[PATCH v2] Generated event stream metadata file
Ravindra Kumar Meena rmeena840 at gmail.com
Wed Jun 26 05:05:17 UTC 2019
> Is this working right? Please regenerate a single squashed patch.
> Check for git errors (no newline at end of file?)
> Just a thought, I'm not sure if it makes sense: Will we eventually
> need separate metadata files for each of the 4 kinds of record event
> layouts? 32b be, 32b le, 64b be, 64b le? if so, the file name should
> probably reflect the options, e.g., metadata-64b-be-record
Sorry, but file name cannot be renamed like this because babeltrace won't
be able to read the traces.
Babeltrace first looks for a file named metadata and then it looks for the
traces matching its description in the same directory.
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190626/5043deed/attachment-0002.html>
