[PATCH] Add Testsuite for PSXINTTYPES01
Vaibhav Gupta vaibhavgupta40 at gmail.com
Thu Jun 13 16:45:44 UTC 2019
On Thu, Jun 13, 2019 at 3:55 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Jun 12, 2019 at 12:17 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Ok, will do that.
> > On Wed, Jun 12, 2019, 10:10 PM Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
> >> Hi Vaibhav,
> >> RTEMS does not use // for comment. Just make this little change and
> send the
> >> next version of this patch.
> Speaking of patch versions, please use the -v option of
> git-format-patch to generate version-numbrered patches. this one
> should have been maybe -v2, and next one would be -v3, etc...
> >> On Wed, Jun 12, 2019 at 3:09 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> >> >  testsuites/psxtests/Makefile.am               |   7 +
> >> >  testsuites/psxtests/configure.ac              |   1 +
> >> >  testsuites/psxtests/psxinttypes01/init.c      | 233
> >> >  .../psxtests/psxinttypes01/psxinttypes01.doc  |  70 ++++++
> >> >  .../psxtests/psxinttypes01/psxinttypes01.scn  |  44 ++++
> >> >  5 files changed, 355 insertions(+)
> >> >  create mode 100644 testsuites/psxtests/psxinttypes01/init.c
> >> >  create mode 100644
> testsuites/psxtests/psxinttypes01/psxinttypes01.docs
> >> >  create mode 100644
> testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> >> > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> >> > index 1e354c0df7..59c9f2085b 100755
> >> > --- a/testsuites/psxtests/Makefile.am
> >> > +++ b/testsuites/psxtests/Makefile.am
> >> > @@ -523,6 +523,13 @@ psxintrcritical01_CPPFLAGS = $(AM_CPPFLAGS) \
> >> >  endif
> >> >  endif
> >> > +if TEST_psxinttypes01
> >> > +psx_tests += psxinttypes01
> >> > +psxinttypes01_SOURCES = psxinttypes01/init.c
> >> > +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
> >> > +       $(support_includes)
> >> > +endif
> >> >  if HAS_POSIX
> >> >  if TEST_psxitimer
> >> >  psx_tests += psxitimer
> >> > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> >> > index cdd6ee7e4e..85559e4aa5 100644
> >> > --- a/testsuites/psxtests/configure.ac
> >> > +++ b/testsuites/psxtests/configure.ac
> >> > @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxid01])
> >> >  RTEMS_TEST_CHECK([psximfs01])
> >> >  RTEMS_TEST_CHECK([psximfs02])
> >> >  RTEMS_TEST_CHECK([psxintrcritical01])
> >> > +RTEMS_TEST_CHECK([psxinttypes01])
> >> >  RTEMS_TEST_CHECK([psxitimer])
> >> >  RTEMS_TEST_CHECK([psxkey01])
> >> >  RTEMS_TEST_CHECK([psxkey02])
> >> > diff --git a/testsuites/psxtests/psxinttypes01/init.c
> b/testsuites/psxtests/psxinttypes01/init.c
> >> > new file mode 100644
> >> > index 0000000000..8eafae11ac
> >> > --- /dev/null
> >> > +++ b/testsuites/psxtests/psxinttypes01/init.c
> >> > @@ -0,0 +1,233 @@
> >> > + *  @file
> >> > + *  @brief Test suite for inttypes.h methods
> >> > + * SPDX-License-Identifier: BSD-2-Clause
> >> > + * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
> >> > + * Redistribution and use in source and binary forms, with or without
> >> > + * modification, are permitted provided that the following conditions
> >> > + * are met:
> >> > + * 1. Redistributions of source code must retain the above copyright
> >> > + *    notice, this list of conditions and the following disclaimer.
> >> > + * 2. Redistributions in binary form must reproduce the above
> copyright
> in the
> >> > + *    documentation and/or other materials provided with the
> distribution.
> >> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> CONTRIBUTORS "AS IS"
> >> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> >> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> >> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> >> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> OR
> >> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> OF
> >> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> >> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> WHETHER IN
> >> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> >> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> ADVISED OF THE
> >> > + * POSSIBILITY OF SUCH DAMAGE.
> >> > +#ifdef HAVE_CONFIG_H
> >> > +#include "config.h"
> >> > +#endif
> >> > +#include <rtems/test.h>
> >> > +#include <inttypes.h>
> >> > +#include <stdio.h>
> >> > +#include <errno.h>
> >> > +#include <tmacros.h>
> >> > +#include <stdint.h>
> >> > +#include <stddef.h>
> >> > +const char rtems_test_name[] = "PSXINTTYPE 01";
> >> > +/* forward declarations to avoid warnings */
> >> > +rtems_task Init(rtems_task_argument ignored);
> >> > +  int       base            = 10;
> >> > +  int       invalid_base    = 40;
> >> > +  char     *nptr1_p         = "123abc";
>   //char* pointing to string with positive number
> >> > +  char            *nptr1_p_errange = "9999999999999999999999";
>    //char* pointing to string with positive number that is out of range
> >> > +  char     *nptr1_n         = "-123abc";
>  //char* pointing to string with negative number
> >> > +  char            *nptr1_n_errange = "-9999999999999999999999";
>   //char* pointing to string with negative number that is out of range
> >> > +  char     *endptr1         = NULL;
> >> > +  wchar_t  *nptr2_p         = L"123junk";
> //wchar_t* pointing to string with positive number
> >> > +  wchar_t  *nptr2_p_errange = L"9999999999999999999999";
>  //wchar_t* pointing to string with positive number that is out of range
> >> > +  wchar_t  *nptr2_n         = L"-123junk";
>  //wchar_t* pointing to string with negative number
> >> > +  wchar_t  *nptr2_n_errange = L"-9999999999999999999999";
> //wchar_t* pointing to string with negative number that is out of range
> Have a look at https://devel.rtems.org/wiki/Developer/Coding/Conventions
Okay, I guess there is no need of commenting the variables. The name of
variables
itself define their purpose.
> >> > +  wchar_t  *endptr2         = NULL;
> >> > +  intmax_t  result_strtoimax;
> >> > +  uintmax_t result_strtoumax;
> >> > +  TEST_BEGIN();
> >> > +  /*Test for strtoimax  */
> >> > +  puts( "\nstrtoimax Testcases...." );
> >> > +  puts( "Valid Inputs - Positive Number" );
> >> > +  result_strtoimax = strtoimax( nptr1_p, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoimax == 123 );
> >> > +  puts( "Final string pointed by endptr" );
> >> > +  rtems_test_assert( endptr1 == ( nptr1_p + 3 ) );
> >> > +  puts( "Valid Inputs - Negative Number" );
> >> > +  result_strtoimax = strtoimax( nptr1_n, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoimax == -123 );
> >> > +  rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
> >> > +  puts( "Valid Input - Positive Number - Number out of Range" );
> >> > +  result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoimax == INTMAX_MAX );
> >> > +  rtems_test_assert( errno == ERANGE );
> >> > +  puts( "Valid Input - Negative Number - Number out of Range" );
> >> > +  result_strtoimax = strtoimax( nptr1_n_errange, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoimax == INTMAX_MIN );
> >> > +  puts( "Invalid Input - Send NULL Pointer" );
> >> > +  result_strtoimax = strtoimax( NULL, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoimax == 0 );
> >> > +  rtems_test_assert( errno == EINVAL );
> >> > +  puts( "Invalid Input - Invalid base - Use base = 40" );
> >> > +  result_strtoimax = strtoimax( nptr1_p, &endptr1, invalid_base );
> >> > +  /*Test for strtoumax  */
> >> > +  puts( "\nstrtoumax Testcases...." );
> >> > +  result_strtoumax = strtoumax( nptr1_p, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoumax ==123 );
> >> > +  result_strtoumax = strtoumax( nptr1_n, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoumax != 0 );
> >> > +  result_strtoumax = strtoumax( nptr1_p_errange, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoumax == UINTMAX_MAX );
> >> > +  result_strtoumax = strtoumax( nptr1_n_errange, &endptr1, base );
> >> > +  result_strtoumax = strtoumax( NULL, &endptr1, base );
> >> > +  rtems_test_assert( result_strtoumax == 0 );
> >> > +  result_strtoumax = strtoumax( nptr1_p, &endptr1, invalid_base );
> >> > +  /*Test for wcstoimax  */
> >> > +  puts( "\nwcstoimax Testcases...." );
> >> > +  result_strtoimax = wcstoimax( nptr2_p, &endptr2, base );
> >> > +  rtems_test_assert( endptr2 == ( nptr2_p + 3 ) );
> >> > +  result_strtoimax = wcstoimax( nptr2_n, &endptr2, base );
> >> This should be like result_strtoimax == -123. ( one space between
> >> operator and and value)
> I think it does have one space between operator and value?
> >> > +  rtems_test_assert( endptr2 == ( nptr2_n + 4 ) );
> >> > +  result_strtoimax = wcstoimax( nptr2_p_errange, &endptr2, base );
> >> > +  result_strtoimax = wcstoimax( nptr2_n_errange, &endptr2, base );
> >> > +  rtems_test_assert( result_strtoimax != 0 );
> This looks wrong to me, please double check the spec for wcstoimax
Oh sorry, I mis read it for the case the wcstoumax. wcstoimax will return
INTMAX_MIN.
I have corrected it.
> >> > +  result_strtoimax = wcstoimax( NULL, &endptr2, base );
> >> > +  result_strtoimax = wcstoimax( nptr2_p, &endptr2, invalid_base );
> >> > +  /*Test for wcstoumax  */
> >> > +  puts( "\nwcstoumax Testcases...." );
> >> > +  result_strtoumax = wcstoumax( nptr2_p, &endptr2, base );
> >> > +  rtems_test_assert( result_strtoumax == 123 );
> >> > +  result_strtoumax = wcstoumax( nptr2_n, &endptr2, base );
> >> > +  result_strtoumax = wcstoumax( nptr2_p_errange, &endptr2, base );
> >> > +  result_strtoumax = wcstoumax( nptr2_n_errange, &endptr2, base );
> >> > +  result_strtoumax = wcstoumax( NULL, &endptr2, base );
> >> > +  result_strtoumax = wcstoumax( nptr2_p, &endptr2, invalid_base );
> >> > +  TEST_END();
> >> > +  rtems_test_exit(0);
> >> > +/* NOTICE: the clock driver is explicitly disabled */
> >> > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> >> > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> >> > +#define CONFIGURE_MAXIMUM_TASKS            1
> >> > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> >> > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> >> > +#include <rtems/confdefs.h>
> >> > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> >> > index 0000000000..b5fd8e6d0e
> >> > --- /dev/null
> >> > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> >> > @@ -0,0 +1,70 @@
> >> > + * Copyright (C) 2019, Vaibhav Gupta
> >> > + * are met:
> copyright
> in the
> distribution.
> TO, THE
> PARTICULAR PURPOSE
> CONTRIBUTORS BE
> OR
> OF
> BUSINESS
> WHETHER IN
> OTHERWISE)
> ADVISED OF THE
> Thought I already said to get rid of this license block? I don't think
> we include this in the .doc files...
Oh, I thought you meant to remove only @breif part.
> >> > +This File describes the concepts tested by this test suite.
> >> > +inttypes.h - fixed size integer types
> >> > +test suite name: PSXINTTYPE 01
> >> > +- Checks for invalid base value
> >> > +- Checks for Strtoimax Testcases
> >> > +       - checks for output for string having a positive number
> >> > +       - checks for output for string having a negative number
> >> > +       - checks for output for string having a positive number -
> Number Out of Range
> >> > +       - checks for output for string having a negative number -
> Number Out of Range
> >> > +       - checks for final string pointed by endptr
> >> > +       - checks for output for invalid argument - NULL Pointer
> >> > +       - checks for output for invalid argument - Invalid Base
> >> > +- Checks for Strtoumax Test Cases
> Number Out of Range
> Number Out of Range
> >> > +- Checks for Wcstoimax Testcases
> Number Out of Range
> Number Out of Range
> >> > +- Checks for Wcstoumax Testcases
> Number Out of Range
> Number Out of Range
> >> > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> >> > index 0000000000..33e82428f1
> >> > --- /dev/null
> >> > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> >> > @@ -0,0 +1,44 @@
> >> > +*** PSXINTTYPE 01 TEST ***
> >> > +strtoimax Testcases....
> >> > +Valid Inputs - Positive Number
> >> > +Final string pointed by endptr
> >> > +Valid Inputs - Negative Number
> >> > +Valid Input - Positive Number - Number out of Range
> >> > +Valid Input - Negative Number - Number out of Range
> >> > +Invalid Input - Send NULL Pointer
> >> > +Invalid Input - Invalid base - Use base = 40
> >> > +strtoumax Testcases....
> >> > +wcstoimax Testcases....
> >> > +wcstoumax Testcases....
> >> > +*** END OF PSXINTTYPE 01 TEST ***
> >> > 2.21.0
> >> You can also look into this:
> http://man7.org/linux/man-pages/man3/strtol.3.html
> >> Thanks,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190613/57ad798f/attachment-0002.html>
