Query for GSOC Project
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Tue Mar 5 04:46:59 UTC 2019
Thanks for clarification. I will follow the resources.
On Mon, 4 Mar, 2019, 3:18 PM Christian Mauderer <
christian.mauderer at embedded-brains.de wrote:
> Am 04.03.19 um 07:47 schrieb Sebastian Huber:
> > Hello Vaibhav Gupta,
> > On 04/03/2019 07:27, Vaibhav Gupta wrote:
> >> I am unable to confirm, if the project is open for GSOC, as some of
> >> them are labelled as new/ need for funding, etc.
> >> So, I made a list of projects which I find interesting. It would be
> >> very helpful for me to finalize a project if mentors confirm which of
> >> the following projects are open/ not open for GSOC.
> >> 1. #3476 : IMFS- Improve bytes per block handling. :
> >> https://devel.rtems.org/ticket/3476
> >> 2. #3477 : IMFS - Add Configurable Allocator Support :
> >> https://devel.rtems.org/ticket/3477
> > the IMFS tickets contain not enough work for a GSoC project.
> >> 1. #3338 : Port CHFS to RTEMS : https://devel.rtems.org/ticket/3338
> > This would be suitable GSoC project if you find a mentor. It needs to
> > deal also with the Erase Block Handler (EBH).
> >> 1. #3428 : Add SDIO driver support to rtems-libbsd :
> >> https://devel.rtems.org/ticket/3428
> >> <https://devel.rtems.org/ticket/3028>
> > I am not sure what the status of this is, it was a GSoC project before.
> > My experience is that this is close to the hardware level and difficult
> > to debug if you don't have a JTAG debugger.
> Last year Udit worked on this project (CC on this mail). See the
> following for the status reports:
> https://devel.rtems.org/wiki/GSoC/2018#UditkumarAgarwal
> The really relevant part of the status is the one from July 18th: The
> driver already started to work but it was still not fully functional.
> After that some more benchmarks have been carried out due to some slight
> direction change in the project.
> For SDIO the stack would have to be updated to the latest version of
> libbsd and some debugging would be necessary. That is most likely not
> enough work left for a complete project.
> Kind regards
> Christian
> > Please also have a look at the open projects page:
> > https://devel.rtems.org/wiki/Developer/OpenProjects
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190305/6e2f1651/attachment.html>
