[PATCH]Re:RAP File load error
jameszxj jameszxj at gmail.com
Wed Jun 12 05:29:07 UTC 2019
I commit and create a patch use sourcetree, is this ok?
------------------ Original ------------------
Date: Wed, Jun 12, 2019 12:26 PM
To: "jameszxj"<jameszxj at gmail.com>;"devel"<devel at rtems.org>;
Subject: Re: [PATCH]Re:RAP File load error
On 12/6/19 2:15 pm, jameszxj wrote:
> I found the problem
Awesome.
> is: rtems_rtl_elf_relocate_rel() change the return value,
> but rtl-rap.c:412 still check the return value as bool, so the RAP load failed.
> I make a patch about this.
The patch look good however I need a patch generated from a commit so I can
acknowledge your contribution. Please commit the change and create a patch, the
following may help ...
https://devel.rtems.org/wiki/Developer/Git/Users#CreatingaPatch
Thanks
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190612/41d0adc9/attachment-0002.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190612/41d0adc9/attachment-0002.obj>
