GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena
rmeena840 at gmail.com
Tue Jun 25 12:39:00 UTC 2019
Hi Sebastian,
Like I said that all values are correct(ns, CPU, data) except
rtems_record_event. This is happening because of byte order issue.
This is the warning output of babeltrace
[warning] Unknown value 927712935936 in enum.
0 RTEMS_RECORDING_EVENT: { ns = 4281426372217274368, cpu = 0, events = (
<unknown> : container = 927712935936 ), data = 167837702 }
[warning] Unknown value 897648164864 in enum.
<unknown> : container = 897648164864 ), data = 32440 }
Whatever value is passed on "ctf_item.data=item->event;" is converted into
big-endian value. That's why it giving huge value e.g 897648164864. See the
above output.
If we change the byte order of 897648164864 then it will be 215 which is in
the range of 0 to 1023. This is what we want.
If we could pass the big-endian value on "ctf_item.data=item->event;" then
it will work fine. I intentionally tried to pass 897648164864 directly to
"ctf_item.data=item->event;" and it was working fine because its byte order
is changed and its new value will be 215.
I tried a few approaches but didn't work for me. Any idea how to deal with
it?
Thanks
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190625/7d9e918d/attachment-0002.html>
