Doxygen Groups for cpukit
Thu Mar 7 13:19:45 UTC 2019
Hello,
I adjusted several hundred Doxygen groups in the BSP area this week. It
is not finished, but it is now in a much better shape. My next step is
to adjust the groups in the cpukit area. I propose the following coarse
structure:
* Board Support Packages
* Device Drivers
   * Block Devices
     * Block Device Buffer Management
     * Block Device Disk Management
     * Block Device Management
       * XYZ Block Device
     * Block Device Partition Management
   * Cache
     * XYZ Cache Support
   * Console
     * Termios
       * XYZ Driver
   * Framebuffer
     * XYZ Driver
   * I2C
     * Bus Driver
       * XYZ Driver
     * Device Driver
       * XYZ Driver
   * Legacy I2C
   * Legacy Network
   * RTC
       * XYZ Driver
   * Serial Mouse
       * XYZ Driver
   * SPI
     * Bus Driver
       * XYZ Driver
     * Device Driver
       * XYZ Driver
* API
   * Classic
     * Tasks
   * Dynamic Loading
   * File Systems
   * Memory Management
   * Shell
   * Tracing
     * Event Recording
     * Capture Engine
* Internal
   * C Library Support
   * POSIX
   * Super Core
     * Thread Handler
     * CPU
       * ARM
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
