[PATCH] RSB: upgrade to sis 2.13 (was: Issue with sis and Leon3)
Jiri Gaisler
jiri at gaisler.se
Sat Mar 2 20:50:00 UTC 2019
The attached patch for RSB solves the problem of output not being
flushed in gdb/sis and run/sis. Note that I would discourage the use of
run as it cannot run the SMP tests. I have also experienced some random
hangs in rtems-test when using run, but never with sis.
Jiri.
On 3/1/19 4:53 PM, Joel Sherrill wrote:
> Thank you for being so responsive.
> I suspected a missing flush but had no idea where to look. I hopedyou
> would spot the missing line of code quickly and was right. :)
> --joel
> On Thu, Feb 28, 2019 at 1:01 PM Jiri Gaisler <jiri at gaisler.se
> <mailto:jiri at gaisler.se>> wrote:
> I have found the problem, stdout is not flushed when the simulator
> stops and it has been invoked by gdb. The run command uses the gdb
> interface to call sis, so this is why it happens there too. I will
> make a new sis patch (2.13) with some additional (speed)
> improvements...
> Jiri.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190302/e53825b9/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190302/e53825b9/attachment.bin>
