GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena rmeena840 at gmail.com
Thu Jun 20 12:27:07 UTC 2019
> >> This is very good news. Writing the event stream is the easy part. Just
> >> fwrite() the events in the modified print_item(). Your TSDL in the
> metadata
> >> file must describe this event stream.
> > Yes. That's what I am trying today. You suggested that I have to convert
> > client_item(see below)
> > typedef struct client_item {
> >  union {
> >    SLIST_ENTRY( client_item ) free_node;
> >    RB_ENTRY( client_item )    active_node;
> >  uint64_t                     ns;
> >  uint32_t                     cpu;
> >  rtems_record_event           event;
> >  uint64_t                     data;
> >  uint64_t                     counter;
> > } client_item;
> > to
> > typedef struct ctf_event {
> >  uint64_t                     ns;
> >  uint32_t                     cpu;
> >  uint64_t                     data;
> >  uint64_t                     counter;
> Please remove the counter. It is only used internally in the client.
> > } ctf_event;
> > I did that but rtems-tools build is failing because I think some part of
> > the codebase is dependent on
> > union {
> > How should I deal with it?
> Why do you want to change struct client_item? You should create a struct
> ctf_event variable in print_item() on the stack, initialize it with the
> values handed over in the client item and fwrite() it to the event stream.
 Okay. I have sent the patch. Although it's not working. I tried very much
but it was appending the events.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190620/64b51f5d/attachment-0002.html>
