Guidance to make Testsuites
Thu Jun 13 20:00:49 UTC 2019
On Thu, Jun 13, 2019 at 10:31 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com> wrote:
> Hello,
> To test the codes I have ported, it is necessary to make tesuites.
> I have compiled newlib for sparc and arm architecture and have
> kept them in separate folders.
> RTEMS is present in a different folder.
> I want to know how to use compiled newlib in RTEMS?
You can use the RSB with custom patches applied during the build
process. There is an example exactly about newlib in the docs, have a
read through: https://docs.rtems.org/branches/master/user/rsb/project-sets.html#patches
> Thank you
> Vaibhav Gupta
