[PATCH] user: correct the path to sb-set-builder
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Sat Mar 2 21:48:18 UTC 2019
Index 4.2 User Documentation, rtems query to specify the build set for
architecture, path to sb-set-builder
is: '$HOME/development/rtems/rsb/source-builder/sb-set-builder'
Mentioned command - '../source-builder/sb-set-builder --list-bsets' indicates
the path '$HOME/development/rtems/source-builder/sb-set-builder' , which is
unspecified.
user/installation/developer.rst | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/user/installation/developer.rst b/user/installation/developer.rst
index 541e04b..a903b58 100644
--- a/user/installation/developer.rst
+++ b/user/installation/developer.rst
@@ -92,7 +92,7 @@ build, just ask the tool:
.. code-block:: none
- $ ../source-builder/sb-set-builder --list-bsets <1>
+ $ ./source-builder/sb-set-builder --list-bsets <1>
RTEMS Source Builder - Set Builder, v4.11.0
Examining: config
Examining: ../source-builder/config <2>
2.20.1
