Beagleboard BSP Framebuffer
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Mar 12 10:35:39 UTC 2019
On Tue, 12 Mar 2019 at 15:27, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Am 12.03.19 um 10:52 schrieb Vijay Kumar Banerjee:
> > On Mon, 11 Mar 2019 at 19:21, Gedare Bloom <gedare at rtems.org
> > <mailto:gedare at rtems.org>> wrote:
> > On Sun, Mar 10, 2019 at 7:31 PM Joel Sherrill <joel at rtems.org
> > <mailto:joel at rtems.org>> wrote:
> > The MINIX license is BSD with advertising clause as I read it.
> > That is less preferable to a 2-paragraph BSD license that you
> > are likely to find in Freebase. Try there.
> > The license is fine if you find nothing else. I assume Joel meant
> > FreeBSD.
> > Study the framebuffers in i386 and raspberrypi code bases.
> > Hello,
> > Thanks for the reference, I found the tda19988 driver in freebsd source.
> > Following the raspberrypi framebuffer, I have made a header file with
> the
> > basic functions to implement. The implementation will be using the
> > driver code from the freebsd.
> > What needs to be figured out next is how to use the driver code with
> rtems,
> > since the file uses a lot of header files from the freebsd source, how
> do we
> > go about integrating it with rtems? Is there any guide on using codes
> from
> > different projects into RTEMS?
> Hello Vijay,
> for FreeBSD we have the libbsd as an easy way to integrate sources and
> keep them up to date. Although I don't think that we have a framebuffer
> driver there yet I would expect that it is a good method for that too.
> Best regards
> Christian
> Hi
I cloned the rtems-libbsd and the framer driver is not there. I wonder if
adding
this drivers to libbsd is itself a meaty task. Do we need a ticket for this
Also, the driver uses i2c bus driver from FreeBSD source, I see that the
i2c driver
is nicely supported in the rtems beagle bsp, how to use the i2c module in
the bsp,
with the hdmi framer driver in libbsd ? (I'm a bit confused here :) )
> > It is usable in RTEMS though. We just try to avoid pushing the
> > advertising requirement
> > On Sun, Mar 10, 2019, 12:47 PM Vijay Kumar Banerjee
> > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>
> wrote:
> > On Fri, Mar 8, 2019, 12:35 AM Vijay Kumar Banerjee
> > wrote:
> > Hi,
> > I was reading up and trying to figure out the steps to
> > achieve this project. Here's
> > what I came up with :
> > 1. BBB uses TD19988 HDMI Framer, so the first step is to
> > get an HDMI output,
> > read EDID info and set the videomode according to the
> > info. After some searching,
> > I found a driver in minix that might be helpful. Is the
> > minix license compatible?
> https://github.com/Stichting-MINIX-Research-Foundation/minix/blob/03ac74ede908465cc64c671bbd209e761dc765dc/LICENSE
> > 2. Set the values of structs from fb.h
> > 3. Write the fb.c using the functions from framebuffer.h
> > ( I'm taking the fb.c in raspberrypi
> > as example and the bsp-howto as a reference text)
> > The above list is just an outline and I intend to
> > explore/understand it better and make a
> > proposal out of it.
> > Does this list make sense to you?
> > What am I missing?
> > I would really appreciate any remarks/comments or
> > details you'd like to add, it will help me understand it
> > better.
> > ping :)
> > Thanks,
> > --vijay
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190312/63573b7e/attachment.html>
