GSoC Project | Basic Support for Trace Compass
Thu Jun 27 10:46:51 UTC 2019
On 27/06/2019 12:39, Ravindra Kumar Meena wrote:
>      > Okay. It worked. I have placed it in mis/record directory.
>      > It is a binary file. So I directly made a push to my GitHub
>     rtems-tools
>      > repository workplace.
>     https://github.com/rmeena840/rtems-tools/commit/70d527dcf8ae8a5026dd1af79e4d27c5adcbdade
>      > Have a look.
>     For whatever reason this file has only 98304 bytes. The content looks
>     all right. So, the next step is to modify the client so that it can
>     read
>     from a file instead of the TCP stream.
> I am trying to write code to read from the original raw record item.
I am not sure why you want to do this. On which task are you currently
working?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
