[PATCH v2] port ndbm
Vaibhav Gupta vaibhavgupta40 at gmail.com
Wed Jun 26 15:11:39 UTC 2019
On Wed, Jun 26, 2019 at 8:35 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> Hello,
> Newlib is compiling successfully.
> But when i applied patch to RSB. It is not generating     ndbm.h
> inside   rtems/5/sparc-rtem5/include     this time.
> I am following same steps again which I followed that day when ndbm.h was
> successfully generated.
> Below are the log files generated by rsb build.
Although, before testing, I update RSB today    (git pull). I figured that
the configuration file, used by rsb for newlib, is now changed.
So i updated my steps accordingly. That is, I added the patch in that new
configuration file.
According to logs, patch is applied I guess, but it is not generating
ndbm.h   in include directory.
> On Wed, Jun 26, 2019 at 8:32 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>>  newlib/libc/include/ndbm.h     |  84 +++++++++++++
>>  newlib/libc/search/Makefile.am |   1 +
>>  newlib/libc/search/ndbm.c      | 215 +++++++++++++++++++++++++++++++++
>>  3 files changed, 300 insertions(+)
>>  create mode 100644 newlib/libc/include/ndbm.h
>>  create mode 100644 newlib/libc/search/ndbm.c
>> diff --git a/newlib/libc/include/ndbm.h b/newlib/libc/include/ndbm.h
>> new file mode 100644
>> index 000000000..3b42c60b0
>> --- /dev/null
>> +++ b/newlib/libc/include/ndbm.h
>> @@ -0,0 +1,84 @@
>> + * SPDX-License-Identifier: BSD-3-Clause
>> + * Copyright (c) 1990, 1993
>> + *     The Regents of the University of California.  All rights reserved.
>> + * This code is derived from software contributed to Berkeley by
>> + * Margo Seltzer.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the
>> distribution.
>> + * 3. Neither the name of the University nor the names of its
>> contributors
>> + *    may be used to endorse or promote products derived from this
>> software
>> + *    without specific prior written permission.
>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS''
>> AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE
>> LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
>> GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
>> STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
>> WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + *     @(#)ndbm.h      8.1 (Berkeley) 6/2/93
>> + * $FreeBSD$
>> +#ifndef _NDBM_H_
>> +#define        _NDBM_H_
>> +#define __DBINTERFACE_PRIVATE
>> +/* Map dbm interface onto db(3). */
>> +#define DBM_RDONLY     O_RDONLY
>> +/* Flags to dbm_store(). */
>> +#define DBM_INSERT      0
>> +#define DBM_REPLACE     1
>> + * The db(3) support for ndbm always appends this suffix to the
>> + * file name to avoid overwriting the user's original database.
>> +#define        DBM_SUFFIX      ".db"
>> +typedef struct {
>> +       void *dptr;
>> +       int dsize;      /* XXX Should be size_t according to 1003.1-2008.
>> +} datum;
>> +struct __db;
>> +typedef struct __db DB;
>> +typedef DB DBM;
>> +#define        dbm_pagfno(a)   DBM_PAGFNO_NOT_AVAILABLE
>> +__BEGIN_DECLS
>> +int     dbm_clearerr(DBM *);
>> +void    dbm_close(DBM *);
>> +int     dbm_delete(DBM *, datum);
>> +int     dbm_error(DBM *);
>> +datum   dbm_fetch(DBM *, datum);
>> +datum   dbm_firstkey(DBM *);
>> +#if __BSD_VISIBLE
>> +long    dbm_forder(DBM *, datum);
>> +#endif
>> +datum   dbm_nextkey(DBM *);
>> +DBM    *dbm_open(const char *, int, mode_t);
>> +int     dbm_store(DBM *, datum, datum, int);
>> +#if __BSD_VISIBLE
>> +int     dbm_dirfno(DBM *);
>> +#endif
>> +__END_DECLS
>> +#endif /* !_NDBM_H_ */
>> diff --git a/newlib/libc/search/Makefile.am
>> b/newlib/libc/search/Makefile.am
>> index 98920c3f4..a61107fb9 100644
>> --- a/newlib/libc/search/Makefile.am
>> +++ b/newlib/libc/search/Makefile.am
>> @@ -9,6 +9,7 @@ GENERAL_SOURCES = \
>>         db_local.h \
>>         extern.h \
>>         hash.h \
>> +       ndbm.c \
>>         page.h \
>>         qsort.c
>> diff --git a/newlib/libc/search/ndbm.c b/newlib/libc/search/ndbm.c
>> index 000000000..8ac6d1f40
>> --- /dev/null
>> +++ b/newlib/libc/search/ndbm.c
>> @@ -0,0 +1,215 @@
>> + * Margo Seltzer.
>> + * are met:
>> distribution.
>> contributors
>> software
>> AND
>> PURPOSE
>> LIABLE
>> CONSEQUENTIAL
>> GOODS
>> STRICT
>> WAY
>> + * SUCH DAMAGE.
>> +#if defined(LIBC_SCCS) && !defined(lint)
>> +static char sccsid[] = "@(#)ndbm.c     8.4 (Berkeley) 7/21/94";
>> +#endif /* LIBC_SCCS and not lint */
>> +#include <sys/cdefs.h>
>> +__FBSDID("$FreeBSD$");
>> + * This package provides a dbm compatible interface to the new hashing
>> + * package described in db(3).
>> +#include <sys/param.h>
>> +#include <stdio.h>
>> +#include <string.h>
>> +#include <errno.h>
>> +#include <ndbm.h>
>> +#include "db_local.h"
>> +#include "hash.h"
>> + * Returns:
>> + *     *DBM on success
>> + *      NULL on failure
>> +extern DBM *
>> +dbm_open(const char *file, int flags, mode_t mode)
>> +       HASHINFO info;
>> +       char path[MAXPATHLEN];
>> +       info.bsize = 4096;
>> +       info.ffactor = 40;
>> +       info.nelem = 1;
>> +       info.cachesize = 0;
>> +       info.hash = NULL;
>> +       info.lorder = 0;
>> +       if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
>> +               errno = ENAMETOOLONG;
>> +               return(NULL);
>> +       (void)strcpy(path, file);
>> +       (void)strcat(path, DBM_SUFFIX);
>> +       return ((DBM *)__hash_open(path, flags, mode, 0, &info));
>> +extern void
>> +dbm_close(DBM *db)
>> +       (void)(db->close)(db);
>> + * Returns:
>> + *     DATUM on success
>> + *     NULL on failure
>> +extern datum
>> +dbm_fetch(DBM *db, datum key)
>> +       datum retdata;
>> +       int status;
>> +       DBT dbtkey, dbtretdata;
>> +       dbtkey.data = key.dptr;
>> +       dbtkey.size = key.dsize;
>> +       status = (db->get)(db, &dbtkey, &dbtretdata, 0);
>> +       if (status) {
>> +               dbtretdata.data = NULL;
>> +               dbtretdata.size = 0;
>> +       retdata.dptr = dbtretdata.data;
>> +       retdata.dsize = dbtretdata.size;
>> +       return (retdata);
>> + * Returns:
>> + *     NULL on failure
>> +extern datum
>> +dbm_firstkey(DBM *db)
>> +       int status;
>> +       datum retkey;
>> +       DBT dbtretkey, dbtretdata;
>> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
>> +       if (status)
>> +               dbtretkey.data = NULL;
>> +       retkey.dptr = dbtretkey.data;
>> +       retkey.dsize = dbtretkey.size;
>> +       return (retkey);
>> + * Returns:
>> + *     NULL on failure
>> +extern datum
>> +dbm_nextkey(DBM *db)
>> +       int status;
>> +       datum retkey;
>> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
>> +       if (status)
>> +       return (retkey);
>> + * Returns:
>> + *      0 on success
>> + *     <0 failure
>> +extern int
>> +dbm_delete(DBM *db, datum key)
>> +       int status;
>> +       DBT dbtkey;
>> +       status = (db->del)(db, &dbtkey, 0);
>> +       if (status)
>> +               return (-1);
>> +       else
>> +               return (0);
>> + * Returns:
>> + *      0 on success
>> + *     <0 failure
>> + *      1 if DBM_INSERT and entry exists
>> +extern int
>> +dbm_store(DBM *db, datum key, datum data, int flags)
>> +       DBT dbtkey, dbtdata;
>> +       dbtdata.data = data.dptr;
>> +       dbtdata.size = data.dsize;
>> +       return ((db->put)(db, &dbtkey, &dbtdata,
>> +           (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
>> +extern int
>> +dbm_error(DBM *db)
>> +       HTAB *hp;
>> +       hp = (HTAB *)db->internal;
>> +       return (hp->error);
>> +extern int
>> +dbm_clearerr(DBM *db)
>> +       HTAB *hp;
>> +       hp->error = 0;
>> +       return (0);
>> +extern int
>> +dbm_dirfno(DBM *db)
>> +       return(((HTAB *)db->internal)->fp);
>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190626/464ce5b2/attachment-0002.html>
