Doxygen @return vs. @retval
Sebastian Huber
Fri Mar 1 09:56:53 UTC 2019
On 28/02/2019 17:06, Joel Sherrill wrote:
> On Thu, Feb 28, 2019 at 9:03 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello,
> we agreed to use @retval instead of @return:
> https://docs.rtems.org/branches/master/eng/coding-doxygen.html#doxygen-best-practices
> Is there going to be a global replacement or have they been purged?
This has to be done step by step. First we need clear guidance.
> How should we indicate that not a particular value is returned, but
> instead an element of a set. For example:
> * @brief Performs something and returns the operation status.
> * @retval 0 Successful operation.
> * @retval EIO Input/output error.
> * @retval <otherwise> Any other value will not be returned.
> int f(void);
> That last @retval doesn't match what I thought your statement above
> indicated.
> The English on the last @retval say there are no more. Why even
> include that?
To make it clear that nothing else is returned. Alternatively, we can
globally state that functions only return the values documented,
otherwise there is a documentation or code bug.
What about function pointer typedefs where you specify some requirements
on a particular implementation, e.g.
* @brief Write to flash operation.
* @param[in, out] self The flash control.
* @param[in] offset The offset to write from the flash begin in bytes.
* @param[in] buffer The buffer containing the data to write.
* @param[in] size_of_buffer The size of the buffer in bytes.
* @retval -EIO An error occurred. Please note that the value is negative.
* @retval other All other values are reserved and must not be used.
typedef int (*rtems_jffs2_flash_write)(
rtems_jffs2_flash_control *self,
uint32_t offset,
const unsigned char *buffer,
size_t size_of_buffer
> If you mean other errno's may be returned, that's different.
> What about the -1 and errno cases?
errno is a thread-local variable. You may document this in the @retval
-1 text.
> * @brief Creates an object.
> * @retval NULL Not enough resources to create an object.
> * @retval <object> Pointer to created object.
> T *create(void);
> We may also use "[object]" or "{object}" or "object" or whatever.
> Can we use "instance of T"?
You cannot use spaces in "@retval value text" for the value.
> I assume you used object generically. Wouldn't it be the specific noun
> for the created object?
My intent is to clarify which format we want to use for values which are
no particular C constant, e.g "<value>", "[value]", "{value}", "value",
or whatever.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
