Guidance to make Testsuites
Vaibhav Gupta vaibhavgupta40 at gmail.com
Thu Jun 20 11:29:21 UTC 2019
I checked that erc32 is using     rtems-sparc.bset      file
Inside it i found, it is using
rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f   file
I added following lines to
rsb/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
%prep
  %patch setup newlib -p1
%patch add newlib file://0001-Port-ndbm.patch
%hash sha512 0001-Port-ndbm.patch
0e05d97d0a6f8a436a233fe4fb3cbda7c0cfeab11cfda1c155d8aa5b80289f386896b0e8c28e5858e1d7409fd22c8d1cbaaccb181bc376845fe6d50b16359db6
And when I tried to build the tool-chain again using the command:
../source-builder/sb-set-builder --prefix=/home/varodek/development/rtems/5
5/rtems-sparc
It generated the following error report
RTEMS Tools Project - Source Builder Error Report
 Build: error: building
sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1
 Command Line: ../source-builder/sb-set-builder
--prefix=/home/varodek/development/rtems/5 5/rtems-sparc
 Python: 2.7.16 (default, Mar 11 2019, 18:59:25) [GCC 8.2.1 20181127]
 git://
git.rtems.org/rtems-source-builder.git/origin/780a2cf36c9c69e5e4c2393f8c0bbcf3854bbacf-modified
 Linux varodek 5.0.9-arch1-1-ARCH #1 SMP PREEMPT Sat Apr 20 15:00:46 UTC
2019 x86_64
Tail of the build log:
-rw-rw-r-- bodrato/bodrato    8702 2015-11-01 20:49
gmp-6.1.0/mpn/x86/pentium/mmx/lshift.asm
-rw-rw-r-- bodrato/bodrato    9481 2015-11-01 20:49
gmp-6.1.0/mpn/x86/pentium/mmx/rshift.asm
-rw-rw-r-- bodrato/bodrato    8228 2015-11-01 20:49
gmp-6.1.0/mpn/x86/pentium/mmx/mul_1.asm
-rw-rw-r-- bodrato/bodrato    9336 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k8/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    9888 2015-11-01 20:49
gmp-6.1.0/mpn/x86/bd1/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    6385 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/aors_n.asm
drwxrwxr-x bodrato/bodrato       0 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/k62mmx/
-rw-rw-r-- bodrato/bodrato   12512 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mul_basecase.asm
-rw-rw-r-- bodrato/bodrato    3379 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/pre_mod_1.asm
-rw-rw-r-- bodrato/bodrato    5161 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mul_1.asm
-rw-rw-r-- bodrato/bodrato   14082 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/sqr_basecase.asm
-rw-rw-r-- bodrato/bodrato    3928 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mod_34lsub1.asm
-rw-rw-r-- bodrato/bodrato    7537 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    9827 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/aorsmul_1.asm
-rw-rw-r-- bodrato/bodrato    4030 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mode1o.asm
-rw-rw-r-- bodrato/bodrato    4504 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/divrem_1.asm
-rw-rw-r-- bodrato/bodrato    6418 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/gcd_1.asm
-rwxrwxr-x bodrato/bodrato    5944 2015-11-01 20:49 gmp-6.1.0/mpn/x86/k6/
cross.pl
gmp-6.1.0/mpn/x86/k6/mmx/
-rw-rw-r-- bodrato/bodrato    8639 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/README
-rw-rw-r-- bodrato/bodrato    2318 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mmx/com.asm
-rw-rw-r-- bodrato/bodrato    2717 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mmx/rshift.asm
-rw-rw-r-- bodrato/bodrato    2701 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mmx/lshift.asm
-rw-rw-r-- bodrato/bodrato    6336 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mmx/logops_n.asm
-rw-rw-r-- bodrato/bodrato    5466 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mmx/dive_1.asm
-rw-rw-r-- bodrato/bodrato    4481 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/mmx/popham.asm
-rw-rw-r-- bodrato/bodrato    5647 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/k62mmx/lshift.asm
-rw-rw-r-- bodrato/bodrato    5687 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/k62mmx/rshift.asm
-rw-rw-r-- bodrato/bodrato    3070 2015-11-01 20:49
gmp-6.1.0/mpn/x86/k6/k62mmx/copyd.asm
-rw-rw-r-- bodrato/bodrato    2352 2015-11-01 20:49
gmp-6.1.0/mpn/x86/i486/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato   13769 2015-11-01 20:49
gmp-6.1.0/mpn/lisp/gmpasm-mode.el
-rw-rw-r-- bodrato/bodrato    3237 2015-11-01 20:49
gmp-6.1.0/mpn/power/addmul_1.asm
-rw-rw-r-- bodrato/bodrato    3030 2015-11-01 20:49
gmp-6.1.0/mpn/power/mul_1.asm
-rw-rw-r-- bodrato/bodrato    2587 2015-11-01 20:49
gmp-6.1.0/mpn/power/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    2823 2015-11-01 20:49
gmp-6.1.0/mpn/power/add_n.asm
-rw-rw-r-- bodrato/bodrato    1245 2015-11-01 20:49
gmp-6.1.0/mpn/power/sdiv.asm
-rw-rw-r-- bodrato/bodrato    2894 2015-11-01 20:49
gmp-6.1.0/mpn/power/sub_n.asm
-rw-rw-r-- bodrato/bodrato    3449 2015-11-01 20:49
gmp-6.1.0/mpn/power/submul_1.asm
-rw-rw-r-- bodrato/bodrato    1299 2015-11-01 20:49
gmp-6.1.0/mpn/power/umul.asm
-rw-rw-r-- bodrato/bodrato    2035 2015-11-01 20:49
gmp-6.1.0/mpn/power/rshift.asm
-rw-rw-r-- bodrato/bodrato    2016 2015-11-01 20:49
gmp-6.1.0/mpn/power/lshift.asm
-rw-rw-r-- bodrato/bodrato   20943 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/aors_n.asm
-rw-rw-r-- bodrato/bodrato    9372 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/README
-rw-rw-r-- bodrato/bodrato    3389 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/sec_tabselect.asm
-rw-rw-r-- bodrato/bodrato   15213 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/mul_2.asm
-rw-rw-r-- bodrato/bodrato    8416 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/lshiftc.asm
-rw-rw-r-- bodrato/bodrato    1587 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/aorsorrlsh2_n.asm
-rw-rw-r-- bodrato/bodrato    3404 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/copyi.asm
gmp-6.1.0/mpn/ia64/aorsorrlsh1_n.asm
-rw-rw-r-- bodrato/bodrato   10809 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/divrem_1.asm
-rw-rw-r-- bodrato/bodrato    4738 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/sqr_diag_addlsh1.asm
-rw-rw-r-- bodrato/bodrato    8349 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/add_n_sub_n.asm
-rw-rw-r-- bodrato/bodrato   17852 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/addmul_2.asm
-rw-rw-r-- bodrato/bodrato    6598 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/cnd_aors_n.asm
-rw-rw-r-- bodrato/bodrato   11463 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/rsh1aors_n.asm
-rw-rw-r-- bodrato/bodrato    7110 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/lorrshift.asm
-rw-rw-r-- bodrato/bodrato    7158 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/gcd_1.asm
-rw-rw-r-- bodrato/bodrato   13304 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/addmul_1.asm
-rw-rw-r-- bodrato/bodrato    9691 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    4543 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/popcount.asm
-rw-rw-r-- bodrato/bodrato    6524 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/divrem_2.asm
-rw-rw-r-- bodrato/bodrato    6782 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/dive_1.asm
-rw-rw-r-- bodrato/bodrato    4167 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/ia64-defs.m4
-rw-rw-r-- bodrato/bodrato    7174 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/logops_n.asm
-rw-rw-r-- bodrato/bodrato   11349 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/mode1o.asm
-rw-rw-r-- bodrato/bodrato   12629 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/submul_1.asm
-rw-rw-r-- bodrato/bodrato    3055 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/invert_limb.asm
-rw-rw-r-- bodrato/bodrato    9313 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/bdiv_dbm1c.asm
-rw-rw-r-- bodrato/bodrato    3568 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/copyd.asm
-rw-rw-r-- bodrato/bodrato    8357 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/hamdist.asm
-rw-rw-r-- bodrato/bodrato    9925 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/aorsorrlshC_n.asm
-rw-rw-r-- bodrato/bodrato   11545 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/mul_1.asm
-rw-rw-r-- bodrato/bodrato    5115 2015-11-01 20:49
gmp-6.1.0/mpn/ia64/mod_34lsub1.asm
gmp-6.1.0/mpn/x86_64/bobcat/
-rw-rw-r-- bodrato/bodrato    6455 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/divrem_1.asm
-rw-rw-r-- bodrato/bodrato    3930 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mul_1.asm
-rw-rw-r-- bodrato/bodrato    3022 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/invert_limb.asm
-rw-rw-r-- bodrato/bodrato    3500 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/sublsh1_n.asm
-rw-rw-r-- bodrato/bodrato    4074 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/div_qr_2u_pi1.asm
gmp-6.1.0/mpn/x86_64/bd1/
-rw-rw-r-- bodrato/bodrato    3606 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/addmul_2.asm
drwxrwxr-x bodrato/bodrato       0 2015-11-01 20:49 gmp-6.1.0/mpn/x86_64/k8/
-rw-rw-r-- bodrato/bodrato    3543 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/lshsub_n.asm
-rw-rw-r-- bodrato/bodrato    2224 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/missing-inline.m4
-rw-rw-r-- bodrato/bodrato    4225 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mod_34lsub1.asm
-rw-rw-r-- bodrato/bodrato    4526 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mod_1_2.asm
-rw-rw-r-- bodrato/bodrato    2242 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/darwin.m4
-rw-rw-r-- bodrato/bodrato    2120 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/copyd.asm
gmp-6.1.0/mpn/x86_64/fastavx/
gmp-6.1.0/mpn/x86_64/fastsse/
-rw-rw-r-- bodrato/bodrato    2697 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/README
-rw-rw-r-- bodrato/bodrato    4496 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/div_qr_1n_pi1.asm
gmp-6.1.0/mpn/x86_64/skylake/
gmp-6.1.0/mpn/x86_64/bd2/
-rw-rw-r-- bodrato/bodrato    3417 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aorrlshC_n.asm
-rw-rw-r-- bodrato/bodrato    2484 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/sqr_diag_addlsh1.asm
gmp-6.1.0/mpn/x86_64/lshift.asm
-rw-rw-r-- bodrato/bodrato    2302 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bdiv_dbm1c.asm
-rw-rw-r-- bodrato/bodrato    5082 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mod_1_4.asm
-rw-rw-r-- bodrato/bodrato    3834 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/rshift.asm
-rw-rw-r-- bodrato/bodrato    3541 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aors_n.asm
gmp-6.1.0/mpn/x86_64/nano/
-rw-rw-r-- bodrato/bodrato    1414 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/missing-call.m4
gmp-6.1.0/mpn/x86_64/atom/
-rw-rw-r-- bodrato/bodrato    4218 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aors_err1_n.asm
-rw-rw-r-- bodrato/bodrato    3666 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/sec_tabselect.asm
gmp-6.1.0/mpn/x86_64/mulx/
-rw-rw-r-- bodrato/bodrato    4024 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/gcd_1.asm
gmp-6.1.0/mpn/x86_64/coreinhm/
-rw-rw-r-- bodrato/bodrato    1670 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aorrlsh2_n.asm
gmp-6.1.0/mpn/x86_64/coreihwl/
-rw-rw-r-- bodrato/bodrato    3203 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/addaddmul_1msb0.asm
gmp-6.1.0/mpn/x86_64/pentium4/
-rw-rw-r-- bodrato/bodrato    3736 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bdiv_q_1.asm
gmp-6.1.0/mpn/x86_64/coreibwl/
-rw-rw-r-- bodrato/bodrato    3177 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/missing.asm
-rw-rw-r-- bodrato/bodrato    3264 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/div_qr_2n_pi1.asm
-rw-rw-r-- bodrato/bodrato    3080 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aors_err3_n.asm
-rw-rw-r-- bodrato/bodrato    3961 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aorsmul_1.asm
-rw-rw-r-- bodrato/bodrato    3875 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/popham.asm
-rw-rw-r-- bodrato/bodrato    3831 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aorrlsh1_n.asm
-rw-rw-r-- bodrato/bodrato   10572 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    9299 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/x86_64-defs.m4
-rw-rw-r-- bodrato/bodrato    3974 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mode1o.asm
-rw-rw-r-- bodrato/bodrato    1539 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/invert_limb_table.asm
-rw-rw-r-- bodrato/bodrato    4993 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mod_1_1.asm
-rw-rw-r-- bodrato/bodrato    2310 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/dos64.m4
-rw-rw-r-- bodrato/bodrato    2128 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/com.asm
-rw-rw-r-- bodrato/bodrato    4309 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/cnd_aors_n.asm
-rw-rw-r-- bodrato/bodrato    2104 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/copyi.asm
-rw-rw-r-- bodrato/bodrato    3506 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/dive_1.asm
-rw-rw-r-- bodrato/bodrato    4120 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/rsh1aors_n.asm
gmp-6.1.0/mpn/x86_64/fat/
-rw-rw-r-- bodrato/bodrato    3348 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aors_err2_n.asm
-rw-rw-r-- bodrato/bodrato    3923 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/lshiftc.asm
-rw-rw-r-- bodrato/bodrato    3870 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/aorrlsh_n.asm
-rw-rw-r-- bodrato/bodrato    3876 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/divrem_2.asm
gmp-6.1.0/mpn/x86_64/coreisbr/
-rw-rw-r-- bodrato/bodrato    3716 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mul_2.asm
gmp-6.1.0/mpn/x86_64/k10/
-rw-rw-r-- bodrato/bodrato    5083 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/logops_n.asm
gmp-6.1.0/mpn/x86_64/core2/
-rw-rw-r-- bodrato/bodrato    1472 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/sublsh2_n.asm
-rw-rw-r-- bodrato/bodrato    8230 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/redc_1.asm
-rw-rw-r-- bodrato/bodrato    3249 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/lshiftc.asm
-rw-rw-r-- bodrato/bodrato    1288 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/sec_tabselect.asm
gmp-6.1.0/mpn/x86_64/core2/aorrlsh1_n.asm
-rw-rw-r-- bodrato/bodrato   10986 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    3767 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/rsh1aors_n.asm
gmp-6.1.0/mpn/x86_64/core2/copyd.asm
-rw-rw-r-- bodrato/bodrato    1255 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/popcount.asm
-rw-rw-r-- bodrato/bodrato    4176 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/aors_err1_n.asm
gmp-6.1.0/mpn/x86_64/core2/aorrlsh2_n.asm
gmp-6.1.0/mpn/x86_64/core2/sublsh1_n.asm
-rw-rw-r-- bodrato/bodrato    1335 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/aorrlsh_n.asm
-rw-rw-r-- bodrato/bodrato    4126 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/gcd_1.asm
-rw-rw-r-- bodrato/bodrato   16719 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/mul_basecase.asm
-rw-rw-r-- bodrato/bodrato    7748 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/mullo_basecase.asm
-rw-rw-r-- bodrato/bodrato    3692 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/aorsmul_1.asm
-rw-rw-r-- bodrato/bodrato    3322 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/sublshC_n.asm
-rw-rw-r-- bodrato/bodrato    3092 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/rshift.asm
-rw-rw-r-- bodrato/bodrato    3162 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/lshift.asm
-rw-rw-r-- bodrato/bodrato    3036 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/aors_n.asm
gmp-6.1.0/mpn/x86_64/core2/copyi.asm
-rw-rw-r-- bodrato/bodrato    5007 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/divrem_1.asm
-rw-rw-r-- bodrato/bodrato   17381 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/core2/sqr_basecase.asm
gmp-6.1.0/mpn/x86_64/k10/sec_tabselect.asm
-rw-rw-r-- bodrato/bodrato    1305 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k10/lshiftc.asm
-rw-rw-r-- bodrato/bodrato    3288 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k10/popcount.asm
-rw-rw-r-- bodrato/bodrato   11388 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k10/gmp-mparam.h
gmp-6.1.0/mpn/x86_64/k10/gcd_1.asm
-rw-rw-r-- bodrato/bodrato    1302 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k10/rshift.asm
gmp-6.1.0/mpn/x86_64/k10/lshift.asm
gmp-6.1.0/mpn/x86_64/k10/hamdist.asm
-rw-rw-r-- bodrato/bodrato    3547 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/mul_1.asm
-rw-rw-r-- bodrato/bodrato    4083 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/rsh1aors_n.asm
-rw-rw-r-- bodrato/bodrato   11362 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    7403 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/mul_basecase.asm
-rw-rw-r-- bodrato/bodrato    3138 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/popcount.asm
gmp-6.1.0/mpn/x86_64/coreisbr/lshiftc.asm
-rw-rw-r-- bodrato/bodrato    1778 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/aorrlsh1_n.asm
gmp-6.1.0/mpn/x86_64/coreisbr/rshift.asm
gmp-6.1.0/mpn/x86_64/coreisbr/lshift.asm
-rw-rw-r-- bodrato/bodrato    4285 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/aors_n.asm
-rw-rw-r-- bodrato/bodrato    8965 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/sqr_basecase.asm
-rw-rw-r-- bodrato/bodrato    1857 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/aorrlsh2_n.asm
-rw-rw-r-- bodrato/bodrato    4933 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/aorrlsh_n.asm
-rw-rw-r-- bodrato/bodrato    6768 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/mullo_basecase.asm
-rw-rw-r-- bodrato/bodrato    3880 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/aorrlshC_n.asm
-rw-rw-r-- bodrato/bodrato   10034 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/redc_1.asm
-rw-rw-r-- bodrato/bodrato    4272 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/aorsmul_1.asm
gmp-6.1.0/mpn/x86_64/coreisbr/sec_tabselect.asm
-rw-rw-r-- bodrato/bodrato    4433 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/addmul_2.asm
-rw-rw-r-- bodrato/bodrato    3408 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/mul_2.asm
-rw-rw-r-- bodrato/bodrato    1278 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreisbr/divrem_1.asm
-rw-rw-r-- bodrato/bodrato    1059 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fat/redc_1.c
-rw-rw-r-- bodrato/bodrato    1063 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fat/mod_1.c
-rw-rw-r-- bodrato/bodrato    5648 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fat/fat_entry.asm
gmp-6.1.0/mpn/x86_64/fat/redc_2.c
-rw-rw-r-- bodrato/bodrato    2807 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fat/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    1075 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fat/mullo_basecase.c
-rw-rw-r-- bodrato/bodrato   11578 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fat/fat.c
-rw-rw-r-- bodrato/bodrato    1071 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fat/sqr_basecase.c
gmp-6.1.0/mpn/x86_64/fat/mul_basecase.c
-rw-rw-r-- bodrato/bodrato    7012 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreibwl/mul_basecase.asm
-rw-rw-r-- bodrato/bodrato    4161 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreibwl/mul_1.asm
-rw-rw-r-- bodrato/bodrato   11059 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreibwl/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    4539 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreibwl/addmul_1.asm
-rw-rw-r-- bodrato/bodrato   16373 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreibwl/sqr_basecase.asm
-rw-rw-r-- bodrato/bodrato    3711 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/lshiftc.asm
-rw-rw-r-- bodrato/bodrato    1256 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/popcount.asm
-rw-rw-r-- bodrato/bodrato   11243 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    1675 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/aorslsh2_n.asm
-rw-rw-r-- bodrato/bodrato    3369 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/mod_34lsub1.asm
-rw-rw-r-- bodrato/bodrato    6608 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/rsh1aors_n.asm
gmp-6.1.0/mpn/x86_64/pentium4/aorslsh1_n.asm
-rw-rw-r-- bodrato/bodrato    4172 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/aors_n.asm
-rw-rw-r-- bodrato/bodrato    3545 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/lshift.asm
-rw-rw-r-- bodrato/bodrato    3580 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/rshift.asm
-rw-rw-r-- bodrato/bodrato    4146 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/pentium4/aorslshC_n.asm
gmp-6.1.0/mpn/x86_64/pentium4/sec_tabselect.asm
-rw-rw-r-- bodrato/bodrato    4108 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/aorsmul_1.asm
-rw-rw-r-- bodrato/bodrato    3296 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/mul_1.asm
-rw-rw-r-- bodrato/bodrato    9556 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/sqr_basecase.asm
-rw-rw-r-- bodrato/bodrato   12256 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    7507 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/mul_basecase.asm
-rw-rw-r-- bodrato/bodrato    9057 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/redc_1.asm
-rw-rw-r-- bodrato/bodrato    4302 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/addmul_2.asm
-rw-rw-r-- bodrato/bodrato    7490 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/mullo_basecase.asm
-rw-rw-r-- bodrato/bodrato    3523 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreihwl/mul_2.asm
-rw-rw-r-- bodrato/bodrato   11384 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreinhm/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    1294 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreinhm/popcount.asm
-rw-rw-r-- bodrato/bodrato    1291 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreinhm/hamdist.asm
gmp-6.1.0/mpn/x86_64/coreinhm/sec_tabselect.asm
-rw-rw-r-- bodrato/bodrato    4825 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreinhm/aorrlsh_n.asm
-rw-rw-r-- bodrato/bodrato    3861 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreinhm/aorsmul_1.asm
-rw-rw-r-- bodrato/bodrato   10069 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/coreinhm/redc_1.asm
-rw-rw-r-- bodrato/bodrato    3673 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mulx/aorsmul_1.asm
gmp-6.1.0/mpn/x86_64/mulx/adx/
-rw-rw-r-- bodrato/bodrato    3344 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mulx/mul_1.asm
-rw-rw-r-- bodrato/bodrato    3412 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/mulx/adx/addmul_1.asm
-rw-rw-r-- bodrato/bodrato    3743 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/aorsmul_1.asm
-rw-rw-r-- bodrato/bodrato    3432 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/mul_2.asm
-rw-rw-r-- bodrato/bodrato    1301 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/dive_1.asm
gmp-6.1.0/mpn/x86_64/atom/copyi.asm
-rw-rw-r-- bodrato/bodrato   10466 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/redc_1.asm
-rw-rw-r-- bodrato/bodrato    3437 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/addmul_2.asm
-rw-rw-r-- bodrato/bodrato    1357 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/aors_n.asm
-rw-rw-r-- bodrato/bodrato    2590 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/lshift.asm
-rw-rw-r-- bodrato/bodrato    2526 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/rshift.asm
-rw-rw-r-- bodrato/bodrato    1238 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/popcount.asm
-rw-rw-r-- bodrato/bodrato   10240 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    4042 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/aorrlsh2_n.asm
-rw-rw-r-- bodrato/bodrato    5538 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/rsh1aors_n.asm
-rw-rw-r-- bodrato/bodrato    2657 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/lshiftc.asm
-rw-rw-r-- bodrato/bodrato    4847 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/sublsh1_n.asm
-rw-rw-r-- bodrato/bodrato    5102 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/aorrlsh1_n.asm
gmp-6.1.0/mpn/x86_64/atom/copyd.asm
gmp-6.1.0/mpn/x86_64/atom/com.asm
-rw-rw-r-- bodrato/bodrato    2966 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/atom/mul_1.asm
gmp-6.1.0/mpn/x86_64/nano/copyd.asm
-rw-rw-r-- bodrato/bodrato    3830 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/nano/dive_1.asm
gmp-6.1.0/mpn/x86_64/nano/copyi.asm
-rw-rw-r-- bodrato/bodrato   11861 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/nano/gmp-mparam.h
gmp-6.1.0/mpn/x86_64/nano/popcount.asm
gmp-6.1.0/mpn/x86_64/nano/gcd_1.asm
-rw-rw-r-- bodrato/bodrato   12816 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd2/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato   11156 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/skylake/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    4141 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/com.asm
-rw-rw-r-- bodrato/bodrato    5762 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/copyd-palignr.asm
-rw-rw-r-- bodrato/bodrato     603 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/README
-rw-rw-r-- bodrato/bodrato    3929 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/copyd.asm
gmp-6.1.0/mpn/x86_64/fastsse/copyi-palignr.asm
-rw-rw-r-- bodrato/bodrato    4656 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/lshiftc.asm
-rw-rw-r-- bodrato/bodrato    4520 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/sec_tabselect.asm
-rw-rw-r-- bodrato/bodrato    6834 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/com-palignr.asm
-rw-rw-r-- bodrato/bodrato    4524 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/lshiftc-movdqu2.asm
-rw-rw-r-- bodrato/bodrato    4368 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/lshift.asm
-rw-rw-r-- bodrato/bodrato    4561 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/rshift-movdqu2.asm
-rw-rw-r-- bodrato/bodrato    4335 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/lshift-movdqu2.asm
-rw-rw-r-- bodrato/bodrato    4392 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastsse/copyi.asm
gmp-6.1.0/mpn/x86_64/fastavx/copyi.asm
-rw-rw-r-- bodrato/bodrato    3795 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/fastavx/copyd.asm
-rw-rw-r-- bodrato/bodrato    9575 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k8/mulmid_basecase.asm
-rw-rw-r-- bodrato/bodrato    4602 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k8/div_qr_1n_pi1.asm
-rw-rw-r-- bodrato/bodrato   11524 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k8/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    4611 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k8/aorrlsh_n.asm
-rw-rw-r-- bodrato/bodrato   14488 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k8/sqr_basecase.asm
-rw-rw-r-- bodrato/bodrato    8007 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k8/mullo_basecase.asm
-rw-rw-r-- bodrato/bodrato   10545 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k8/redc_1.asm
-rw-rw-r-- bodrato/bodrato    8707 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/k8/mul_basecase.asm
-rw-rw-r-- bodrato/bodrato    1328 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/aorrlsh1_n.asm
gmp-6.1.0/mpn/x86_64/bd1/popcount.asm
-rw-rw-r-- bodrato/bodrato   11949 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    7587 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/mul_basecase.asm
-rw-rw-r-- bodrato/bodrato    3826 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/aorsmul_1.asm
-rw-rw-r-- bodrato/bodrato    3813 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/mul_1.asm
gmp-6.1.0/mpn/x86_64/bd1/copyd.asm
-rw-rw-r-- bodrato/bodrato    1280 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/sublsh1_n.asm
gmp-6.1.0/mpn/x86_64/bd1/hamdist.asm
gmp-6.1.0/mpn/x86_64/bd1/copyi.asm
-rw-rw-r-- bodrato/bodrato    1282 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/com.asm
-rw-rw-r-- bodrato/bodrato    3654 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/mul_2.asm
-rw-rw-r-- bodrato/bodrato     478 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bd1/README
gmp-6.1.0/mpn/x86_64/bd1/gcd_1.asm
gmp-6.1.0/mpn/x86_64/bd1/sec_tabselect.asm
-rw-rw-r-- bodrato/bodrato    3836 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bobcat/aorsmul_1.asm
-rw-rw-r-- bodrato/bodrato    8902 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bobcat/redc_1.asm
-rw-rw-r-- bodrato/bodrato    2101 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bobcat/copyd.asm
gmp-6.1.0/mpn/x86_64/bobcat/mul_1.asm
-rw-rw-r-- bodrato/bodrato   10461 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bobcat/gmp-mparam.h
-rw-rw-r-- bodrato/bodrato    3283 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bobcat/aors_n.asm
-rw-rw-r-- bodrato/bodrato    2143 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bobcat/copyi.asm
-rw-rw-r-- bodrato/bodrato    9865 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bobcat/sqr_basecase.asm
-rw-rw-r-- bodrato/bodrato    8739 2015-11-01 20:49
gmp-6.1.0/mpn/x86_64/bobcat/mul_basecase.asm
-rw-rw-r-- bodrato/bodrato    1577 2015-11-01 20:49
gmp-6.1.0/mpn/m88k/README
-rw-rw-r-- bodrato/bodrato    2928 2015-11-01 20:49
gmp-6.1.0/mpn/m88k/add_n.s
-rw-rw-r-- bodrato/bodrato    4316 2015-11-01 20:49
gmp-6.1.0/mpn/m88k/mul_1.s
-rw-rw-r-- bodrato/bodrato    2998 2015-11-01 20:49
gmp-6.1.0/mpn/m88k/sub_n.s
gmp-6.1.0/mpn/m88k/mc88110/
-rw-rw-r-- bodrato/bodrato    1823 2015-11-01 20:49
gmp-6.1.0/mpn/m88k/mc88110/mul_1.s
-rw-rw-r-- bodrato/bodrato    1794 2015-11-01 20:49
gmp-6.1.0/mpn/m88k/mc88110/addmul_1.s
-rw-rw-r-- bodrato/bodrato    6740 2015-11-01 20:49
gmp-6.1.0/mpn/m88k/mc88110/sub_n.S
-rw-rw-r-- bodrato/bodrato    5059 2015-11-01 20:49
gmp-6.1.0/mpn/m88k/mc88110/add_n.S
-rw-rw-r-- bodrato/bodrato    1653 2015-11-01 20:49
gmp-6.1.0/mpn/sh/add_n.asm
-rw-rw-r-- bodrato/bodrato    1665 2015-11-01 20:49
gmp-6.1.0/mpn/sh/sub_n.asm
drwxrwxr-x bodrato/bodrato       0 2015-11-01 20:49 gmp-6.1.0/mpn/sh/sh2/
-rw-rw-r-- bodrato/bodrato    1796 2015-11-01 20:49
gmp-6.1.0/mpn/sh/sh2/submul_1.asm
-rw-rw-r-- bodrato/bodrato    1696 2015-11-01 20:49
gmp-6.1.0/mpn/sh/sh2/mul_1.asm
-rw-rw-r-- bodrato/bodrato    1789 2015-11-01 20:49
gmp-6.1.0/mpn/sh/sh2/addmul_1.asm
-rw-rw-r-- bodrato/bodrato    1309 2015-11-01 20:49 gmp-6.1.0/scanf/fscanf.c
-rw-rw-r-- bodrato/bodrato    1747 2015-11-01 20:49
gmp-6.1.0/scanf/fscanffuns.c
-rw-rw-r-- bodrato/bodrato    1822 2015-11-01 20:49
gmp-6.1.0/scanf/vsscanf.c
-rw-rw-r-- bodrato/bodrato    1236 2015-11-01 20:49
gmp-6.1.0/scanf/vfscanf.c
-rw-rw-r-- bodrato/bodrato    1441 2015-11-01 20:49 gmp-6.1.0/scanf/sscanf.c
-rw-rw-r-- bodrato/bodrato    2546 2015-11-01 20:49
gmp-6.1.0/scanf/sscanffuns.c
-rw-rw-r-- bodrato/bodrato   18681 2015-11-01 20:49
gmp-6.1.0/scanf/Makefile.in
-rw-rw-r-- bodrato/bodrato   20908 2015-11-01 20:49 gmp-6.1.0/scanf/doscan.c
-rw-rw-r-- bodrato/bodrato    1299 2015-11-01 20:49 gmp-6.1.0/scanf/scanf.c
-rw-rw-r-- bodrato/bodrato    1227 2015-11-01 20:49 gmp-6.1.0/scanf/vscanf.c
-rw-rw-r-- bodrato/bodrato    1321 2015-11-01 20:49
gmp-6.1.0/scanf/Makefile.am
-rw-rw-r-- bodrato/bodrato    9434 2015-11-01 20:49
gmp-6.1.0/rand/randlc2x.c
-rw-rw-r-- bodrato/bodrato    2975 2015-11-01 20:49
gmp-6.1.0/rand/randlc2s.c
-rw-rw-r-- bodrato/bodrato    2584 2015-11-01 20:49 gmp-6.1.0/rand/randmui.c
-rw-rw-r-- bodrato/bodrato    1380 2015-11-01 20:49
gmp-6.1.0/rand/Makefile.am
-rw-rw-r-- bodrato/bodrato   15761 2015-11-01 20:49 gmp-6.1.0/rand/randmt.c
-rw-rw-r-- bodrato/bodrato    1404 2015-11-01 20:49 gmp-6.1.0/rand/rands.c
-rw-rw-r-- bodrato/bodrato    1692 2015-11-01 20:49 gmp-6.1.0/rand/randbui.c
-rw-rw-r-- bodrato/bodrato   18793 2015-11-01 20:49
gmp-6.1.0/rand/Makefile.in
-rw-rw-r-- bodrato/bodrato    1261 2015-11-01 20:49 gmp-6.1.0/rand/randsd.c
-rw-rw-r-- bodrato/bodrato    1223 2015-11-01 20:49 gmp-6.1.0/rand/randclr.c
-rw-rw-r-- bodrato/bodrato    1498 2015-11-01 20:49 gmp-6.1.0/rand/rand.c
-rw-rw-r-- bodrato/bodrato    1199 2015-11-01 20:49 gmp-6.1.0/rand/randdef.c
-rw-rw-r-- bodrato/bodrato    1334 2015-11-01 20:49
gmp-6.1.0/rand/randsdui.c
-rw-rw-r-- bodrato/bodrato    4499 2015-11-01 20:49 gmp-6.1.0/rand/randmts.c
-rw-rw-r-- bodrato/bodrato    1250 2015-11-01 20:49
gmp-6.1.0/rand/randiset.c
-rw-rw-r-- bodrato/bodrato    1662 2015-11-01 20:49 gmp-6.1.0/rand/randmt.h
-rw-rw-r-- bodrato/bodrato     100 2015-11-01 20:50 gmp-6.1.0/doc/stamp-vti
-rw-rw-r-- bodrato/bodrato   13299 2015-11-01 20:49
gmp-6.1.0/doc/configuration
-rw-rw-r-- bodrato/bodrato  448954 2015-11-01 20:49 gmp-6.1.0/doc/gmp.texi
-rw-rw-r-- bodrato/bodrato  298669 2015-11-01 20:50 gmp-6.1.0/doc/gmp.info-1
-rw-rw-r-- bodrato/bodrato    5908 2015-11-01 20:50 gmp-6.1.0/doc/gmp.info
-rw-rw-r-- bodrato/bodrato    1235 2015-11-01 20:49
gmp-6.1.0/doc/Makefile.am
-rw-rw-r-- bodrato/bodrato   51799 2015-11-01 20:49 gmp-6.1.0/doc/tasks.html
-rw-rw-r-- bodrato/bodrato   23522 2015-11-01 20:49
gmp-6.1.0/doc/projects.html
-rwxr-xr-x bodrato/bodrato    6047 2015-09-06 00:39 gmp-6.1.0/doc/mdate-sh
-rw-rw-r-- bodrato/bodrato  212169 2015-11-01 20:50 gmp-6.1.0/doc/gmp.info-2
-rw-rw-r-- bodrato/bodrato   27251 2015-11-01 20:49
gmp-6.1.0/doc/Makefile.in
-rw-rw-r-- bodrato/bodrato    4945 2015-11-01 20:49
gmp-6.1.0/doc/isa_abi_headache
-rw-r--r-- bodrato/bodrato  323102 2015-09-06 00:39
gmp-6.1.0/doc/texinfo.tex
gmp-6.1.0/doc/version.texi
-rw-rw-r-- bodrato/bodrato   23559 2015-11-01 20:49
gmp-6.1.0/doc/fdl-1.3.texi
+ cd gmp-6.1.0
+ /bin/chmod -R a+rX,g-w,o-w .
+ cd
/home/varodek/development/rtems/rsb/rtems/build/sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1
+ /bin/rm -f gcc-7.4.0/gmp
+ ln -s
/home/varodek/development/rtems/rsb/rtems/build/sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1/gmp-6.1.0
gcc-7.4.0/gmp
+ echo 'RTEMS 5, RSB 780a2cf36c9c69e5e4c2393f8c0bbcf3854bbacf-modified,
Newlib 1d35a003f'
+ cd gcc-7.4.0
+ contrib/gcc_update --touch
+ cd
+ /bin/cat
/home/varodek/development/rtems/rsb/rtems/patches/0001-Port-ndbm.patch
+ /usr/bin/patch -p3
patching file include/ndbm.h
can't find file to patch at input line 108
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/newlib/libc/search/Makefile.am
b/newlib/libc/search/Makefile.am
|index 98920c3f4..a61107fb9 100644
|--- a/newlib/libc/search/Makefile.am
|+++ b/newlib/libc/search/Makefile.am
File to patch:
Skip this patch? [y]
Skipping patch.
1 out of 1 hunk ignored
patching file search/ndbm.c
shell cmd failed: /bin/sh -ex
 /home/varodek/development/rtems/rsb/rtems/build/sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1/do-build
error: building sparc-rtems5-gcc-7.4.0-newlib-1d35a003f-x86_64-linux-gnu-1
Help me out please
Vaibhav gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190620/2ab3cb7c/attachment-0002.html>
