[rtems commit] bsp/lm4f120: Disable unsupported tests
Mon Mar 4 21:43:24 UTC 2019
Hi
I thought it was clear that these patches should not be merged. They take
too broad a stroke and don't make any attempt to resolve the real issue.
The psxtm* amd tm* tests can easily be made to fit. Most of the offendiing
ones respect an OPERATION_COUNT define which controls how many
objects under test will be created.
Chris is working on a modification to override OPERATION_COUNT from
tcfg and that is the more elegant solution.
Some of the tests likely don't fit but this is a sledgehammer solution
and ignored the comments that didn't want these patches merged.
I would have implemented these a couple of months ago if I thought it
was prudent.
--joel
On Mon, Mar 4, 2019 at 12:20 AM Sebastian Huber <sebh at rtems.org> wrote:
> Module:    rtems
> Branch:    master
> Commit:    77971b66175c6c9e9c5889a65069a7701e3c8ec9
> Changeset:
> http://git.rtems.org/rtems/commit/?id=77971b66175c6c9e9c5889a65069a7701e3c8ec9
> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:      Mon Feb 25 13:47:42 2019 +0100
>  bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg | 70
>  1 file changed, 64 insertions(+), 6 deletions(-)
> diff --git a/bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg
> b/bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg
> index 8eafa26..0c074d0 100644
> --- a/bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg
> +++ b/bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg
> @@ -7,21 +7,79 @@
>  include: testdata/disable-iconv-tests.tcfg
>  include: testdata/disable-jffs2-tests.tcfg
> +exclude: block08
> +exclude: capture
>  exclude: fileio
> -exclude: cdtest
> -exclude: iostream
>  exclude: flashdisk01
>  exclude: fsdosfsname01
>  exclude: ftp01
>  exclude: linpack
> +exclude: loopback
>  exclude: mghttpd01
> -exclude: monitor02
> +exclude: ostream
>  exclude: pppd
> +exclude: psxaio01
> +exclude: psxaio02
> +exclude: psxaio03
> +exclude: psxconfig01
> +exclude: psxtmbarrier02
> +exclude: psxtmclocknanosleep02
> +exclude: psxtmclocknanosleep03
> +exclude: psxtmcond08
> +exclude: psxtmcond09
> +exclude: psxtmcond10
> +exclude: psxtmmqrcvblock01
> +exclude: psxtmmqrcvblock02
> +exclude: psxtmmutex02
> +exclude: psxtmmutex04
> +exclude: psxtmmutex06
> +exclude: psxtmnanosleep02
> +exclude: psxtmrwlock02
> +exclude: psxtmrwlock03
> +exclude: psxtmrwlock04
> +exclude: psxtmrwlock05
> +exclude: psxtmrwlock07
> +exclude: psxtmsem03
> +exclude: psxtmsem05
> +exclude: psxtmsleep02
> +exclude: psxtmthread01
> +exclude: psxtmthread03
>  exclude: sp16
>  exclude: sp25
> +exclude: sp42
> +exclude: sp47
>  exclude: sp48
> +exclude: sp71
>  exclude: spstkalloc02
> -exclude: sptls02
> -exclude: rtems++
> -exclude: tmfine01
> +exclude: sptimecounter02
> +exclude: sptimecounter03
> +exclude: tm02
> +exclude: tm03
> +exclude: tm04
> +exclude: tm05
> +exclude: tm06
> +exclude: tm07
> +exclude: tm10
> +exclude: tm11
> +exclude: tm12
> +exclude: tm13
> +exclude: tm14
> +exclude: tm15
> +exclude: tm16
> +exclude: tm17
> +exclude: tm18
> +exclude: tm21
> +exclude: tm23
> +exclude: tm24
> +exclude: tm25
> +exclude: tm26
> +exclude: tm29
> +exclude: tm31
> +exclude: tm32
> +exclude: tm33
> +exclude: tm34
> +exclude: tm35
> +exclude: tm36
> +exclude: tmcontext01
> +exclude: top
>  exclude: utf8proc01
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190304/bf9a25c9/attachment.html>
