Doxygen @param and [in], [out] or [in,out]?
Sebastian Huber
Wed Mar 13 06:55:42 UTC 2019
On 28/02/2019 15:52, Sebastian Huber wrote:
> Hello,
> we agreed to use @param for function parameter documentation:
> https://docs.rtems.org/branches/master/eng/coding-doxygen.html#doxygen-best-practices
> Do we want to use [in], [out] or [in,out] as well?
> If yes, how are [in], [out] or [in,out] used exactly? For example
> consider values passed by reference. Is in
> void f(int *a)
> if (*a == 0) {
> *a = 1;
> the parameter a an [in,out] parameter? What about
> void g(int *a)
> *a = 1;
> How can we ensure that this extra information is consistent throughout
> the documentation?
> I think we should remove all the [in], [out] or [in,out] stuff. From
> the parameter type it is quite obvious how they are used, e.g. "type
> *param" vs. "const type *param". For passed by value it is clear that
> they are input parameters. Output only use is normally indicated by
> the function name, e.g. "initialize", "set", "create", etc.
In ticket
http://devel.rtems.org/ticket/3721
Jens Schweikhardt proposed the following:
"1) only pointer parameters are annotated (since scalars are [in] by
language definition)
2) [in] indicates that the pointer must point to an initialized object (it
may be dereferenced by the directive)
3) [out] indicates that the object pointed to may be written by the
directive
4) [inout] If both 2) and 3) apply."
I think these are good guidelines. What about annotation of const pointers? Should they get the [in] annotation which is somewhat redundant?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
