Doxygen Groups for cpukit
Joel Sherrill
joel at rtems.org
Thu Mar 7 14:19:56 UTC 2019
On Thu, Mar 7, 2019 at 7:19 AM Sebastian Huber <
> Hello,
> I adjusted several hundred Doxygen groups in the BSP area this week. It
> is not finished, but it is now in a much better shape. My next step is
> to adjust the groups in the cpukit area. I propose the following coarse
> structure:
> * Board Support Packages
> * Device Drivers
> * Block Devices
> * Block Device Buffer Management
> * Block Device Disk Management
> * Block Device Management
> * XYZ Block Device
> * Block Device Partition Management
> * Cache
> * XYZ Cache Support
> * Console
> * Termios
> * XYZ Driver
> * Framebuffer
> * XYZ Driver
> * I2C
> * Bus Driver
> * XYZ Driver
> * Device Driver
> * XYZ Driver
> * Legacy I2C
> * Legacy Network
> * RTC
> * XYZ Driver
> * Serial Mouse
> * XYZ Driver
> * SPI
> * Bus Driver
> * XYZ Driver
> * Device Driver
> * XYZ Driver
> * API
> * Classic
> * Tasks
> * Dynamic Loading
> * File Systems
> * Memory Management
> * Shell
For the shell, very little is really a public API. Most is internal.
I suspect this applies in many places.
* Tracing
> * Event Recording
> * Capture Engine
> * Internal
> * C Library Support
> * POSIX
For POSIX and C Library Support, some significant portion of the contents
are public APIs.
Some should be included in APIs and some in Internal.
* Super Core
> * Thread Handler
> * CPU
> * ARM
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190307/d5236414/attachment-0001.html>
