[PATCH] user: correct the path to sb-set-builder
Sun Mar 3 20:48:00 UTC 2019
On 3/3/19 8:48 am, Vaibhav Gupta wrote:
> Index 4.2 User Documentation, rtems query to specify the build set for
> architecture, path to sb-set-builder
> is: '$HOME/development/rtems/rsb/source-builder/sb-set-builder'
> Mentioned command - '../source-builder/sb-set-builder --list-bsets' indicates
> the path '$HOME/development/rtems/source-builder/sb-set-builder' , which is
> unspecified.
The path as documented is correct. It should be run in the `rtems` directory and
not the top level of the RSB. If this is not clear then a patch to improve the
documentation could help.
