[PATCH v2] port ndbm
Vaibhav Gupta vaibhavgupta40 at gmail.com
Thu Jun 27 06:23:14 UTC 2019
I even tried:
$ cd
/home/varodek/development/newlib/b-sparc-rtems5-newlib/sparc-rtems5/newlib/libc/posix
$ sparc-rtems5-nm -A ./*.o | grep lib_a-ndbm.o
Output <<
./lib_a-ndbm.o:00000000 T dbm_clearerr
./lib_a-ndbm.o:00000000 T dbm_close
./lib_a-ndbm.o:00000000 T dbm_delete
./lib_a-ndbm.o:00000000 T dbm_dirfno
./lib_a-ndbm.o:00000000 T dbm_error
./lib_a-ndbm.o:00000000 T dbm_fetch
./lib_a-ndbm.o:00000000 T dbm_firstkey
./lib_a-ndbm.o:00000000 T dbm_nextkey
./lib_a-ndbm.o:00000000 T dbm_open
./lib_a-ndbm.o:00000000 T dbm_store
./lib_a-ndbm.o:         U __errno
./lib_a-ndbm.o:         U __hash_open
./lib_a-ndbm.o:         U strcat
./lib_a-ndbm.o:         U strcpy
./lib_a-ndbm.o:         U strlen
On Thu, Jun 27, 2019 at 11:51 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> On Thu, Jun 27, 2019 at 11:24 AM Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
>> On Thu, Jun 27, 2019 at 11:14 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>> > On Thu, Jun 27, 2019 at 10:08 AM Aditya Upadhyay <aadit0402 at gmail.com>
>> wrote:
>> >> On Thu, Jun 27, 2019 at 2:11 AM Vaibhav Gupta <
>> vaibhavgupta40 at gmail.com> wrote:
>> >> > Hello Gedare,
>> >> > as you suggested, to use the group name of patch as 'newlib'.
>> >> > I did that and then removed the line    "%patch setup newlib -p1"
>> >> > It has generated ndbm.h in include directory.
>> >> You are applying the patches to RSB just for testing purpose. It would
>> >> not show your contribution.
>> >> This will only help you to tests your methods what you will be going
>> >> to contribute to newlib.
>> >> So figuring out the solution of this old header replacement or
>> >> updating headers and submitting the patches to
>> >> the newlib is recommended.
>> > Sure, I will complete the testsuite as soon as possible and then push
>> the patch to newlib.
>> First you will have to figure out the dependecies between headers,
>> only then you would be able to
>> send the right patches. Otherwise You have to make much changes in your
>> patch.
>> >> I appreciate your effort. Have you figured out how would you be going
>> >> to write the test cases for ndbm and ftw methods?
>> > I did tried to check for the ndbm using raw ndbm methods in
>> testsuites/samples/hello/init.c:
>> https://github.com/VARoDeK/rtems/blob/test_ndbm_presence/testsuites/samples/hello/init.c
>> You will have to write test cases in psxtests directory by following
>> this open group page:
>> https://pubs.opengroup.org/onlinepubs/9699919799/functions/dbm_clearerr.html
>> > It showing the error:
>> /home/varodek/development/rtems/5/lib/gcc/sparc-rtems5/7.4.1/../../../../sparc-rtems5/bin/ld:
>> hello/hello-init.o: in function `Init':
>> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:41:
>> undefined reference to `dbm_open'
>> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:42:
>> undefined reference to `dbm_store'
>> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:45:
>> undefined reference to `dbm_fetch'
>> /home/varodek/development/rtems/kernel/rtems/c/src/../../testsuites/samples/hello/init.c:49:
>> undefined reference to `dbm_close'
>> Can you check whether function symbol is getting generated or not?
>> Like when you compile newlib, You can see that function symbol
>> using this command:
>> $sparc-rtems5-nm `find . -name lib_a-ndbm.o` This command will list
>> the function symbol.
> When I made changes in Newlib-cygwin, and compiled it in
> b-sparc-rtems5-newlib.
> I checked for function symbols using commnad :
> $ cd
> $ nm -A ./*.o | grep dbm_close
> output<< ./lib_a-ndbm.o:00000000 T dbm_close
>> >> > Vaibhav Gupta
>> >> > On Wed, Jun 26, 2019 at 8:41 PM Vaibhav Gupta <
>> >> >> On Wed, Jun 26, 2019 at 8:35 PM Vaibhav Gupta <
>> >> >>> Hello,
>> >> >>> Newlib is compiling successfully.
>> >> >>> But when i applied patch to RSB. It is not generating     ndbm.h
>>    inside   rtems/5/sparc-rtem5/include     this time.
>> >> >>> I am following same steps again which I followed that day when
>> ndbm.h was successfully generated.
>> >> >>> Below are the log files generated by rsb build.
>> >> >> Although, before testing, I update RSB today    (git pull). I
>> figured that the configuration file, used by rsb for newlib, is now changed.
>> >> >> So i updated my steps accordingly. That is, I added the patch in
>> that new configuration file.
>> >> >> According to logs, patch is applied I guess, but it is not
>> generating    ndbm.h   in include directory.
>> >> >>> On Wed, Jun 26, 2019 at 8:32 PM Vaibhav Gupta <
>> >> >>>>  newlib/libc/include/ndbm.h     |  84 +++++++++++++
>> >> >>>>  newlib/libc/search/Makefile.am |   1 +
>> >> >>>>  newlib/libc/search/ndbm.c      | 215
>> >> >>>>  3 files changed, 300 insertions(+)
>> >> >>>>  create mode 100644 newlib/libc/include/ndbm.h
>> >> >>>>  create mode 100644 newlib/libc/search/ndbm.c
>> >> >>>> diff --git a/newlib/libc/include/ndbm.h
>> b/newlib/libc/include/ndbm.h
>> >> >>>> new file mode 100644
>> >> >>>> index 000000000..3b42c60b0
>> >> >>>> --- /dev/null
>> >> >>>> +++ b/newlib/libc/include/ndbm.h
>> >> >>>> @@ -0,0 +1,84 @@
>> >> >>>> + * SPDX-License-Identifier: BSD-3-Clause
>> >> >>>> + * Copyright (c) 1990, 1993
>> >> >>>> + *     The Regents of the University of California.  All rights
>> reserved.
>> >> >>>> + * This code is derived from software contributed to Berkeley by
>> >> >>>> + * Margo Seltzer.
>> >> >>>> + * Redistribution and use in source and binary forms, with or
>> without
>> >> >>>> + * modification, are permitted provided that the following
>> conditions
>> >> >>>> + * are met:
>> >> >>>> + * 1. Redistributions of source code must retain the above
>> copyright
>> >> >>>> + *    notice, this list of conditions and the following
>> disclaimer.
>> >> >>>> + * 2. Redistributions in binary form must reproduce the above
>> copyright
>> disclaimer in the
>> >> >>>> + *    documentation and/or other materials provided with the
>> distribution.
>> >> >>>> + * 3. Neither the name of the University nor the names of its
>> contributors
>> >> >>>> + *    may be used to endorse or promote products derived from
>> this software
>> >> >>>> + *    without specific prior written permission.
>> >> >>>> + * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS
>> ``AS IS'' AND
>> >> >>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> TO, THE
>> >> >>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>> PARTICULAR PURPOSE
>> >> >>>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR
>> CONTRIBUTORS BE LIABLE
>> >> >>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> CONSEQUENTIAL
>> >> >>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> SUBSTITUTE GOODS
>> >> >>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> INTERRUPTION)
>> >> >>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> CONTRACT, STRICT
>> >> >>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> ARISING IN ANY WAY
>> >> >>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> POSSIBILITY OF
>> >> >>>> + * SUCH DAMAGE.
>> >> >>>> + *     @(#)ndbm.h      8.1 (Berkeley) 6/2/93
>> >> >>>> + * $FreeBSD$
>> >> >>>> +#ifndef _NDBM_H_
>> >> >>>> +#define        _NDBM_H_
>> >> >>>> +#define __DBINTERFACE_PRIVATE
>> >> >>>> +/* Map dbm interface onto db(3). */
>> >> >>>> +#define DBM_RDONLY     O_RDONLY
>> >> >>>> +/* Flags to dbm_store(). */
>> >> >>>> +#define DBM_INSERT      0
>> >> >>>> +#define DBM_REPLACE     1
>> >> >>>> + * The db(3) support for ndbm always appends this suffix to the
>> >> >>>> + * file name to avoid overwriting the user's original database.
>> >> >>>> +#define        DBM_SUFFIX      ".db"
>> >> >>>> +typedef struct {
>> >> >>>> +       void *dptr;
>> >> >>>> +       int dsize;      /* XXX Should be size_t according to
>> 1003.1-2008. */
>> >> >>>> +} datum;
>> >> >>>> +struct __db;
>> >> >>>> +typedef struct __db DB;
>> >> >>>> +typedef DB DBM;
>> >> >>>> +#define        dbm_pagfno(a)   DBM_PAGFNO_NOT_AVAILABLE
>> >> >>>> +__BEGIN_DECLS
>> >> >>>> +int     dbm_clearerr(DBM *);
>> >> >>>> +void    dbm_close(DBM *);
>> >> >>>> +int     dbm_delete(DBM *, datum);
>> >> >>>> +int     dbm_error(DBM *);
>> >> >>>> +datum   dbm_fetch(DBM *, datum);
>> >> >>>> +datum   dbm_firstkey(DBM *);
>> >> >>>> +#if __BSD_VISIBLE
>> >> >>>> +long    dbm_forder(DBM *, datum);
>> >> >>>> +#endif
>> >> >>>> +datum   dbm_nextkey(DBM *);
>> >> >>>> +DBM    *dbm_open(const char *, int, mode_t);
>> >> >>>> +int     dbm_store(DBM *, datum, datum, int);
>> >> >>>> +#if __BSD_VISIBLE
>> >> >>>> +int     dbm_dirfno(DBM *);
>> >> >>>> +#endif
>> >> >>>> +__END_DECLS
>> >> >>>> +#endif /* !_NDBM_H_ */
>> >> >>>> diff --git a/newlib/libc/search/Makefile.am
>> b/newlib/libc/search/Makefile.am
>> >> >>>> index 98920c3f4..a61107fb9 100644
>> >> >>>> --- a/newlib/libc/search/Makefile.am
>> >> >>>> +++ b/newlib/libc/search/Makefile.am
>> >> >>>> @@ -9,6 +9,7 @@ GENERAL_SOURCES = \
>> >> >>>>         db_local.h \
>> >> >>>>         extern.h \
>> >> >>>>         hash.h \
>> >> >>>> +       ndbm.c \
>> >> >>>>         page.h \
>> >> >>>>         qsort.c
>> >> >>>> diff --git a/newlib/libc/search/ndbm.c b/newlib/libc/search/ndbm.c
>> >> >>>> index 000000000..8ac6d1f40
>> >> >>>> --- /dev/null
>> >> >>>> +++ b/newlib/libc/search/ndbm.c
>> >> >>>> @@ -0,0 +1,215 @@
>> reserved.
>> >> >>>> + * Margo Seltzer.
>> without
>> conditions
>> >> >>>> + * are met:
>> copyright
>> disclaimer.
>> copyright
>> disclaimer in the
>> distribution.
>> contributors
>> this software
>> ``AS IS'' AND
>> TO, THE
>> PARTICULAR PURPOSE
>> CONSEQUENTIAL
>> SUBSTITUTE GOODS
>> INTERRUPTION)
>> CONTRACT, STRICT
>> ARISING IN ANY WAY
>> POSSIBILITY OF
>> >> >>>> + * SUCH DAMAGE.
>> >> >>>> +#if defined(LIBC_SCCS) && !defined(lint)
>> >> >>>> +static char sccsid[] = "@(#)ndbm.c     8.4 (Berkeley) 7/21/94";
>> >> >>>> +#endif /* LIBC_SCCS and not lint */
>> >> >>>> +#include <sys/cdefs.h>
>> >> >>>> +__FBSDID("$FreeBSD$");
>> >> >>>> + * This package provides a dbm compatible interface to the new
>> hashing
>> >> >>>> + * package described in db(3).
>> >> >>>> +#include <sys/param.h>
>> >> >>>> +#include <stdio.h>
>> >> >>>> +#include <string.h>
>> >> >>>> +#include <errno.h>
>> >> >>>> +#include <ndbm.h>
>> >> >>>> +#include "db_local.h"
>> >> >>>> +#include "hash.h"
>> >> >>>> + * Returns:
>> >> >>>> + *     *DBM on success
>> >> >>>> + *      NULL on failure
>> >> >>>> +extern DBM *
>> >> >>>> +dbm_open(const char *file, int flags, mode_t mode)
>> >> >>>> +       HASHINFO info;
>> >> >>>> +       char path[MAXPATHLEN];
>> >> >>>> +       info.bsize = 4096;
>> >> >>>> +       info.ffactor = 40;
>> >> >>>> +       info.nelem = 1;
>> >> >>>> +       info.cachesize = 0;
>> >> >>>> +       info.hash = NULL;
>> >> >>>> +       info.lorder = 0;
>> >> >>>> +       if( strlen(file) >= sizeof(path) - strlen(DBM_SUFFIX)) {
>> >> >>>> +               errno = ENAMETOOLONG;
>> >> >>>> +               return(NULL);
>> >> >>>> +       (void)strcpy(path, file);
>> >> >>>> +       (void)strcat(path, DBM_SUFFIX);
>> >> >>>> +       return ((DBM *)__hash_open(path, flags, mode, 0, &info));
>> >> >>>> +extern void
>> >> >>>> +dbm_close(DBM *db)
>> >> >>>> +       (void)(db->close)(db);
>> >> >>>> + * Returns:
>> >> >>>> + *     DATUM on success
>> >> >>>> + *     NULL on failure
>> >> >>>> +extern datum
>> >> >>>> +dbm_fetch(DBM *db, datum key)
>> >> >>>> +       datum retdata;
>> >> >>>> +       int status;
>> >> >>>> +       DBT dbtkey, dbtretdata;
>> >> >>>> +       dbtkey.data = key.dptr;
>> >> >>>> +       dbtkey.size = key.dsize;
>> >> >>>> +       status = (db->get)(db, &dbtkey, &dbtretdata, 0);
>> >> >>>> +       if (status) {
>> >> >>>> +               dbtretdata.data = NULL;
>> >> >>>> +               dbtretdata.size = 0;
>> >> >>>> +       retdata.dptr = dbtretdata.data;
>> >> >>>> +       retdata.dsize = dbtretdata.size;
>> >> >>>> +       return (retdata);
>> >> >>>> + * Returns:
>> >> >>>> + *     NULL on failure
>> >> >>>> +extern datum
>> >> >>>> +dbm_firstkey(DBM *db)
>> >> >>>> +       int status;
>> >> >>>> +       datum retkey;
>> >> >>>> +       DBT dbtretkey, dbtretdata;
>> >> >>>> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_FIRST);
>> >> >>>> +       if (status)
>> >> >>>> +               dbtretkey.data = NULL;
>> >> >>>> +       retkey.dptr = dbtretkey.data;
>> >> >>>> +       retkey.dsize = dbtretkey.size;
>> >> >>>> +       return (retkey);
>> >> >>>> + * Returns:
>> >> >>>> + *     NULL on failure
>> >> >>>> +extern datum
>> >> >>>> +dbm_nextkey(DBM *db)
>> >> >>>> +       int status;
>> >> >>>> +       datum retkey;
>> >> >>>> +       status = (db->seq)(db, &dbtretkey, &dbtretdata, R_NEXT);
>> >> >>>> +       if (status)
>> >> >>>> +       return (retkey);
>> >> >>>> + * Returns:
>> >> >>>> + *      0 on success
>> >> >>>> + *     <0 failure
>> >> >>>> +extern int
>> >> >>>> +dbm_delete(DBM *db, datum key)
>> >> >>>> +       int status;
>> >> >>>> +       DBT dbtkey;
>> >> >>>> +       status = (db->del)(db, &dbtkey, 0);
>> >> >>>> +       if (status)
>> >> >>>> +               return (-1);
>> >> >>>> +       else
>> >> >>>> +               return (0);
>> >> >>>> + * Returns:
>> >> >>>> + *      0 on success
>> >> >>>> + *     <0 failure
>> >> >>>> + *      1 if DBM_INSERT and entry exists
>> >> >>>> +extern int
>> >> >>>> +dbm_store(DBM *db, datum key, datum data, int flags)
>> >> >>>> +       DBT dbtkey, dbtdata;
>> >> >>>> +       dbtdata.data = data.dptr;
>> >> >>>> +       dbtdata.size = data.dsize;
>> >> >>>> +       return ((db->put)(db, &dbtkey, &dbtdata,
>> >> >>>> +           (flags == DBM_INSERT) ? R_NOOVERWRITE : 0));
>> >> >>>> +extern int
>> >> >>>> +dbm_error(DBM *db)
>> >> >>>> +       HTAB *hp;
>> >> >>>> +       hp = (HTAB *)db->internal;
>> >> >>>> +       return (hp->error);
>> >> >>>> +extern int
>> >> >>>> +dbm_clearerr(DBM *db)
>> >> >>>> +       HTAB *hp;
>> >> >>>> +       hp->error = 0;
>> >> >>>> +       return (0);
>> >> >>>> +extern int
>> >> >>>> +dbm_dirfno(DBM *db)
>> >> >>>> +       return(((HTAB *)db->internal)->fp);
>> >> >>>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190627/b71ab9b1/attachment-0002.html>
