[PATCH] shell: Correct argument order of `mfill`
Fri Mar 8 06:40:54 UTC 2019
On 01/03/2019 19:21, Jonathan Brandmeyer wrote:
>   cpukit/libmisc/shell/main_mfill.c | 2 +-
>   1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libmisc/shell/main_mfill.c b/cpukit/libmisc/shell/main_mfill.c
> index d8e2fcf74c..47a55d3a2f 100644
> --- a/cpukit/libmisc/shell/main_mfill.c
> +++ b/cpukit/libmisc/shell/main_mfill.c
> @@ -60,7 +60,7 @@ static int rtems_shell_main_mfill(
>      *  Now fill the memory.
> -  memset(addr, size, value);
> +  memset(addr, value, size);
>     return 0;
Fixing this bug on the master is easy, but the bug is there in all RTEMS
versions since 2007. If you fix this properly means you need tickets for
a couple of RTEMS versions and an individual commit message
corresponding to each ticket. The administration overhead is huge. I
just fixed it for RTEMS 5.1:
https://devel.rtems.org/ticket/3720
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
