[rtems commit] bsp/lm4f120: Disable unsupported tests
Mon Mar 4 22:15:46 UTC 2019
On 5/3/19 8:43 am, Joel Sherrill wrote:
> I thought it was clear that these patches should not be merged. They take
> too broad a stroke and don't make any attempt to resolve the real issue.
> The psxtm* amd tm* tests can easily be made to fit. Most of the offendiing
> ones respect an OPERATION_COUNT define which controls how many
> objects under test will be created.
Yes they can.
> Chris is working on a modification to override OPERATION_COUNT from
> tcfg and that is the more elegant solution.
I am as per this email ...
https://lists.rtems.org/pipermail/devel/2019-February/024997.html
I will merge then update these configs to use the new cflags option.
> Some of the tests likely don't fit but this is a sledgehammer solution
> and ignored the comments that didn't want these patches merged.
> I would have implemented these a couple of months ago if I thought it
> was prudent.
I did not know we had a problem.
