[PATCH] Write event stream in file
Ravindra Kumar Meena rmeena840 at gmail.com
Tue Jun 25 07:48:57 UTC 2019
> >     Do you get compiler warnings with this version?
> > No I didn't get any compiler warning or error.
> How did you configure the build? Did you somehow disable the warnings?
> [242/254] Compiling misc/record/record-main.c
> ../misc/record/record-main.c: In function ‘print_item’:
> ../misc/record/record-main.c:152:14: warning: variable ‘seconds’ set but
> not used [-Wunused-but-set-variable]
>       uint32_t seconds;
> ../misc/record/record-main.c: In function ‘handler’:
> ../misc/record/record-main.c:161:14: warning: ‘ns’ may be used
> uninitialized in this function [-Wmaybe-uninitialized]
>     ctf_item.ns=ns;
> ../misc/record/record-main.c:149:12: note: ‘ns’ was declared here
>     uint32_t ns;
Okay. I also got these warnings after reconfiguring again. This can be
resolved if we remove the if block. I think there is no need for it now.
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190625/6a69041a/attachment-0002.html>
