[PATCH v2 2/5] iicbus: port to RTEMS
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Wed Jun 12 12:23:53 UTC 2019
On Sat, Jun 8, 2019 at 6:20 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
>  Makefile.todo                                 |  11 ++
>  buildset/default.ini                          |   1 +
>  libbsd.py                                     |  35 ++++
>  rtemsbsd/include/bsp/nexus-devices.h          |   4 +
>  .../machine/rtems-bsd-kernel-namespace.h      |  29 +++
>  rtemsbsd/include/rtems/bsd/local/iicbus_if.h  | 166 ++++++++++++++++++
>  rtemsbsd/local/iicbus_if.c                    |  76 ++++++++
>  7 files changed, 322 insertions(+)
>  create mode 100644 rtemsbsd/include/rtems/bsd/local/iicbus_if.h
>  create mode 100644 rtemsbsd/local/iicbus_if.c
> diff --git a/Makefile.todo b/Makefile.todo
> index 9754ddb6..74188531 100644
> --- a/Makefile.todo
> +++ b/Makefile.todo
> @@ -215,6 +215,17 @@ $(LOCAL_SRC)/gpiobus_if.c:
> $(FREEBSD_SRC)/sys/dev/gpio/gpiobus_if.m
>             -e 's|#include "gpiobus_if.h"|#include
> <rtems/bsd/local/gpiobus_if.h>|'
>         mv gpiobus_if.c $@
> +$(LOCAL_INC)/iicbus_if.h: $(FREEBSD_SRC)/sys/dev/iicbus/iicbus_if.m
> +       awk -f $(TOOLS)/makeobjops.awk $< -h
> +       mv iicbus_if.h $@
> +$(LOCAL_SRC)/iicbus_if.c: $(FREEBSD_SRC)/sys/dev/iicbus/iicbus_if.m
> +       awk -f $(TOOLS)/makeobjops.awk $< -c
> +       sed -i iicbus_if.c \
> +           -e '1 i\#include <machine/rtems-bsd-kernel-space.h>\n' \
> +           -e 's|#include "iicbus_if.h"|#include
> <rtems/bsd/local/iicbus_if.h>|'
> +       mv iicbus_if.c $@
I haven't added these files to the list of files in "GENERATED" files.
I'll add that and post a v3 of the patch series.
>  $(LOCAL_INC)/sdhci_if.h: $(FREEBSD_SRC)/sys/dev/sdhci/sdhci_if.m
>         mv sdhci_if.h $@
> diff --git a/buildset/default.ini b/buildset/default.ini
> index f25fe9a3..4acb2368 100644
> --- a/buildset/default.ini
> +++ b/buildset/default.ini
> @@ -36,6 +36,7 @@ dev_usb_serial = on
>  dev_usb_storage = on
>  dev_usb_wlan = off
>  dev_wlan_rtwn = off
> +iic = on
>  dhcpcd = on
>  dpaa = on
>  evdev = on
> diff --git a/libbsd.py b/libbsd.py
> index d99e3ad8..a25d3a8a 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -125,6 +125,7 @@ _defaults = {
>       ('freebsd/sys/sys',                        '**/*.h',
>           'sys'),
>       ('freebsd/sys/vm',                         '**/*.h',
>           'vm'),
>       ('freebsd/sys/dev/mii',                    '**/*.h',
>           'dev/mii'),
> +     ('freebsd/sys/dev/iicbus',                 '**/*.h',
>           'dev/iicbus'),
>       ('linux/include',                          '**/*.h',
>       ('mDNSResponder/mDNSCore',                 'mDNSDebug.h',
>       ('mDNSResponder/mDNSCore',                 'mDNSEmbeddedAPI.h',
> @@ -741,6 +742,39 @@ class evdev(builder.Module):
>              mm.generator['source']()
> +# IIC
> +class iic(builder.Module):
> +    def __init__(self, manager):
> +        super(iic, self).__init__(manager, type(self).__name__)
> +    def generate(self):
> +        mm = self.manager
> +        self.addKernelSpaceHeaderFiles(
> +                'sys/dev/iicbus/iicbus.h',
> +                'sys/dev/iicbus/iic.h',
> +                'sys/dev/iicbus/iiconf.h',
> +        self.addKernelSpaceSourceFiles(
> +                'sys/dev/iicbus/iic.c',
> +                'sys/dev/iicbus/iicbus.c',
> +                'sys/dev/iicbus/iiconf.c',
> +                'sys/dev/iicbus/ofw_iicbus.c',
> +            mm.generator['source']()
> +        self.addRTEMSSourceFiles(
> +                'local/iicbus_if.c',
>  # USB
> @@ -5096,6 +5130,7 @@ def load(mm):
>      mm.addModule(mmc_ti(mm))
>      mm.addModule(dev_input(mm))
>      mm.addModule(evdev(mm))
> +    mm.addModule(iic(mm))
>      mm.addModule(dev_usb(mm))
>      mm.addModule(dev_usb_controller(mm))
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h
> b/rtemsbsd/include/bsp/nexus-devices.h
> index a916c664..97f6d2b2 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -61,6 +61,10 @@ SYSINIT_DRIVER_REFERENCE(sdhci_ti, simplebus);
>  SYSINIT_DRIVER_REFERENCE(mmcsd, mmc);
>  SYSINIT_DRIVER_REFERENCE(cpsw, cpswss);
>  SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
> +SYSINIT_DRIVER_REFERENCE(rtems_i2c, simplebus);
> +SYSINIT_DRIVER_REFERENCE(ofw_iicbus, rtems_i2c);
> +SYSINIT_DRIVER_REFERENCE(iic, iicbus);
> +SYSINIT_DRIVER_REFERENCE(iicbus, rtems_i2c);
>  #ifdef RTEMS_BSD_MODULE_NET80211
>  SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
>  SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
> diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> index 83c4366a..235c9886 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> @@ -1989,6 +1989,33 @@
>  #define        igmp_input _bsd_igmp_input
>  #define        igmp_mtx _bsd_igmp_mtx
>  #define        igmp_slowtimo _bsd_igmp_slowtimo
> +#define        iic2errno _bsd_iic2errno
> +#define        iicbb_devclass _bsd_iicbb_devclass
> +#define        iicbb_driver _bsd_iicbb_driver
> +#define        iicbus_block_read _bsd_iicbus_block_read
> +#define        iicbus_block_write _bsd_iicbus_block_write
> +#define        iicbus_devclass _bsd_iicbus_devclass
> +#define        iicbus_driver _bsd_iicbus_driver
> +#define        iicbus_generic_intr _bsd_iicbus_generic_intr
> +#define        iicbus_init_frequency _bsd_iicbus_init_frequency
> +#define        iicbus_intr _bsd_iicbus_intr
> +#define        iicbus_null_callback _bsd_iicbus_null_callback
> +#define        iicbus_null_repeated_start _bsd_iicbus_null_repeated_start
> +#define        iicbus_read _bsd_iicbus_read
> +#define        iicbus_read_byte _bsd_iicbus_read_byte
> +#define        iicbus_release_bus _bsd_iicbus_release_bus
> +#define        iicbus_repeated_start _bsd_iicbus_repeated_start
> +#define        iicbus_request_bus _bsd_iicbus_request_bus
> +#define        iicbus_start _bsd_iicbus_start
> +#define        iicbus_started _bsd_iicbus_started
> +#define        iicbus_stop _bsd_iicbus_stop
> +#define        iicbus_transfer _bsd_iicbus_transfer
> +#define        iicbus_transfer_excl _bsd_iicbus_transfer_excl
> +#define        iicbus_transfer_gen _bsd_iicbus_transfer_gen
> +#define        iicbus_write _bsd_iicbus_write
> +#define        iicbus_write_byte _bsd_iicbus_write_byte
> +#define        iicdev_readfrom _bsd_iicdev_readfrom
> +#define        iicdev_writeto _bsd_iicdev_writeto
>  #define        im6o_mc_filter _bsd_im6o_mc_filter
>  #define        imo_multi_filter _bsd_imo_multi_filter
>  #define        in4_cksum _bsd_in4_cksum
> @@ -3021,6 +3048,8 @@
>  #define        ofw_gpiobus_parse_gpios _bsd_ofw_gpiobus_parse_gpios
>  #define        ofw_gpiobus_register_provider
> _bsd_ofw_gpiobus_register_provider
>  #define        ofw_gpiobus_unregister_provider
> _bsd_ofw_gpiobus_unregister_provider
> +#define        ofw_iicbus_devclass _bsd_ofw_iicbus_devclass
> +#define        ofw_iicbus_driver _bsd_ofw_iicbus_driver
>  #define        ofw_parse_bootargs _bsd_ofw_parse_bootargs
>  #define        ofw_reg_to_paddr _bsd_ofw_reg_to_paddr
>  #define        OF_write _bsd_OF_write
> diff --git a/rtemsbsd/include/rtems/bsd/local/iicbus_if.h
> b/rtemsbsd/include/rtems/bsd/local/iicbus_if.h
> new file mode 100644
> index 00000000..7fafbb60
> --- /dev/null
> +++ b/rtemsbsd/include/rtems/bsd/local/iicbus_if.h
> @@ -0,0 +1,166 @@
> + * This file is produced automatically.
> + * Do not modify anything in here by hand.
> + * Created from source file
> + *   freebsd-org/sys/dev/iicbus/iicbus_if.m
> + * with
> + *   makeobjops.awk
> + * See the source file for legal information
> +#ifndef _iicbus_if_h_
> +#define _iicbus_if_h_
> +/** @brief Unique descriptor for the IICBUS_INTR() method */
> +extern struct kobjop_desc iicbus_intr_desc;
> +/** @brief A function implementing the IICBUS_INTR() method */
> +typedef int iicbus_intr_t(device_t dev, int event, char *buf);
> +static __inline int IICBUS_INTR(device_t dev, int event, char *buf)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_intr);
> +       rc = ((iicbus_intr_t *) _m)(dev, event, buf);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_CALLBACK() method */
> +extern struct kobjop_desc iicbus_callback_desc;
> +/** @brief A function implementing the IICBUS_CALLBACK() method */
> +typedef int iicbus_callback_t(device_t dev, int index, caddr_t data);
> +static __inline int IICBUS_CALLBACK(device_t dev, int index, caddr_t data)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_callback);
> +       rc = ((iicbus_callback_t *) _m)(dev, index, data);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_REPEATED_START() method */
> +extern struct kobjop_desc iicbus_repeated_start_desc;
> +/** @brief A function implementing the IICBUS_REPEATED_START() method */
> +typedef int iicbus_repeated_start_t(device_t dev, u_char slave, int
> timeout);
> +static __inline int IICBUS_REPEATED_START(device_t dev, u_char slave,
> +                                          int timeout)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_repeated_start);
> +       rc = ((iicbus_repeated_start_t *) _m)(dev, slave, timeout);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_START() method */
> +extern struct kobjop_desc iicbus_start_desc;
> +/** @brief A function implementing the IICBUS_START() method */
> +typedef int iicbus_start_t(device_t dev, u_char slave, int timeout);
> +static __inline int IICBUS_START(device_t dev, u_char slave, int timeout)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_start);
> +       rc = ((iicbus_start_t *) _m)(dev, slave, timeout);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_STOP() method */
> +extern struct kobjop_desc iicbus_stop_desc;
> +/** @brief A function implementing the IICBUS_STOP() method */
> +typedef int iicbus_stop_t(device_t dev);
> +static __inline int IICBUS_STOP(device_t dev)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_stop);
> +       rc = ((iicbus_stop_t *) _m)(dev);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_READ() method */
> +extern struct kobjop_desc iicbus_read_desc;
> +/** @brief A function implementing the IICBUS_READ() method */
> +typedef int iicbus_read_t(device_t dev, char *buf, int len, int *bytes,
> +                          int last, int delay);
> +static __inline int IICBUS_READ(device_t dev, char *buf, int len, int
> *bytes,
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_read);
> +       rc = ((iicbus_read_t *) _m)(dev, buf, len, bytes, last, delay);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_WRITE() method */
> +extern struct kobjop_desc iicbus_write_desc;
> +/** @brief A function implementing the IICBUS_WRITE() method */
> +typedef int iicbus_write_t(device_t dev, const char *buf, int len, int
> *bytes,
> +                           int timeout);
> +static __inline int IICBUS_WRITE(device_t dev, const char *buf, int len,
> +                                 int *bytes, int timeout)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_write);
> +       rc = ((iicbus_write_t *) _m)(dev, buf, len, bytes, timeout);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_RESET() method */
> +extern struct kobjop_desc iicbus_reset_desc;
> +/** @brief A function implementing the IICBUS_RESET() method */
> +typedef int iicbus_reset_t(device_t dev, u_char speed, u_char addr,
> +                           u_char *oldaddr);
> +static __inline int IICBUS_RESET(device_t dev, u_char speed, u_char addr,
> +                                 u_char *oldaddr)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_reset);
> +       rc = ((iicbus_reset_t *) _m)(dev, speed, addr, oldaddr);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_TRANSFER() method */
> +extern struct kobjop_desc iicbus_transfer_desc;
> +/** @brief A function implementing the IICBUS_TRANSFER() method */
> +typedef int iicbus_transfer_t(device_t dev, struct iic_msg *msgs,
> +                              uint32_t nmsgs);
> +static __inline int IICBUS_TRANSFER(device_t dev, struct iic_msg *msgs,
> +                                    uint32_t nmsgs)
> +       kobjop_t _m;
> +       int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_transfer);
> +       rc = ((iicbus_transfer_t *) _m)(dev, msgs, nmsgs);
> +       return (rc);
> +/** @brief Unique descriptor for the IICBUS_GET_FREQUENCY() method */
> +extern struct kobjop_desc iicbus_get_frequency_desc;
> +/** @brief A function implementing the IICBUS_GET_FREQUENCY() method */
> +typedef u_int iicbus_get_frequency_t(device_t dev, u_char speed);
> +static __inline u_int IICBUS_GET_FREQUENCY(device_t dev, u_char speed)
> +       kobjop_t _m;
> +       u_int rc;
> +       KOBJOPLOOKUP(((kobj_t)dev)->ops,iicbus_get_frequency);
> +       rc = ((iicbus_get_frequency_t *) _m)(dev, speed);
> +       return (rc);
> +#endif /* _iicbus_if_h_ */
> diff --git a/rtemsbsd/local/iicbus_if.c b/rtemsbsd/local/iicbus_if.c
> index 00000000..68099c34
> --- /dev/null
> +++ b/rtemsbsd/local/iicbus_if.c
> @@ -0,0 +1,76 @@
> +#include <machine/rtems-bsd-kernel-space.h>
> + * with
> + *   makeobjops.awk
> +#include <sys/param.h>
> +#include <sys/queue.h>
> +#include <sys/kernel.h>
> +#include <sys/kobj.h>
> +#include <sys/bus.h>
> +#include <dev/iicbus/iic.h>
> +#include <rtems/bsd/local/iicbus_if.h>
> +static int iicbus_nosupport(void)
> +       return (ENODEV);
> +static u_int
> +iicbus_default_frequency(device_t bus, u_char speed)
> +       return (100000);
> +struct kobjop_desc iicbus_intr_desc = {
> +       0, { &iicbus_intr_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc iicbus_callback_desc = {
> +       0, { &iicbus_callback_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc iicbus_repeated_start_desc = {
> +       0, { &iicbus_repeated_start_desc, (kobjop_t)iicbus_nosupport }
> +struct kobjop_desc iicbus_start_desc = {
> +       0, { &iicbus_start_desc, (kobjop_t)iicbus_nosupport }
> +struct kobjop_desc iicbus_stop_desc = {
> +       0, { &iicbus_stop_desc, (kobjop_t)iicbus_nosupport }
> +struct kobjop_desc iicbus_read_desc = {
> +       0, { &iicbus_read_desc, (kobjop_t)iicbus_nosupport }
> +struct kobjop_desc iicbus_write_desc = {
> +       0, { &iicbus_write_desc, (kobjop_t)iicbus_nosupport }
> +struct kobjop_desc iicbus_reset_desc = {
> +       0, { &iicbus_reset_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc iicbus_transfer_desc = {
> +       0, { &iicbus_transfer_desc, (kobjop_t)kobj_error_method }
> +struct kobjop_desc iicbus_get_frequency_desc = {
> +       0, { &iicbus_get_frequency_desc,
> (kobjop_t)iicbus_default_frequency }
> 2.20.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190612/168ddf6e/attachment-0002.html>
