[PATCH 2/6] TDA19988 : Port to RTEMS
Christian Mauderer list at c-mauderer.de
Sun Jun 30 15:39:41 UTC 2019
On 30/06/2019 17:33, Vijay Kumar Banerjee wrote:
> The following patchset has only the port commits, the commits to import
> are pushed to Github and the links are as follows:
> [PATCH 1/6]
> : https://github.com/thelunatic/rtems-libbsd/commit/fa8900b30f5b41611ddc16e5b386a6b8b443675a
> [PATCH 3/6]
> : https://github.com/thelunatic/rtems-libbsd/commit/4f1cde1ef64e4a401cf4acd71bc5e681628fb3ed
> [PATCH 5/6]
> : https://github.com/thelunatic/rtems-libbsd/commit/efe23128b1cf39bdd75040067c95d87c05ae7f00
Hello Vijay,
just a side note: Are you aware of the --compose option of git
send-email? It's thought for adding an introductory message. In RTEMS
it's quite common to use this to add a short description of the patch
set and add comments like the one you just added.
Note that this depends on the community. For example the Linux mailing
lists suggest to _not_ use introductory messages for most cases.
Best regards
Christian
