Attempt to get rid of -qrtems
Fri Jun 28 08:02:58 UTC 2019
On 28/06/2019 01:37, Chris Johns wrote:
> On 27/6/19 10:08 pm, Sebastian Huber wrote:
>> I would like to get rid of the -qrtems command for normal RTEMS applications.
> I do not think you can remove -qrtems as it will break all existing configure
> scripts. The default needs to be stubs.
Ok, this was just some side-effect of an attempt to get rid of the
bsp_specs. What about the attached patch.
You can add startfiles via the linker command file. Is it possible to
add also endfiles? I didn't find anything in the GNU ld documentation
about this.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190628/62436cbe/attachment-0002.bin>
