[PATCH v2] Comment added
Ravindra Kumar Meena
rmeena840 at gmail.com
Mon Jun 17 10:50:02 UTC 2019
> > misc/CTF/record-ctf.ref | 55
> We should avoid uppercase or mix case in file names unless they are
> existing or
> in imported code. We have some hosts that are case insensitive and our
> experience over the years is this can cause problems. :)
Okay. I didn't know that. :)
> Is this file for the rtems-tools repo?
Yes
> If it is not please ignore the following.
> I wonder if there should be a top level trace directory to gather all the
> trace
> pieces in one place. I think trace is important enough to have this
> status. So
> this file could be ...
> trace/config/ctf/record-ctf.ref
> or
> trace/config/record-ctf.ref
It's metadata file for TSDL description. I will rename it to "metadata"
> ? This is only an example as I am not really sure what role this file
> plays.
> Notes:
> 1) I have found in other parts of rtems-tools.git having the config
> directory of
> files separated from the other sources makes installing into the shared
> tree
> simpler.
> 2) The tools currently in rtems-tools.git can be run with the same command
> line
> options from a built repo with an absolute path or when installed under a
> prefix. This is something to consider when referencing configuration files.
> Okay, Chris. Thanks for the review.
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190617/d029b45e/attachment-0002.html>
