[PATCH v3 2/2] Add Testsuite for PSXINTTYPES01
Thu Jun 13 18:57:11 UTC 2019
Hi Vaibhav,
On Thu, Jun 13, 2019, 11:51 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> Remove comments on variable declaration.
> Remove licence from Doc
> Correct the assert condition for wcstoimax for negative errange condition.
Please squash (git-rebase) the commits to make one, new commit with only
the necessary code. Send the new commit as -v2 patch. Thanks
 testsuites/psxtests/psxinttypes01/init.c      | 26 +++++++++---------
>  .../psxtests/psxinttypes01/psxinttypes01.doc  | 27 -------------------
>  2 files changed, 13 insertions(+), 40 deletions(-)
> diff --git a/testsuites/psxtests/psxinttypes01/init.c
> b/testsuites/psxtests/psxinttypes01/init.c
> index 8eafae11ac..94df8206c0 100644
> --- a/testsuites/psxtests/psxinttypes01/init.c
> +++ b/testsuites/psxtests/psxinttypes01/init.c
> @@ -52,16 +52,16 @@ rtems_task Init(rtems_task_argument ignored)
>    int       base            = 10;
>    int       invalid_base    = 40;
> -  char     *nptr1_p         = "123abc";
> //char* pointing to string with positive number
> -  char            *nptr1_p_errange = "9999999999999999999999";
>  //char* pointing to string with positive number that is out of range
> -  char     *nptr1_n         = "-123abc";                       //char*
> pointing to string with negative number
> -  char            *nptr1_n_errange = "-9999999999999999999999";
> //char* pointing to string with negative number that is out of range
> +  char     *nptr1_p         = "123abc";
> +  char            *nptr1_p_errange = "9999999999999999999999";
> +  char     *nptr1_n         = "-123abc";
> +  char            *nptr1_n_errange = "-9999999999999999999999";
>    char     *endptr1         = NULL;
> -  wchar_t  *nptr2_p         = L"123junk";                      //wchar_t*
> -  wchar_t  *nptr2_p_errange = L"9999999999999999999999";       //wchar_t*
> -  wchar_t  *nptr2_n         = L"-123junk";                     //wchar_t*
> -  wchar_t  *nptr2_n_errange = L"-9999999999999999999999";      //wchar_t*
> +  wchar_t  *nptr2_p         = L"123junk";
> +  wchar_t  *nptr2_p_errange = L"9999999999999999999999";
> +  wchar_t  *nptr2_n         = L"-123junk";
> +  wchar_t  *nptr2_n_errange = L"-9999999999999999999999";
>    wchar_t  *endptr2         = NULL;
>    intmax_t  result_strtoimax;
> @@ -69,7 +69,7 @@ rtems_task Init(rtems_task_argument ignored)
>    TEST_BEGIN();
> -  /*Test for strtoimax  */
> +  /* Test for strtoimax  */
>    puts( "\nstrtoimax Testcases...." );
>    puts( "Valid Inputs - Positive Number" );
>    result_strtoimax = strtoimax( nptr1_p, &endptr1, base );
> @@ -105,7 +105,7 @@ rtems_task Init(rtems_task_argument ignored)
>    rtems_test_assert( result_strtoimax == 0 );
>    rtems_test_assert( errno == EINVAL );
> -  /*Test for strtoumax  */
> +  /* Test for strtoumax  */
>    puts( "\nstrtoumax Testcases...." );
>    result_strtoumax = strtoumax( nptr1_p, &endptr1, base );
> @@ -141,7 +141,7 @@ rtems_task Init(rtems_task_argument ignored)
>    rtems_test_assert( result_strtoumax == 0 );
> -  /*Test for wcstoimax  */
> +  /* Test for wcstoimax  */
>    puts( "\nwcstoimax Testcases...." );
>    result_strtoimax = wcstoimax( nptr2_p, &endptr2, base );
> @@ -164,7 +164,7 @@ rtems_task Init(rtems_task_argument ignored)
>    puts( "Valid Input - Negative Number - Number out of Range" );
>    result_strtoimax = wcstoimax( nptr2_n_errange, &endptr2, base );
> -  rtems_test_assert( result_strtoimax != 0 );
> +  rtems_test_assert( result_strtoimax == INTMAX_MIN );
>    rtems_test_assert( errno == ERANGE );
>    puts( "Invalid Input - Send NULL Pointer" );
> @@ -177,7 +177,7 @@ rtems_task Init(rtems_task_argument ignored)
> -  /*Test for wcstoumax  */
> +  /* Test for wcstoumax  */
>    puts( "\nwcstoumax Testcases...." );
>    result_strtoumax = wcstoumax( nptr2_p, &endptr2, base );
> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> index b5fd8e6d0e..607d67015e 100644
> --- a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> @@ -1,30 +1,3 @@
> - * SPDX-License-Identifier: BSD-2-Clause
> - * Copyright (C) 2019, Vaibhav Gupta
> - * Redistribution and use in source and binary forms, with or without
> - * modification, are permitted provided that the following conditions
> - * are met:
> - * 1. Redistributions of source code must retain the above copyright
> - *    notice, this list of conditions and the following disclaimer.
> - * 2. Redistributions in binary form must reproduce the above copyright
> - *    notice, this list of conditions and the following disclaimer in the
> - *    documentation and/or other materials provided with the distribution.
> - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> - * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> - * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> - * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> - * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> - * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> - * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> - * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> - * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> - * POSSIBILITY OF SUCH DAMAGE.
>  This File describes the concepts tested by this test suite.
>  inttypes.h - fixed size integer types
> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190613/50b4890d/attachment-0002.html>
