmt, struct thread *td)
> > +     struct iic_cdevpriv *priv;
> > +     int error;
> > +     priv = malloc(sizeof(*priv), M_IIC, M_WAITOK | M_ZERO);
> > +     sx_init(&priv->lock, "iic");
> > +     priv->sc = dev->si_drv1;
> > +     error = devfs_set_cdevpriv(priv, iicdtor);
> > +     if (error != 0)
> > +             free(priv, M_IIC);
> > +     return (error);
> > +static void
> > +iicdtor(void *data)
> > +     device_t iicdev, parent;
> > +     priv = data;
> > +     KASSERT(priv != NULL, ("iic cdevpriv should not be NULL!"));
> > +     iicdev = priv->sc->sc_dev;
> > +     parent = device_get_parent(iicdev);
> > +     if (priv->started) {
> > +             iicbus_stop(parent);
> > +             iicbus_reset(parent, IIC_UNKNOWN, 0, NULL);
> > +             iicbus_release_bus(parent, iicdev);
> > +     sx_destroy(&priv->lock);
> > +static int
> > +iicuio_move(struct iic_cdevpriv *priv, struct uio *uio, int last)
> > +     device_t parent;
> > +     int error, num_bytes, transferred_bytes, written_bytes;
> > +     char buffer[128];
> > +     parent = device_get_parent(priv->sc->sc_dev);
> > +     error = 0;
> > +      * We can only transfer up to sizeof(buffer) bytes in 1 shot, so
> loop until
> > +      * everything has been transferred.
> > +     while ((error == 0) && (uio->uio_resid > 0)) {
> > +             num_bytes = MIN(uio->uio_resid, sizeof(buffer));
> > +             transferred_bytes = 0;
> > +             if (uio->uio_rw == UIO_WRITE) {
> > +                     error = uiomove(buffer, num_bytes, uio);
> > +                     while ((error == 0) && (transferred_bytes <
> num_bytes)) {
> > +                             written_bytes = 0;
> > +                             error = iicbus_write(parent,
> &buffer[transferred_bytes],
> > +                                 num_bytes - transferred_bytes,
> &written_bytes, 0);
> > +                             transferred_bytes += written_bytes;
> > +             } else if (uio->uio_rw == UIO_READ) {
> > +                     error = iicbus_read(parent, buffer,
> > +                         num_bytes, &transferred_bytes,
> > +                         ((uio->uio_resid <= sizeof(buffer)) ? last :
> 0), 0);
> > +                     if (error == 0)
> > +                             error = uiomove(buffer, transferred_bytes,
> uio);
> > +     return (error);
> > +static int
> > +iicuio(struct cdev *dev, struct uio *uio, int ioflag)
> > +     device_t parent;
> > +     int error;
> > +     uint8_t addr;
> > +     priv = NULL;
> > +     error = devfs_get_cdevpriv((void**)&priv);
> > +     if (error != 0)
> > +             return (error);
> > +     IIC_LOCK(priv);
> > +     if (priv->started || (priv->addr == 0)) {
> > +             IIC_UNLOCK(priv);
> > +             return (ENXIO);
> > +     error = iicbus_request_bus(parent, priv->sc->sc_dev,
> > +         (ioflag & O_NONBLOCK) ? IIC_DONTWAIT : (IIC_WAIT | IIC_INTR));
> > +     if (error != 0) {
> > +             IIC_UNLOCK(priv);
> > +             return (error);
> > +     if (uio->uio_rw == UIO_READ)
> > +             addr = priv->addr | LSB;
> > +     else
> > +             addr = priv->addr & ~LSB;
> > +     error = iicbus_start(parent, addr, 0);
> > +     if (error != 0)
> > +             iicbus_release_bus(parent, priv->sc->sc_dev);
> > +             IIC_UNLOCK(priv);
> > +             return (error);
> > +     error = iicuio_move(priv, uio, IIC_LAST_READ);
> > +     IIC_UNLOCK(priv);
> > +     return (error);
> > +static int
> > +iicrdwr(struct iic_cdevpriv *priv, struct iic_rdwr_data *d, int flags)
> > +     struct iic_msg *buf, *m;
> > +     void **usrbufs;
> > +     int error;
> > +     uint32_t i;
> > +     error = 0;
> > +     if (d->nmsgs > IIC_RDRW_MAX_MSGS)
> > +             return (EINVAL);
> > +     buf = malloc(sizeof(*d->msgs) * d->nmsgs, M_IIC, M_WAITOK);
> > +     error = copyin(d->msgs, buf, sizeof(*d->msgs) * d->nmsgs);
> > +     if (error != 0) {
> > +             free(buf, M_IIC);
> > +             return (error);
> > +     /* Alloc kernel buffers for userland data, copyin write data */
> > +     usrbufs = malloc(sizeof(void *) * d->nmsgs, M_IIC, M_WAITOK |
> M_ZERO);
> > +     for (i = 0; i < d->nmsgs; i++) {
> > +             m = &(buf[i]);
> > +             usrbufs[i] = m->buf;
> > +              * At least init the buffer to NULL so we can safely
> free() it later.
> > +              * If the copyin() to buf failed, don't try to malloc
> bogus m->len.
> > +             m->buf = NULL;
> > +             if (error != 0)
> > +                     continue;
> > +             /* m->len is uint16_t, so allocation size is capped at
> 64K. */
> > +             m->buf = malloc(m->len, M_IIC, M_WAITOK);
> > +             if (!(m->flags & IIC_M_RD))
> > +                     error = copyin(usrbufs[i], m->buf, m->len);
> > +     if (error == 0)
> > +             error = iicbus_request_bus(parent, iicdev,
> > +                 (flags & O_NONBLOCK) ? IIC_DONTWAIT : (IIC_WAIT |
> IIC_INTR));
> > +     if (error == 0) {
> > +             error = iicbus_transfer(iicdev, buf, d->nmsgs);
> > +     /* Copyout all read segments, free up kernel buffers */
> > +             m = &(buf[i]);
> > +             if ((error == 0) && (m->flags & IIC_M_RD))
> > +                     error = copyout(m->buf, usrbufs[i], m->len);
> > +             free(m->buf, M_IIC);
> > +     free(usrbufs, M_IIC);
> > +     free(buf, M_IIC);
> > +     return (error);
> > +static int
> > +iicioctl(struct cdev *dev, u_long cmd, caddr_t data, int flags, struct
> thread *td)
> > +     device_t parent, iicdev;
> > +     struct iiccmd *s;
> > +     struct uio ubuf;
> > +     struct iovec uvec;
> > +     int error;
> > +     s = (struct iiccmd *)data;
> > +     if (error != 0)
> > +             return (error);
> > +     IIC_LOCK(priv);
> > +     switch (cmd) {
> > +     case I2CSTART:
> > +                     error = EINVAL;
> > +                     break;
> IIC_INTR));
> > +             if (error == 0)
> > +                     error = iicbus_start(parent, s->slave, 0);
> > +             if (error == 0) {
> > +                     priv->addr = s->slave;
> > +                     priv->started = true;
> > +             } else
> > +             break;
> > +     case I2CSTOP:
> > +                     error = iicbus_stop(parent);
> > +                     priv->started = false;
> > +             break;
> > +     case I2CRSTCARD:
> > +              * Bus should be owned before we reset it.
> > +              * We allow the bus to be already owned as the result of
> an in-progress
> > +              * sequence; however, bus reset will always be followed by
> release
> > +              * (a new start is presumably needed for I/O anyway). */
> > +             if (!priv->started)
> > +             if (error == 0) {
> > +                     error = iicbus_reset(parent, IIC_UNKNOWN, 0, NULL);
> > +                      * Ignore IIC_ENOADDR as it only means we have a
> master-only
> > +                      * controller.
> > +                     if (error == IIC_ENOADDR)
> > +                             error = 0;
> > +             break;
> > +     case I2CWRITE:
> > +             if (!priv->started) {
> > +                     error = EINVAL;
> > +                     break;
> > +             uvec.iov_base = s->buf;
> > +             uvec.iov_len = s->count;
> > +             ubuf.uio_iov = &uvec;
> > +             ubuf.uio_iovcnt = 1;
> > +             ubuf.uio_segflg = UIO_USERSPACE;
> > +             ubuf.uio_td = td;
> > +             ubuf.uio_resid = s->count;
> > +             ubuf.uio_offset = 0;
> > +             ubuf.uio_rw = UIO_WRITE;
> > +             error = iicuio_move(priv, &ubuf, 0);
> > +             break;
> > +     case I2CREAD:
> > +                     error = EINVAL;
> > +                     break;
> > +             ubuf.uio_td = td;
> > +             ubuf.uio_rw = UIO_READ;
> > +             error = iicuio_move(priv, &ubuf, s->last);
> > +             break;
> > +     case I2CRDWR:
> > +              * The rdwr list should be a self-contained set of
> > +              * transactions.  Fail if another transaction is in
> progress.
> > +                     error = EINVAL;
> > +                     break;
> > +             error = iicrdwr(priv, (struct iic_rdwr_data *)data, flags);
> > +             break;
> > +     case I2CRPTSTART:
> > +                     error = EINVAL;
> > +                     break;
> > +             error = iicbus_repeated_start(parent, s->slave, 0);
> > +             break;
> > +     case I2CSADDR:
> > +             priv->addr = *((uint8_t*)data);
> > +             break;
> > +     default:
> > +             error = ENOTTY;
> > +     IIC_UNLOCK(priv);
> > +     return (error);
> > +DRIVER_MODULE(iic, iicbus, iic_driver, iic_devclass, 0, 0);
> > +MODULE_DEPEND(iic, iicbus, IICBUS_MINVER, IICBUS_PREFVER,
> IICBUS_MAXVER);
> > +MODULE_VERSION(iic, 1);
> > diff --git a/freebsd/sys/dev/iicbus/iic.h b/freebsd/sys/dev/iicbus/iic.h
> > index 00000000..5ebf56a9
> > --- /dev/null
> > +++ b/freebsd/sys/dev/iicbus/iic.h
> > @@ -0,0 +1,72 @@
> > + * Copyright (c) 1998 Nicolas Souchu
> > + * are met:
> the
> distribution.
> AND
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> STRICT
> ANY WAY
> OF
> > + * SUCH DAMAGE.
> > + * $FreeBSD$
> > +#ifndef __IIC_H
> > +#define __IIC_H
> > +#include <sys/ioccom.h>
> > +/* Designed to be compatible with linux's struct i2c_msg */
> > +struct iic_msg
> > +     uint16_t        slave;
> > +     uint16_t        flags;
> > +#define      IIC_M_WR        0       /* Fake flag for write */
> > +#define      IIC_M_RD        0x0001  /* read vs write */
> > +#define      IIC_M_NOSTOP    0x0002  /* do not send a I2C stop after
> message */
> > +#define      IIC_M_NOSTART   0x0004  /* do not send a I2C start before
> message */
> > +     uint16_t        len;    /* msg length */
> > +     uint8_t *       buf;
> > +struct iiccmd {
> > +     u_char slave;
> > +     int count;
> > +     int last;
> > +     char *buf;
> > +struct iic_rdwr_data {
> > +     struct iic_msg *msgs;
> > +     uint32_t nmsgs;
> > +#define IIC_RDRW_MAX_MSGS    42
> > +#define I2CSTART     _IOW('i', 1, struct iiccmd)     /* start condition
> > +#define I2CSTOP              _IO('i', 2)                     /* stop
> condition */
> > +#define I2CRSTCARD   _IOW('i', 3, struct iiccmd)     /* reset the card
> > +#define I2CWRITE     _IOW('i', 4, struct iiccmd)     /* send data */
> > +#define I2CREAD              _IOW('i', 5, struct iiccmd)     /* receive
> data */
> > +#define I2CRDWR              _IOW('i', 6, struct iic_rdwr_data)      /*
> General read/write interface */
> > +#define I2CRPTSTART  _IOW('i', 7, struct iiccmd)     /* repeated start
> > +#define I2CSADDR     _IOW('i', 8, uint8_t)           /* set slave
> address for future I/O */
> > +#endif
> > diff --git a/freebsd/sys/dev/iicbus/iicbus.c
> b/freebsd/sys/dev/iicbus/iicbus.c
> > index 00000000..d1e55483
> > --- /dev/null
> > +++ b/freebsd/sys/dev/iicbus/iicbus.c
> > @@ -0,0 +1,378 @@
> > + * are met:
> the
> distribution.
> AND
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> STRICT
> ANY WAY
> OF
> > + * SUCH DAMAGE.
> > +#include <sys/cdefs.h>
> > +__FBSDID("$FreeBSD$");
> > + * Autoconfiguration and support routines for the Philips serial I2C bus
> > +#include <sys/mutex.h>
> > +#include <sys/rman.h>
> > +#include <sys/sysctl.h>
> > +/* See comments below for why auto-scanning is a bad idea. */
> > +#define SCAN_IICBUS 0
> > +static int
> > +iicbus_probe(device_t dev)
> > +     device_set_desc(dev, "Philips I2C bus");
> > +     /* Allow other subclasses to override this driver. */
> > +     return (BUS_PROBE_GENERIC);
> > +#if SCAN_IICBUS
> > +static int
> > +iic_probe_device(device_t dev, u_char addr)
> > +     int count;
> > +     char byte;
> > +     if ((addr & 1) == 0) {
> > +             /* is device writable? */
> > +             if (!iicbus_start(dev, (u_char)addr, 0)) {
> > +                     iicbus_stop(dev);
> > +                     return (1);
> > +     } else {
> > +             /* is device readable? */
> > +             if (!iicbus_block_read(dev, (u_char)addr, &byte, 1,
> &count))
> > +                     return (1);
> > +     return (0);
> > +#endif
> > + * We add all the devices which we know about.
> > + * The generic attach routine will attach them if they are alive.
> > +static int
> > +iicbus_attach(device_t dev)
> > +#if SCAN_IICBUS
> > +     unsigned char addr;
> > +#endif
> > +     struct iicbus_softc *sc = IICBUS_SOFTC(dev);
> > +     int strict;
> > +     sc->dev = dev;
> > +     mtx_init(&sc->lock, "iicbus", NULL, MTX_DEF);
> > +     iicbus_init_frequency(dev, 0);
> > +     iicbus_reset(dev, IIC_FASTEST, 0, NULL);
> > +     if (resource_int_value(device_get_name(dev),
> > +             device_get_unit(dev), "strict", &strict) == 0)
> > +             sc->strict = strict;
> > +     else
> > +             sc->strict = 1;
> > +     /* device probing is meaningless since the bus is supposed to be
> > +      * hot-plug. Moreover, some I2C chips do not appreciate random
> > +      * accesses like stop after start to fast, reads for less than
> > +      * x bytes...
> > +#if SCAN_IICBUS
> > +     printf("Probing for devices on iicbus%d:", device_get_unit(dev));
> > +     /* probe any devices */
> > +     for (addr = 16; addr < 240; addr++) {
> > +             if (iic_probe_device(dev, (u_char)addr)) {
> > +                     printf(" <%x>", addr);
> > +     printf("\n");
> > +#endif
> > +     bus_generic_probe(dev);
> > +     bus_enumerate_hinted_children(dev);
> > +     bus_generic_attach(dev);
> > +        return (0);
> > +static int
> > +iicbus_detach(device_t dev)
> > +     bus_generic_detach(dev);
> > +     device_delete_children(dev);
> > +     mtx_destroy(&sc->lock);
> > +     return (0);
> > +static int
> > +iicbus_print_child(device_t dev, device_t child)
> > +     struct iicbus_ivar *devi = IICBUS_IVAR(child);
> > +     int retval = 0;
> > +     retval += bus_print_child_header(dev, child);
> > +     if (devi->addr != 0)
> > +             retval += printf(" at addr %#x", devi->addr);
> > +     resource_list_print_type(&devi->rl, "irq", SYS_RES_IRQ, "%jd");
> > +     retval += bus_print_child_footer(dev, child);
> > +     return (retval);
> > +static void
> > +iicbus_probe_nomatch(device_t bus, device_t child)
> > +     device_printf(bus, "<unknown card> at addr %#x\n", devi->addr);
> > +static int
> > +iicbus_child_location_str(device_t bus, device_t child, char *buf,
> > +    size_t buflen)
> > +     snprintf(buf, buflen, "addr=%#x", devi->addr);
> > +     return (0);
> > +static int
> > +iicbus_child_pnpinfo_str(device_t bus, device_t child, char *buf,
> > +    size_t buflen)
> > +     *buf = '\0';
> > +     return (0);
> > +static int
> > +iicbus_read_ivar(device_t bus, device_t child, int which, uintptr_t
> *result)
> > +     switch (which) {
> > +     default:
> > +             return (EINVAL);
> > +     case IICBUS_IVAR_ADDR:
> > +             *result = devi->addr;
> > +             break;
> > +     case IICBUS_IVAR_NOSTOP:
> > +             *result = devi->nostop;
> > +             break;
> > +     return (0);
> > +static int
> > +iicbus_write_ivar(device_t bus, device_t child, int which, uintptr_t
> value)
> > +     switch (which) {
> > +     default:
> > +             return (EINVAL);
> > +                     return (EINVAL);
> > +             devi->addr = value;
> > +             devi->nostop = value;
> > +             break;
> > +     return (0);
> > +static device_t
> > +iicbus_add_child(device_t dev, u_int order, const char *name, int unit)
> > +     device_t child;
> > +     struct iicbus_ivar *devi;
> > +     child = device_add_child_ordered(dev, order, name, unit);
> > +     if (child == NULL)
> > +             return (child);
> > +     devi = malloc(sizeof(struct iicbus_ivar), M_DEVBUF, M_NOWAIT |
> M_ZERO);
> > +     if (devi == NULL) {
> > +             device_delete_child(dev, child);
> > +             return (0);
> > +     resource_list_init(&devi->rl);
> > +     device_set_ivars(child, devi);
> > +     return (child);
> > +static void
> > +iicbus_hinted_child(device_t bus, const char *dname, int dunit)
> > +     device_t child;
> > +     int irq;
> > +     child = BUS_ADD_CHILD(bus, 0, dname, dunit);
> > +     devi = IICBUS_IVAR(child);
> > +     resource_int_value(dname, dunit, "addr", &devi->addr);
> > +     if (resource_int_value(dname, dunit, "irq", &irq) == 0) {
> > +             if (bus_set_resource(child, SYS_RES_IRQ, 0, irq, 1) != 0)
> > +                         "warning: bus_set_resource() failed\n");
> > +static struct resource_list *
> > +iicbus_get_resource_list(device_t bus __unused, device_t child)
> > +     return (&devi->rl);
> > +int
> > +iicbus_generic_intr(device_t dev, int event, char *buf)
> > +     return (0);
> > +int
> > +iicbus_null_callback(device_t dev, int index, caddr_t data)
> > +     return (0);
> > +int
> > +iicbus_null_repeated_start(device_t dev, u_char addr)
> > +     return (IIC_ENOTSUPP);
> > +void
> > +iicbus_init_frequency(device_t dev, u_int bus_freq)
> > +      * If a bus frequency value was passed in, use it.  Otherwise
> initialize
> > +      * it first to the standard i2c 100KHz frequency, then override
> that
> > +      * from a hint if one exists.
> > +     if (bus_freq > 0)
> > +             sc->bus_freq = bus_freq;
> > +     else {
> > +             sc->bus_freq = 100000;
> > +             resource_int_value(device_get_name(dev),
> > +                 "frequency", (int *)&sc->bus_freq);
> > +      * Set up the sysctl that allows the bus frequency to be changed.
> > +      * It is flagged as a tunable so that the user can set the value in
> > +      * loader(8), and that will override any other setting from any
> source.
> > +      * The sysctl tunable/value is the one most directly controlled by
> the
> > +      * user and thus the one that always takes precedence.
> > +     SYSCTL_ADD_UINT(device_get_sysctl_ctx(dev),
> > +         SYSCTL_CHILDREN(device_get_sysctl_tree(dev)),
> > +         OID_AUTO, "frequency", CTLFLAG_RW | CTLFLAG_TUN, &sc->bus_freq,
> > +         sc->bus_freq, "Bus frequency in Hz");
> > +static u_int
> > +iicbus_get_frequency(device_t dev, u_char speed)
> > +      * If the frequency has not been configured for the bus, or the
> request
> > +      * is specifically for SLOW speed, use the standard 100KHz rate,
> else
> > +      * use the configured bus speed.
> > +     if (sc->bus_freq == 0 || speed == IIC_SLOW)
> > +             return (100000);
> > +     return (sc->bus_freq);
> > +static device_method_t iicbus_methods[] = {
> > +     DEVMETHOD(device_probe,         iicbus_probe),
> > +     DEVMETHOD(device_attach,        iicbus_attach),
> > +     DEVMETHOD(device_detach,        iicbus_detach),
> > +     /* bus interface */
> > +     DEVMETHOD(bus_setup_intr,       bus_generic_setup_intr),
> > +     DEVMETHOD(bus_teardown_intr,    bus_generic_teardown_intr),
> > +     DEVMETHOD(bus_activate_resource, bus_generic_activate_resource),
> > +     DEVMETHOD(bus_deactivate_resource,
> bus_generic_deactivate_resource),
> > +     DEVMETHOD(bus_adjust_resource,  bus_generic_adjust_resource),
> > +     DEVMETHOD(bus_alloc_resource,   bus_generic_rl_alloc_resource),
> > +     DEVMETHOD(bus_get_resource,     bus_generic_rl_get_resource),
> > +     DEVMETHOD(bus_release_resource, bus_generic_rl_release_resource),
> > +     DEVMETHOD(bus_set_resource,     bus_generic_rl_set_resource),
> > +     DEVMETHOD(bus_get_resource_list, iicbus_get_resource_list),
> > +     DEVMETHOD(bus_add_child,        iicbus_add_child),
> > +     DEVMETHOD(bus_print_child,      iicbus_print_child),
> > +     DEVMETHOD(bus_probe_nomatch,    iicbus_probe_nomatch),
> > +     DEVMETHOD(bus_read_ivar,        iicbus_read_ivar),
> > +     DEVMETHOD(bus_write_ivar,       iicbus_write_ivar),
> > +     DEVMETHOD(bus_child_pnpinfo_str, iicbus_child_pnpinfo_str),
> > +     DEVMETHOD(bus_child_location_str, iicbus_child_location_str),
> > +     DEVMETHOD(bus_hinted_child,     iicbus_hinted_child),
> > +     DEVMETHOD(iicbus_transfer,      iicbus_transfer),
> > +     DEVMETHOD(iicbus_get_frequency, iicbus_get_frequency),
> > +     DEVMETHOD_END
> > +driver_t iicbus_driver = {
> > +        "iicbus",
> > +        iicbus_methods,
> > +        sizeof(struct iicbus_softc),
> > +devclass_t iicbus_devclass;
> > +MODULE_VERSION(iicbus, IICBUS_MODVER);
> > +DRIVER_MODULE(iicbus, iichb, iicbus_driver, iicbus_devclass, 0, 0);
> > diff --git a/freebsd/sys/dev/iicbus/iicbus.h
> b/freebsd/sys/dev/iicbus/iicbus.h
> > index 00000000..503305c7
> > --- /dev/null
> > +++ b/freebsd/sys/dev/iicbus/iicbus.h
> > @@ -0,0 +1,83 @@
> > + * are met:
> the
> distribution.
> AND
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> STRICT
> ANY WAY
> OF
> > + * SUCH DAMAGE.
> > + * $FreeBSD$
> > +#ifndef __IICBUS_H
> > +#define __IICBUS_H
> > +#include <sys/_lock.h>
> > +#include <sys/_mutex.h>
> > +#define IICBUS_IVAR(d) (struct iicbus_ivar *) device_get_ivars(d)
> > +#define IICBUS_SOFTC(d) (struct iicbus_softc *) device_get_softc(d)
> > +struct iicbus_softc
> > +     device_t dev;           /* Myself */
> > +     device_t owner;         /* iicbus owner device structure */
> > +     u_int owncount;         /* iicbus ownership nesting count */
> > +     u_char started;         /* address of the 'started' slave
> > +                              * 0 if no start condition succeeded */
> > +     u_char strict;          /* deny operations that violate the
> > +                              * I2C protocol */
> > +     struct mtx lock;
> > +     u_int bus_freq;         /* Configured bus Hz. */
> > +struct iicbus_ivar
> > +     uint32_t        addr;
> > +     struct resource_list    rl;
> > +     bool            nostop;
> > +enum {
> > +     IICBUS_IVAR_ADDR,               /* Address or base address */
> > +     IICBUS_IVAR_NOSTOP,             /* nostop defaults */
> > +#define IICBUS_ACCESSOR(A, B, T)                                     \
> > +     __BUS_ACCESSOR(iicbus, A, IICBUS, B, T)
> > +IICBUS_ACCESSOR(addr,                ADDR,           uint32_t)
> > +IICBUS_ACCESSOR(nostop,              NOSTOP,         bool)
> > +#define      IICBUS_LOCK(sc)                 mtx_lock(&(sc)->lock)
> > +#define      IICBUS_UNLOCK(sc)               mtx_unlock(&(sc)->lock)
> > +#define      IICBUS_ASSERT_LOCKED(sc)        mtx_assert(&(sc)->lock,
> MA_OWNED)
> > +int  iicbus_generic_intr(device_t dev, int event, char *buf);
> > +void iicbus_init_frequency(device_t dev, u_int bus_freq);
> > +extern driver_t iicbus_driver;
> > +extern devclass_t iicbus_devclass;
> > +extern driver_t ofw_iicbus_driver;
> > +extern devclass_t ofw_iicbus_devclass;
> > +#endif
> > diff --git a/freebsd/sys/dev/iicbus/iiconf.c
> b/freebsd/sys/dev/iicbus/iiconf.c
> > index 00000000..afdce118
> > --- /dev/null
> > +++ b/freebsd/sys/dev/iicbus/iiconf.c
> > @@ -0,0 +1,527 @@
> > + * are met:
> the
> distribution.
> AND
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> STRICT
> ANY WAY
> OF
> > + * SUCH DAMAGE.
> > + * Translate IIC_Exxxxx status values to vaguely-equivelent errno
> values.
> > +int
> > +iic2errno(int iic_status)
> > +     switch (iic_status) {
> > +     case IIC_NOERR:         return (0);
> > +     case IIC_EBUSERR:       return (EALREADY);
> > +     case IIC_ENOACK:        return (EIO);
> > +     case IIC_ETIMEOUT:      return (ETIMEDOUT);
> > +     case IIC_EBUSBSY:       return (EWOULDBLOCK);
> > +     case IIC_ESTATUS:       return (EPROTO);
> > +     case IIC_EUNDERFLOW:    return (EIO);
> > +     case IIC_EOVERFLOW:     return (EOVERFLOW);
> > +     case IIC_ENOTSUPP:      return (EOPNOTSUPP);
> > +     case IIC_ENOADDR:       return (EADDRNOTAVAIL);
> > +     case IIC_ERESOURCE:     return (ENOMEM);
> > +     default:                return (EIO);
> > + * iicbus_intr()
> > +void
> > +iicbus_intr(device_t bus, int event, char *buf)
> > +     struct iicbus_softc *sc = (struct iicbus_softc
> *)device_get_softc(bus);
> > +     /* call owner's intr routine */
> > +     if (sc->owner)
> > +             IICBUS_INTR(sc->owner, event, buf);
> > +     return;
> > +static int
> > +iicbus_poll(struct iicbus_softc *sc, int how)
> > +     int error;
> > +     IICBUS_ASSERT_LOCKED(sc);
> > +     switch (how & IIC_INTRWAIT) {
> > +     case IIC_WAIT | IIC_INTR:
> > +             error = mtx_sleep(sc, &sc->lock, IICPRI|PCATCH, "iicreq",
> 0);
> > +             break;
> > +     case IIC_WAIT | IIC_NOINTR:
> > +             error = mtx_sleep(sc, &sc->lock, IICPRI, "iicreq", 0);
> > +             break;
> > +     default:
> > +             return (IIC_EBUSBSY);
> > +     return (error);
> > + * iicbus_request_bus()
> > + * Allocate the device to perform transfers.
> > + * how       : IIC_WAIT or IIC_DONTWAIT
> > +int
> > +iicbus_request_bus(device_t bus, device_t dev, int how)
> > +     int error = 0;
> > +     IICBUS_LOCK(sc);
> > +     for (;;) {
> > +             if (sc->owner == NULL)
> > +                     break;
> > +             if ((how & IIC_RECURSIVE) && sc->owner == dev)
> > +                     break;
> > +             if ((error = iicbus_poll(sc, how)) != 0)
> > +                     break;
> > +     if (error == 0) {
> > +             ++sc->owncount;
> > +             if (sc->owner == NULL) {
> > +                     sc->owner = dev;
> > +                      * Drop the lock around the call to the bus
> driver, it
> > +                      * should be allowed to sleep in the IIC_WAIT case.
> > +                      * Drivers might also need to grab locks that would
> > +                      * cause a LOR if our lock is held.
> > +                     IICBUS_UNLOCK(sc);
> > +                     /* Ask the underlying layers if the request is ok
> > +                     error = IICBUS_CALLBACK(device_get_parent(bus),
> > +                         IIC_REQUEST_BUS, (caddr_t)&how);
> > +                     IICBUS_LOCK(sc);
> > +                     if (error != 0) {
> > +                             sc->owner = NULL;
> > +                             sc->owncount = 0;
> > +                             wakeup_one(sc);
> > +     return (error);
> > + * iicbus_release_bus()
> > + * Release the device allocated with iicbus_request_dev()
> > +int
> > +iicbus_release_bus(device_t bus, device_t dev)
> > +     IICBUS_LOCK(sc);
> > +     if (sc->owner != dev) {
> > +     if (--sc->owncount == 0) {
> > +             /* Drop the lock while informing the low-level driver. */
> > +             IICBUS_CALLBACK(device_get_parent(bus), IIC_RELEASE_BUS,
> NULL);
> > +             IICBUS_LOCK(sc);
> > +             sc->owner = NULL;
> > +             wakeup_one(sc);
> > +     return (0);
> > + * iicbus_started()
> > + * Test if the iicbus is started by the controller
> > +int
> > +iicbus_started(device_t bus)
> > +     return (sc->started);
> > + * iicbus_start()
> > + * Send start condition to the slave addressed by 'slave'
> > +int
> > +iicbus_start(device_t bus, u_char slave, int timeout)
> > +     int error = 0;
> > +     if (sc->started)
> > +             return (IIC_ESTATUS); /* protocol error, bus already
> started */
> > +     if (!(error = IICBUS_START(device_get_parent(bus), slave,
> timeout)))
> > +             sc->started = slave;
> > +     else
> > +             sc->started = 0;
> > +     return (error);
> > + * iicbus_repeated_start()
> > +int
> > +iicbus_repeated_start(device_t bus, u_char slave, int timeout)
> > +     int error = 0;
> > +     if (!sc->started)
> > +             return (IIC_ESTATUS); /* protocol error, bus not started */
> > +     if (!(error = IICBUS_REPEATED_START(device_get_parent(bus), slave,
> timeout)))
> > +     else
> > +             sc->started = 0;
> > +     return (error);
> > + * iicbus_stop()
> > + * Send stop condition to the bus
> > +int
> > +iicbus_stop(device_t bus)
> > +     int error = 0;
> > +     if (!sc->started)
> > +     error = IICBUS_STOP(device_get_parent(bus));
> > +     /* refuse any further access */
> > +     sc->started = 0;
> > +     return (error);
> > + * iicbus_write()
> > + * Write a block of data to the slave previously started by
> > + * iicbus_start() call
> > +int
> > +iicbus_write(device_t bus, const char *buf, int len, int *sent, int
> timeout)
> > +     /* a slave must have been started for writing */
> > +     if (sc->started == 0 || (sc->strict != 0 && (sc->started & LSB) !=
> 0))
> > +     return (IICBUS_WRITE(device_get_parent(bus), buf, len, sent,
> timeout));
> > + * iicbus_read()
> > + * Read a block of data from the slave previously started by
> > + * iicbus_read() call
> > +int
> > +iicbus_read(device_t bus, char *buf, int len, int *read, int last, int
> delay)
> > +     /* a slave must have been started for reading */
> > +     if (sc->started == 0 || (sc->strict != 0 && (sc->started & LSB) ==
> 0))
> > +     return (IICBUS_READ(device_get_parent(bus), buf, len, read, last,
> delay));
> > + * iicbus_write_byte()
> > + * Write a byte to the slave previously started by iicbus_start() call
> > +int
> > +iicbus_write_byte(device_t bus, char byte, int timeout)
> > +     struct iicbus_softc *sc = device_get_softc(bus);
> > +     char data = byte;
> > +     int sent;
> 0))
> > +     return (iicbus_write(bus, &data, 1, &sent, timeout));
> > + * iicbus_read_byte()
> > + * Read a byte from the slave previously started by iicbus_start() call
> > +int
> > +iicbus_read_byte(device_t bus, char *byte, int timeout)
> > +     int read;
> 0))
> > +     return (iicbus_read(bus, byte, 1, &read, IIC_LAST_READ, timeout));
> > + * iicbus_block_write()
> > + * Write a block of data to slave ; start/stop protocol managed
> > +int
> > +iicbus_block_write(device_t bus, u_char slave, char *buf, int len, int
> *sent)
> > +     u_char addr = slave & ~LSB;
> > +     int error;
> > +     if ((error = iicbus_start(bus, addr, 0)))
> > +             return (error);
> > +     error = iicbus_write(bus, buf, len, sent, 0);
> > +     iicbus_stop(bus);
> > +     return (error);
> > + * iicbus_block_read()
> > + * Read a block of data from slave ; start/stop protocol managed
> > +int
> > +iicbus_block_read(device_t bus, u_char slave, char *buf, int len, int
> *read)
> > +     u_char addr = slave | LSB;
> > +     int error;
> > +             return (error);
> > +     error = iicbus_read(bus, buf, len, read, IIC_LAST_READ, 0);
> > +     iicbus_stop(bus);
> > +     return (error);
> > + * iicbus_transfer()
> > + * Do an aribtrary number of transfers on the iicbus.  We pass these
> > + * raw requests to the bridge driver.  If the bridge driver supports
> > + * them directly, then it manages all the details.  If not, it can use
> > + * the helper function iicbus_transfer_gen() which will do the
> > + * transfers at a low level.
> > + * Pointers passed in as part of iic_msg must be kernel pointers.
> > + * Callers that have user addresses to manage must do so on their own.
> > +int
> > +iicbus_transfer(device_t bus, struct iic_msg *msgs, uint32_t nmsgs)
> > +     return (IICBUS_TRANSFER(device_get_parent(bus), msgs, nmsgs));
> > +int
> > +iicbus_transfer_excl(device_t dev, struct iic_msg *msgs, uint32_t nmsgs,
> > +    int how)
> > +     device_t bus;
> > +     int error;
> > +     bus = device_get_parent(dev);
> > +     error = iicbus_request_bus(bus, dev, how);
> > +     if (error == 0)
> > +             error = IICBUS_TRANSFER(bus, msgs, nmsgs);
> > +     iicbus_release_bus(bus, dev);
> > +     return (error);
> > + * Generic version of iicbus_transfer that calls the appropriate
> > + * routines to accomplish this.  See note above about acceptable
> > + * buffer addresses.
> > +int
> > +iicbus_transfer_gen(device_t dev, struct iic_msg *msgs, uint32_t nmsgs)
> > +     int i, error, lenread, lenwrote, nkid, rpstart, addr;
> > +     device_t *children, bus;
> > +     bool nostop, started;
> > +     if ((error = device_get_children(dev, &children, &nkid)) != 0)
> > +             return (IIC_ERESOURCE);
> > +     if (nkid != 1) {
> > +             free(children, M_TEMP);
> > +     bus = children[0];
> > +     rpstart = 0;
> > +     nostop = iicbus_get_nostop(dev);
> > +     started = false;
> > +     for (i = 0, error = 0; i < nmsgs && error == 0; i++) {
> > +             addr = msgs[i].slave;
> > +             if (msgs[i].flags & IIC_M_RD)
> > +                     addr |= LSB;
> > +             else
> > +                     addr &= ~LSB;
> > +             if (!(msgs[i].flags & IIC_M_NOSTART)) {
> > +                     if (rpstart)
> > +                             error = iicbus_repeated_start(bus, addr,
> 0);
> > +                     else
> > +                             error = iicbus_start(bus, addr, 0);
> > +                     if (error != 0)
> > +                             break;
> > +                     started = true;
> > +                     error = iicbus_read(bus, msgs[i].buf, msgs[i].len,
> > +                         &lenread, IIC_LAST_READ, 0);
> > +             else
> > +                     error = iicbus_write(bus, msgs[i].buf, msgs[i].len,
> > +                         &lenwrote, 0);
> > +             if (error != 0)
> > +                     break;
> > +             if ((msgs[i].flags & IIC_M_NOSTOP) != 0 ||
> > +                 (nostop && i + 1 < nmsgs)) {
> > +                     rpstart = 1;    /* Next message gets repeated
> start */
> > +             } else {
> > +                     rpstart = 0;
> > +                     iicbus_stop(bus);
> > +     if (error != 0 && started)
> > +             iicbus_stop(bus);
> > +     return (error);
> > +int
> > +iicdev_readfrom(device_t slavedev, uint8_t regaddr, void *buffer,
> > +    uint16_t buflen, int waithow)
> > +     struct iic_msg msgs[2];
> > +     uint8_t slaveaddr;
> > +      * Two transfers back to back with a repeat-start between them;
> first we
> > +      * write the address-within-device, then we read from the device.
> > +     slaveaddr = iicbus_get_addr(slavedev);
> > +     msgs[0].slave = slaveaddr;
> > +     msgs[0].flags = IIC_M_WR | IIC_M_NOSTOP;
> > +     msgs[0].len   = 1;
> > +     msgs[0].buf   = ®addr;
> > +     msgs[1].slave = slaveaddr;
> > +     msgs[1].flags = IIC_M_RD;
> > +     msgs[1].len   = buflen;
> > +     msgs[1].buf   = buffer;
> > +     return (iicbus_transfer_excl(slavedev, msgs, nitems(msgs),
> waithow));
> > +int iicdev_writeto(device_t slavedev, uint8_t regaddr, void *buffer,
> > +      * Two transfers back to back with no stop or start between them;
> first
> > +      * we write the address then we write the data to that address,
> all in a
> > +      * single transfer from two scattered buffers.
> > +     msgs[0].len   = 1;
> > +     msgs[1].flags = IIC_M_WR | IIC_M_NOSTART;
> waithow));
> > diff --git a/freebsd/sys/dev/iicbus/iiconf.h
> b/freebsd/sys/dev/iicbus/iiconf.h
> > index 00000000..c264183e
> > --- /dev/null
> > +++ b/freebsd/sys/dev/iicbus/iiconf.h
> > @@ -0,0 +1,162 @@
> > + * are met:
> the
> distribution.
> AND
> PURPOSE
> LIABLE
> CONSEQUENTIAL
> GOODS
> STRICT
> ANY WAY
> OF
> > + * SUCH DAMAGE.
> > + * $FreeBSD$
> > +#ifndef __IICONF_H
> > +#define __IICONF_H
> > +#include <sys/queue.h>
> > +#define IICPRI (PZERO+8)             /* XXX sleep/wakeup queue priority
> > +#define LSB 0x1
> > + * Options affecting iicbus_request_bus()
> > +#define IIC_DONTWAIT 0
> > +#define IIC_NOINTR   0
> > +#define IIC_WAIT     0x1
> > +#define IIC_INTR     0x2
> > +#define IIC_INTRWAIT (IIC_INTR | IIC_WAIT)
> > +#define IIC_RECURSIVE        0x4
> > + * i2c modes
> > +#define IIC_MASTER   0x1
> > +#define IIC_SLAVE    0x2
> > +#define IIC_POLLED   0x4
> > + * i2c speed
> > +#define IIC_UNKNOWN  0x0
> > +#define IIC_SLOW     0x1
> > +#define IIC_FAST     0x2
> > +#define IIC_FASTEST  0x3
> > +#define IIC_LAST_READ        0x1
> > + * callback index
> > +#define IIC_REQUEST_BUS      0x1
> > +#define IIC_RELEASE_BUS      0x2
> > + * interrupt events
> > +#define INTR_GENERAL 0x1     /* general call received */
> > +#define INTR_START   0x2     /* the I2C interface is addressed */
> > +#define INTR_STOP    0x3     /* stop condition received */
> > +#define INTR_RECEIVE 0x4     /* character received */
> > +#define INTR_TRANSMIT        0x5     /* character to transmit */
> > +#define INTR_ERROR   0x6     /* error */
> > +#define INTR_NOACK   0x7     /* no ack from master receiver */
> > + * adapter layer errors
> > +#define      IIC_NOERR       0x0     /* no error occurred */
> > +#define IIC_EBUSERR  0x1     /* bus error (hardware not in expected
> state) */
> > +#define IIC_ENOACK   0x2     /* ack not received until timeout */
> > +#define IIC_ETIMEOUT 0x3     /* timeout */
> > +#define IIC_EBUSBSY  0x4     /* bus busy (reserved by another client) */
> > +#define IIC_ESTATUS  0x5     /* status error */
> > +#define IIC_EUNDERFLOW       0x6     /* slave ready for more data */
> > +#define IIC_EOVERFLOW        0x7     /* too much data */
> > +#define IIC_ENOTSUPP 0x8     /* request not supported */
> > +#define IIC_ENOADDR  0x9     /* no address assigned to the interface */
> > +#define IIC_ERESOURCE        0xa     /* resources (memory, whatever)
> unavailable */
> > + * Note that all iicbus functions return IIC_Exxxxx status values,
> > + * except iic2errno() (obviously) and iicbus_started() (returns bool).
> > +extern int iic2errno(int);
> > +extern int iicbus_request_bus(device_t, device_t, int);
> > +extern int iicbus_release_bus(device_t, device_t);
> > +extern device_t iicbus_alloc_bus(device_t);
> > +extern void iicbus_intr(device_t, int, char *);
> > +extern int iicbus_null_repeated_start(device_t, u_char);
> > +extern int iicbus_null_callback(device_t, int, caddr_t);
> > +#define iicbus_reset(bus,speed,addr,oldaddr) \
> > +     (IICBUS_RESET(device_get_parent(bus), speed, addr, oldaddr))
> > +/* basic I2C operations */
> > +extern int iicbus_started(device_t);
> > +extern int iicbus_start(device_t, u_char, int);
> > +extern int iicbus_stop(device_t);
> > +extern int iicbus_repeated_start(device_t, u_char, int);
> > +extern int iicbus_write(device_t, const char *, int, int *, int);
> > +extern int iicbus_read(device_t, char *, int, int *, int, int);
> > +/* single byte read/write functions, start/stop not managed */
> > +extern int iicbus_write_byte(device_t, char, int);
> > +extern int iicbus_read_byte(device_t, char *, int);
> > +/* Read/write operations with start/stop conditions managed */
> > +extern int iicbus_block_write(device_t, u_char, char *, int, int *);
> > +extern int iicbus_block_read(device_t, u_char, char *, int, int *);
> > +/* vectors of iic operations to pass to bridge */
> > +int iicbus_transfer(device_t bus, struct iic_msg *msgs, uint32_t nmsgs);
> > +int iicbus_transfer_excl(device_t bus, struct iic_msg *msgs, uint32_t
> nmsgs,
> > +    int how);
> > +int iicbus_transfer_gen(device_t bus, struct iic_msg *msgs, uint32_t
> nmsgs);
> > + * Simple register read/write routines, but the "register" can be any
> size.
> > + * The transfers are done with iicbus_transfer_excl().  Reads use a
> repeat-start
> > + * between sending the address and reading; writes use a single
> start/stop.
> > +int iicdev_readfrom(device_t _slavedev, uint8_t _regaddr, void *_buffer,
> > +    uint16_t _buflen, int _waithow);
> > +int iicdev_writeto(device_t _slavedev, uint8_t _regaddr, void *_buffer,
> > +#define IICBUS_MODVER        1
> > +#define IICBUS_MINVER        1
> > +#define IICBUS_MAXVER        1
> > +#define IICBUS_PREFVER       IICBUS_MODVER
> > +extern driver_t iicbb_driver;
> > +extern devclass_t iicbb_devclass;
> > +#define IICBB_MODVER 1
> > +#define IICBB_MINVER 1
> > +#define IICBB_MAXVER 1
> > +#define IICBB_PREFVER        IICBB_MODVER
> > +#endif
> > diff --git a/freebsd/sys/dev/iicbus/ofw_iicbus.c
> b/freebsd/sys/dev/iicbus/ofw_iicbus.c
> > index 00000000..cb31459e
> > --- /dev/null
> > +++ b/freebsd/sys/dev/iicbus/ofw_iicbus.c
> > @@ -0,0 +1,242 @@
> > + * Copyright (c) 2009, Nathan Whitehorn <nwhitehorn at FreeBSD.org>
> > + * are met:
> > + *    notice unmodified, this list of conditions, and the following
> > + *    disclaimer.
> the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
> > + * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
> WARRANTIES
> > + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
> DISCLAIMED.
> > + * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
> > + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
> BUT
> > + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
> USE,
> > + * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
> > + * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
> > + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
> USE OF
> > + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> > +#include <sys/libkern.h>
> > +#include <dev/ofw/ofw_bus.h>
> > +#include <dev/ofw/ofw_bus_subr.h>
> > +#include <dev/ofw/openfirm.h>
> > +/* Methods */
> > +static device_probe_t ofw_iicbus_probe;
> > +static device_attach_t ofw_iicbus_attach;
> > +static device_t ofw_iicbus_add_child(device_t dev, u_int order,
> > +    const char *name, int unit);
> > +static c
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190610/7a39048e/attachment-0002.html>
